Old Aug 24, 2012, 08:37 PM
Joined Dec 2007
anyone knows of any shops in Europe that sells RVOSD?
Dworf is offline Find More Posts by Dworf
Old Aug 24, 2012, 09:44 PM
Illinois, USA
Joined Aug 2009
I believe it's only available direct from RangeVideo.
vertcnc is offline Find More Posts by vertcnc
Old Aug 25, 2012, 05:52 PM
Joined Sep 2011
I have some problem with RTH on two different Rvosd. Its the similar problem on both so i guess it something i do wrong.
I tried gain 50-65. And also roll angle 35-65. But it didnt help. Problem is that it doesnt seem to bank enough to go home. Or it just changes direction a bit and continue away.
I made video on both cases.
RVOSD problems (0 min 40 sec)
Please help me out here.
zkilzz is offline Find More Posts by zkilzz
Old Aug 25, 2012, 06:17 PM
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
How does the plane respond in FBW mode? Have you run the setup wizard? Have you set neutrals?
ommadawn is offline Find More Posts by ommadawn
Old Aug 26, 2012, 02:54 AM
Joined Sep 2011
Flybywire works fine. It flies in a straight line with both planes. Done the wizard many times.
Old Aug 26, 2012, 03:28 AM
Joined Sep 2011
I dont think i set neutrals. Do you need to do that AND do the rc wizards? I tought you set neutrals in the rc wizard.
Old Aug 26, 2012, 03:45 AM
Out of sight, not out of mind
octane81's Avatar
Antarctica
Joined Oct 2010
You need to set neutrals after you trimmed out the plane ... remember to save after , or they will be lost when you disconnect the battery.
octane81 is offline Find More Posts by octane81
Old Aug 26, 2012, 04:58 AM
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
Exactly. You need to trim the plane to fly straight and level, then when the trims are set, you enter the a/p and "set neutrals". This is the flight control surface positions the a/p will use to fly level. You must save this before you power off. It must be redone any time you make changes to the aircraft that will effect its flight characteristics.
Old Aug 26, 2012, 06:01 AM
Joined Sep 2011
Can i save in in flight menu? But will this make my plane bank more and be able to rth?
Old Aug 26, 2012, 08:16 AM
Joined Jan 2011
I need to do that even with inflight menu options? I don't recall doing that, and my settings are still there. Time for a test
npre is offline Find More Posts by npre
Old Aug 26, 2012, 10:45 AM
Joined Sep 2011
I did it. But it didnt effect anything. It didnt change. I trimmed it and then did the rc manual.
Still got the same problem tough. Today i turned on the RTH in a 60 angle bank. It just leveled out the plane and contiue moving in that direction. What am i doing wrong then?
Old Aug 26, 2012, 01:39 PM
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
It's good to check all settings, proportional etc. To make sure nothing got accidentally changed.
picard10th is offline Find More Posts by picard10th
Old Aug 26, 2012, 01:55 PM
Elcheapo's Avatar
Joined Oct 2007
First, you need to understand that the autopilot will try to keep circling above home within the radius set on RTH loiter radius, note that can be set to clock wise(CW) or counter clock wise(CCW). So if you are flying inside this radius the autopilot will effectively try to go out of home. Also even as it is turning slowly, if you leave it as is, it will eventually go back home by doing a very wide turn.
If you still want to increase the autopilot authority, Increase Max roll angle, make sure that if you move the ailerons max to the right the autopilot set this max angle on FBW mode. If not increase the roll proportional gain on slow increments until roll axis start to oscillate and then set it 5-10 units back.
If it does still turns slowly, increase heading proportional gain on slow increments until it does not improve anymore, if you reach this adjust and still need more bank angle then increase heading proportional limit.
Finally... I have explained this few times on the rangevideo forum. If you feel frustrated anytime a quick use of the search function there, will take you out of frustration.
http://rangevideo.com/forum/forum.php
Elcheapo is offline Find More Posts by Elcheapo
Old Aug 26, 2012, 05:59 PM
Multi Rotor Maniac
Stunt Double's Avatar
Joined Oct 2007
Could you write this all up as an official document and publish at the range video website? Its been asked many times before but its no good having the info buried in a forum.
Stunt Double is offline Find More Posts by Stunt Double
Old Aug 26, 2012, 07:49 PM
picard10th's Avatar
Joined Jan 2007
Exactly! I'm working on a sort of guide for dummies here are som of Alex's quotes .
Discussion Maiden Reports 12345 Arizona Model Aviators 466 Apr 23, 2013 06:29 PM
Help! RVOSD thermal sensors rcmonster99 Video Piloting (FPV/RPV) 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
