Old Aug 08, 2012, 12:17 PM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
Originally Posted by vertcnc View Post
I just depends on if it is the same location you flew the previous time. Normally my GPS intializes in about 2-3 min. for the first flight and about 10-20 sec. for the following flights. I am also using 1.3ghz 1 watt VTX. It could be noise from another source, maybe camera. You could try using torriods on the camera leads and also the GPS leads.
Where have you placed the Vtx and gps on your plane?
timtimtim is offline Find More Posts by timtimtim
Old Aug 08, 2012, 12:45 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
I have a X8 and the GPS is in the fuselage under the foam hatch. The VTX is out on the wing about 8-10".
vertcnc is offline Find More Posts by vertcnc
Old Aug 08, 2012, 12:50 PM
vertcnc is offline
Illinois, USA
Joined Aug 2009
timtimtim,
What you could do is run a test to see if your camera or vtx is interfering. Just unplug yuor camera or vtx for the first min. or so and plug it back in and see if you have sats.
Old Aug 08, 2012, 03:12 PM
sancho28 is offline
Find More Posts by sancho28
Originally Posted by IMEIV View Post
Yes ch9 is the PPM out. But I wanted to ask what's the correct choice in main mený, page 3/4 at the voice RSSI input... Analog or Packet 1 ?
Nope, on 12ch version ppm is on ch12
sancho28 is offline Find More Posts by sancho28
Old Aug 08, 2012, 03:30 PM
IMEIV is online now
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Originally Posted by boopidoo View Post
Of course
thanks.
IMEIV is online now Find More Posts by IMEIV
Old Aug 08, 2012, 03:32 PM
IMEIV is online now
IMEIV's Avatar
Joined Apr 2009
Ok
Old Aug 09, 2012, 04:53 AM
Joined Apr 2012
Okay, do you have a lowpassfilter on the vtx?
Old Aug 09, 2012, 07:13 AM
FPVAustralia is offline
Find More Posts by FPVAustralia
Joined Jul 2012
Great OSD!
FPVAustralia is offline Find More Posts by FPVAustralia
Reply With Quote  (Disabled)
Old Aug 09, 2012, 08:39 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Heres a question for the RF techs. Im planning on using a 2.4Ghz 18Db patch and a Lawmate Rx with my RV tracker. Do I need 50ohm or 75ohm impedance coax? I intend using only about 200mm. Will it make a difference over this length?
ommadawn is offline Find More Posts by ommadawn
Old Aug 09, 2012, 08:54 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
You need 50 ohm cable. Yes, it could make a difference as the cable otherwise would act like an impedance transformer. Not likely that something would happen since this is the receiving side of things, but you get better reception with a matched impedance.
Check for an apropriate RG58 or RG316 coax cable. They can be bought off ebay for not much money.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Aug 09, 2012, 09:25 AM
vertcnc is offline
Illinois, USA
Joined Aug 2009
No filters, no torroids. It could be your VTX, the freq's are close. I would try torroids or additional spacing. Definetly check if it get connect without camera or VTX.
Old Aug 09, 2012, 10:45 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
@timtimtim
The GPS battery could be bad as well resulting in long cold start up every time.
boopidoo is offline Find More Posts by boopidoo
Old Aug 09, 2012, 06:49 PM
Joined Apr 2012
Just a question, is IMU better than Thermopiles? OR whats thw difference? Because i changed the direction of the board with usb backwards but when I go right the ahi seems to go to the left instead?
Old Aug 09, 2012, 07:02 PM
vertcnc is offline
Illinois, USA
Joined Aug 2009
IMU is much better. Not affected by sunlight, clouds or ground terrain. If you change the orientation of the board, you also have to change the setting in the menu. Can't remember exactly which one.
You can also check the manual on the RVOSD support site.
Old Aug 10, 2012, 03:43 AM
Joined Apr 2012
I know i have to change settininfs but it seems like i only can use Thermopiles if i have rvosd usb pointing backwards.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
