Old Aug 04, 2012, 12:32 PM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
can someone explain how to get 9x 3 switch to work with the default firmware`?
timtimtim is offline Find More Posts by timtimtim
Old Aug 04, 2012, 01:01 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
http://rangevideo.com/forum/showthre...switch+digikey
Elcheapo is offline Find More Posts by Elcheapo
Old Aug 04, 2012, 02:02 PM
Joined Apr 2012
Originally Posted by Elcheapo View Post
Thanks but that didnt help me at all, thats for er9x i have the standard firmware that comes with the 9x.
Old Aug 04, 2012, 10:39 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I think you can do a firmware change.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Aug 04, 2012, 10:41 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Okay, so I just ordered one of these. Anybody using this with a hercules? I have the 78" version, and am wondering if I could set up the standard elevator/elevons/rudder, but only use the elevons for RTH and waypoints?
Old Aug 05, 2012, 04:55 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
OK guys what do you think is the issue here...
weird AHI (0 min 27 sec)
My horizon won't set it seems....
Gree is offline Find More Posts by Gree
Old Aug 05, 2012, 05:30 AM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
You are doing it in the air with power on, try in the air with power off or better still on the ground
MrBen. is offline Find More Posts by MrBen.
Old Aug 05, 2012, 06:43 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
I do it on the ground as well several times with no motor on. Same thing, the horizon just stays low and doesn't align.
Old Aug 05, 2012, 07:48 AM
dayanki is offline
Find More Posts by dayanki
dayanki's Avatar
Joined Dec 2010
In the Main Menu page 1/4, set FPM Position Adjust to lift the position of the horizon. With the plane on the ground and leveled set neutral AHI (page 1/3 In Flight Menu)
dayanki is offline Find More Posts by dayanki
Old Aug 05, 2012, 10:28 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Originally Posted by RUBNorris View Post
ok I'll give it a shot when i get back. (my router just died)
Also my motor keeps beeping and will not throttle up, so im guessing i have no signal. Everything else works but motor. kinda funny?
Does the screen say Receiver not detected?
Have you got throttle channel reversed? Or correctly assigned ?
ommadawn is offline Find More Posts by ommadawn
Old Aug 05, 2012, 01:20 PM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
Thanks Vova!
Initial test indicate OSD is working properly. Appreciate the 1 day repair turnaround and free service. The vibration meters work now too, I thought that was a firmware issue did you reflash firmware? still says 5.07 or was it related to the missing L9-L10 whatevers?
I can recommend Range Video and will look first to you for my future equipment purchases. Any Idea when RVGS will be avail?
Thanks!
picard10th is offline Find More Posts by picard10th
Old Aug 05, 2012, 01:48 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
Do it on ground, pitch the aircraft up the desired amount. Set neutrals, save configuration. Turn Off the OSD, then turn ON, make sure the airplane do not move during the first 30 seconds.
Old Aug 05, 2012, 02:34 PM
Joined Apr 2012
How important is it to place rvosd horizontally in the fuselage? Is it sensitive OR can i calibrate it?
Old Aug 05, 2012, 05:45 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
The software can reverse the pcb front-rear, and roll to 90-180-270
Old Aug 05, 2012, 06:07 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Thanks guys will try all those things again, although I am sure I have done them all already.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 10:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 11:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 05:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 01:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 03:51 AM
