Joined Nov 2010
Testing RVOSD G5 (G4 main board) on my Skywalker 1900mm. I love it!
One question though, is it possible to change the radius of the circle it takes above home? Thanks! |
Joined Aug 2012
Setting Home not happening
Monday it all worked fine. Had a great FBW flight.
Today it took forever to get the satellites to lock. After a long wait the 'Setting Home" started to count up. It made it to 125 several times and restarted at 0 Then it remained at zero. After a long wait ( 5-7 mins) I disconnected and restart the OSD by disconnecting power. Again it took forever to get the satellites. It showed Setting Home 0" and never counted up. Waited another (10 mins) and reset the OSD again with the same result. HDOP is set at the default 1.30. This was all done at the field in the open. Any ideas? Thanks, |
Happend to me once, too. Exactly the same. I spend about 40 minutes trying, resetting (with IR controller) and swearing. I also tried remove batteries, but with no success.
After then I removed battery, wait for about 5-7 minutes (without any power, to cool it down), reconnect it and get the lock in about minute. It happened to me only once. I have never such problem before or after this. Possible reason was bad wiring of my aileron servos - they are placed next to GPS, but in this case they led (due to my mistake when placing the Skywalker wing) right above GPS antenna. Funny is, that simple reset did not solve this - I had to wait with disconnected RVOSD for some minutes, then it worked as well as always... |
I am really going to miss the Google Earth ground track logging, so I am trying to come up with an add-on solution. Please take a look at these serial data loggers, and tell me if you think they will work with the RVOSD GPS data. This one from Sparkfun https://www.sparkfun.com/products/9530 seems very flexible. It can log GPS data using a removable SD card. If it could tap into the RVOSD GPS cable safely, it would be an inexpensive solution. Ideally some firmware could be created to automatically make .KML files, otherwise that could be done on the PC with a little more hassle. Here are other solutions: https://www.sparkfun.com/products/9530 This would make a great add-on option to the RVOSD. This seems like it should be easy, but last time I used that word you showed me how difficult "easy" can be! Thank you again for answering all these questions. |
The RVGS doesn't have logging either, it requires a computer which is too cumbersome to hassle with in the field. The RVGS should have built in logging onto an SD card also. |
| Thread Tools | |
| Discussion Maiden Reports | 12345 | Arizona Model Aviators | 466 | Apr 23, 2013 06:29 PM |
| Help! RVOSD thermal sensors | rcmonster99 | Video Piloting (FPV/RPV) | 16 | Jun 20, 2011 10:21 AM |
| Discussion Weekend weather reports | neck | Arizona Model Aviators | 13 | Jun 10, 2011 04:59 PM |
| Discussion where are the Joe Nall horror "reports? | guy hanson | Radios | 49 | May 18, 2011 12:06 PM |
| Discussion Finally Fixed the Country Reports | daboz | Dynamic Soaring | 5 | May 16, 2011 02:51 AM |
