Old Aug 07, 2012, 03:09 PM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
Originally Posted by IMEIV View Post
Now Dragon Link works with RVOSD by PPM input in Elev in channel. Great...
Regarding the rssi I can't find reading instruction the type of signal. Someone that use Dragon Link and RVOSD can tell me what's the correct choice... Analog or Packet 1 ?
Id better stay on the RVOSD page here. Could you show how. Im going to redo mine tonight. I need to get alot of wires out of my bay. So servos plug into rvosd outputs and 1 in elivator to DL rx ppm ch9 or ch12?
RUBNorris is offline Find More Posts by RUBNorris
Old Aug 07, 2012, 03:19 PM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Consider that ch9 is printed incorrectly... connect servo plug in ch12 (although in truth it would be ch9) and the other side in elevator in on rvosd.
Then go in main mený page 4 and select:
R/C receiver connected: YES
Rx input Type: Combined PPM
Finally go above in PPM configuration and select the correct function watching to values that change.
IMEIV is offline Find More Posts by IMEIV
Old Aug 07, 2012, 03:31 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Woot thanks! Ill do that today when i get home.
Old Aug 07, 2012, 04:38 PM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
I'm pretty sure you should use Analog.
boopidoo is offline Find More Posts by boopidoo
Old Aug 07, 2012, 09:57 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Ok, pluged in and im getting no value change. Servos are in out ch. And DL has 1 plug in on ch12 the ppm to rvosd to elev. Did i miss anything? Menu screen is set as above.
Old Aug 07, 2012, 10:55 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Fixed it. Im going to do a video to help other noobs..... Lol i feel better now.
Old Aug 07, 2012, 11:36 PM
ROCKY2 is offline
Find More Posts by ROCKY2
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
still have not heard back on a few emails
ROCKY2 is offline Find More Posts by ROCKY2
Old Aug 08, 2012, 12:58 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Thanks. Do you suggest to solder the resistor on rssi signal wire ?
Old Aug 08, 2012, 06:31 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Better than James Brown??
Good stuff. Glad you got it sorted. This stuff sure challenges the patience. If I might make a suggestion, but yourself some spares like extra Vtx, camera, leads and VRx. Its a bugger trying to debug video problems when you havent got anything to swap with. Inevitably at some stage during setup or installation you may lose video, and where to begin??? Having extra hardware means not having to wait for new stuff and simplifies debugging too.
Cheers and enjoy
Frank
ommadawn is offline Find More Posts by ommadawn
Old Aug 08, 2012, 07:06 AM
CN I Dawg is offline
Find More Posts by CN I Dawg
Crash=start of next project
CN I Dawg's Avatar
Joined Nov 2010
Originally Posted by pardus View Post
I have ArduPilotMega 2 and Remzibi OSD which I'm pretty happy with but a friend is now looking for a waypoint/RTH/stabilization/OSD system and is considering RV-OSD5. I have no knowledge of it apart from the little I've read here on the forum and the website. My friend is not very computer savvy.
APM2 + minumOSD costs around $287 excl. postage (excl. current sensor), RV-OSD is $299.
Can someone who has used both give me an objective comparison?
Hi,
I have both...by not very computer savvy, do you mean your friend is not technical? If so, go with RVOSD. It is way more consumer friendly.
The two are mostly equal functionality when it comes to FPV'ng, however, if you want telemetry, UAV and a more feature rich GS, the APM2 is the way to go.
So we don't hijack this thread, PM me if you have specific questions.
Best,
Dog
CN I Dawg is offline Find More Posts by CN I Dawg
Old Aug 08, 2012, 07:59 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
i just wonder, what is the average time for startup, initializing of gps etc..? i tried my setup, im using lawmate 1W transmitter and it takes about 5-7 minutes before i get a signal of 1.3-1.5 HDOP, no difference if its 0,5 meter or 1 meter between GPS and transmitter.
timtimtim is offline Find More Posts by timtimtim
Old Aug 08, 2012, 08:06 AM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
I just depends on if it is the same location you flew the previous time. Normally my GPS intializes in about 2-3 min. for the first flight and about 10-20 sec. for the following flights. I am also using 1.3ghz 1 watt VTX. It could be noise from another source, maybe camera. You could try using torriods on the camera leads and also the GPS leads.
vertcnc is offline Find More Posts by vertcnc
Old Aug 08, 2012, 11:14 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
I changed FrSky receiver with DL Rx receiver and I changed Hitec radio with Futuba T12FG and DL module.
Is it necessary to remake R/C Wizard and setup again Set throttle FS detect ?
Old Aug 08, 2012, 12:07 PM
boopidoo is offline
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Of course
Old Aug 08, 2012, 12:10 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I received my RVOSD today. Nice packaging and quick delivery. Hope to get it setup in the coming weeks.
7oneWo1f is offline Find More Posts by 7oneWo1f
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
