Old Aug 31, 2012, 02:33 PM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
Alex does specify to set on ground, Do you turn off motor and glide while setting?
picard10th is offline Find More Posts by picard10th
Old Aug 31, 2012, 02:39 PM
cabster101 is offline
Find More Posts by cabster101
United States, TX, Austin
Joined Jul 2011
I don't remember if I had the motor on or off. Maybe the motor has to been off and that's why I can't get it to come up. Will test that next time.
cabster101 is offline Find More Posts by cabster101
Old Aug 31, 2012, 02:50 PM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Originally Posted by cabster101 View Post
Anyone else ever have a hard time setting neutral AHI while in the air? I've done it before a few times but sometimes I can't get the screen to calibrate it to come up. I get in the menu and go to Set neutral AHI and push to the right but nothing happens. I've had the issue off and on in the past but today I couldn't access it at all. I can set all other menu options without issue.
I can set it on the ground but I can never get it perfect. I've had better luck setting it in the air when I can get it to come up.
This is on 5.07 but I had the same issue on 5.06.
Do this on the ground!
BushmanLA is offline Find More Posts by BushmanLA
Old Aug 31, 2012, 03:04 PM
Joined Jul 2011
I figured it out. It won't let you set neutral AHI in the air if you have FBW turned on when you enter the menu. I should have remembered that.
Old Aug 31, 2012, 03:06 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
I'm trying to get strong confidence in the RTH before I go any distance. One concern is some times is seems very slow to respond like its not sure what to do maybe in time it would turn but I have to cancel RTH while I can still safely pilot it back what setting would start the turn quicker not necessarily increase turn angle or don't you see a problem? Example at 9:22
Check Post #2383 of this same thread.
First, you need to read the instructions about setting neutral AHI. Long story short: Do not set neutral AHI in flight.
Second, The set neutral AHI menu is blocked if there is any stabilization mode enabled. This is why sometimes you noticed it does not work.
You don't need to set neutral AHI on every flight, after it is properly set, just save configuration before powering OFF the OSD. Only need to set it again if the OSD board attitude change relative to the airplane.
Elcheapo is offline Find More Posts by Elcheapo
Old Aug 31, 2012, 03:26 PM
Joined Jul 2011
I'm not trying to set the AHI every flight. This a new plane I just got in the air, trimmed and set neutrals on. I noticed in FBW it was climbing too much and I wanted to level out the AHI without having to land. Which I have done in past with other planes using RVOSD. This is my 3rd RVOSD and I forgot about having FBW off when trying to set it in the air because it is something you only do once like you said.
Old Aug 31, 2012, 03:31 PM
Rastislavko is online now
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
Little notice about setting neutral AHI: if you've got version 5 and newer, always set it on ground. BUT make sure you have the plane at the flight position - for most airplanes it means at least 5 degrees nose up! So you have to place something under the nose of your airplane to get the proper position. If you set neutral AHI with airplane perfectly leveled (without nose up), it will cause you some problems - it will make your plane dive instead of level flying. Once set properly, you no need to do this anymore...
Rastislavko is online now Find More Posts by Rastislavko
Old Aug 31, 2012, 03:46 PM
Joined Jul 2011
I've done it that way. Sometimes you have the nose too high and sometimes you have it too low. Then you have to keep landing and keep resetting until you get it where you want it. When I set it in the air it's perfect the first time. I understand that it isn't the way the manual or Alex says is the best way but it works for me.
Old Aug 31, 2012, 04:58 PM
picard10th's Avatar
Joined Jan 2007
[QUOTE=Elcheapo;22605168]Check Post #2383 of this same thread.
The rate of turn is not the issue its if the turn is initiated. in the video you can see times when RTH is engaged it starts turning but some times it doesnt seem to start the turn. i read your words of wisdom over and over sometimes its the terms that need clarifying.
My main concern is why it reacts fast sometimes and slow others I'm 500-1000 ft outside loiter radius
Old Aug 31, 2012, 05:53 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
Increase Max roll and pitch angles, keep in mind there is a Loiter radius setting. Inside the loiter radius the autopilot will try to set from 180(away from home) to 90(try to stay on the circle).
Old Aug 31, 2012, 06:27 PM
iskess is online now
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Not really, the inertial unit does have yaw reference for short term corrections. The magnetometer is only needed for long term orientation corrections on VTOL aircraft types.
[Suggestion #2]
Alex,
You now have the 4 ingredients to give us a winds aloft vector arrow and speed.
Heading via Magnetometer
GPS track
Ground Speed
Airspeed
It would be very useful for long cross country flights to know the winds. Imagine how much more accurate the range remaining calculation would be.
iskess is online now Find More Posts by iskess
Old Aug 31, 2012, 07:16 PM
Pixturethis is offline
Find More Posts by Pixturethis
Pixturethis's Avatar
Wichita
Joined Dec 2008
Now that would be a very nice tool to have.
Marc
Pixturethis is offline Find More Posts by Pixturethis
Old Aug 31, 2012, 08:25 PM
picard10th's Avatar
Joined Jan 2007
Current menus 5.07
5.07 menus for everyones info!
Alex, Are roll & pitch angles default
Old Aug 31, 2012, 08:44 PM
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
[Suggestion # 3]
Edit: Already in place!
I will be using DragonLink and I gather the over-throttle is the best method for me to set up RTH.
What if the Rx fails rather than the Tx, and there is a loss of PPM signal to the RVOSD?
The DOSD has its own built in failsafe, in addition to the Rx's failsafe, that kicks in if it detects PPM at start up and later looses it.
It seems like the RVOSD could use its packet detection on the AUX channel to serve the same function, but can it work in conjunction with the over/under throttle method as a back-up? Or does choosing one disable the other?
Excuse me if this is an ignorant question, I am still trying to understand the intricacies of the RVOSD.
Old Aug 31, 2012, 08:49 PM
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
[Suggestion #4]
Wow! That's a lot of menus.
Alex, what if we had a shortcut menu that was fully customizable so we could put our most used items on it. This wouldn't change the order of the original menus, just add a quick access to those that you most frequently so they aren't buried in with the set-it-and-forget-it items.
I haven't flown the RVOSD yet, but it looks cumbersome to wade through these menus while piloting.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
