Old Jul 12, 2011, 10:41 AM
imdone is offline
Find More Posts by imdone
imdone's Avatar
United States, WA, Seattle
Joined May 2011
just to be clear...the RSVODV5 will show both main and aux battery voltages?
imdone is offline Find More Posts by imdone
Old Jul 12, 2011, 10:54 AM
datyip is offline
Find More Posts by datyip
Spain
Joined May 2011
Two questions:
1- The temperature value that OSD shows is outside temp? Where's the sensor located?
2- The angle in upper right screen is related to what?
thanks
datyip is offline Find More Posts by datyip
Old Jul 12, 2011, 10:59 AM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Yep.
BushmanLA is offline Find More Posts by BushmanLA
Old Jul 12, 2011, 11:01 AM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
Originally Posted by datyip View Post
Two questions:
thanks
1- Depends, it is internal temperature. But if the external probe is connected, sill display external temperature.
2- Angle between the airplane and the observer's(pilot) local horizon.
Elcheapo is offline Find More Posts by Elcheapo
Old Jul 12, 2011, 11:16 AM
imdone is offline
imdone's Avatar
Joined May 2011
How well does the fly by wire work?? Any videos from a flying wing?
Old Jul 12, 2011, 11:21 AM
BushmanLA's Avatar
Joined Dec 2005
Worked well enough for me.
I flicked it on and it was fairly easy to steer with rudder only. As stated above you do have to manage the throttle yourself. If you set it too low you slowly start losing alt. If you set it too high you tend to maintain alt but just fly a little faster.
I plan to test it further sometime this week. Will post vid.
Old Jul 12, 2011, 11:57 AM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
I think you are using FBW mode on RVOSD the same way you use any other stabilization system, and that's not the way it is supposed to work.
It is not like the autopilot use ailerons and elevator to level the plane while you steer with rudder.
The way it works is the autopilot will analyze your aileron and elevator inputs, setting pitch and roll angles proportional to stick deflections. So if you want to bank left you move aileron stick left, but the autopilot will actively keep the plane at the desired angle, so when stick is released the airplane will go back to level immediately. Max angles allowed for both pitch and roll are selected on the menu.
Old Jul 12, 2011, 12:08 PM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
This is a clip from my Maxie Swift with a Gen 4 RVOSD. I always fly with FBW engaged. The occasional turbulence is from thermal activity.
http://vimeo.com/16632294
Gary Evans is offline Find More Posts by Gary Evans
Old Jul 12, 2011, 12:37 PM
imdone is offline
imdone's Avatar
Joined May 2011
Is that stabilized by the IMU of the RVOSD5? That is what I'm most interested in
Old Jul 12, 2011, 12:50 PM
Mesa, Arizona
Joined Nov 2006
Gen 4 and under utilized FMA IR sensors. Gen 5 uses IMU's which are a better solution. The stabilization results seem the same to me. IMU's will work in a cloud where IR sensors will not.
With an unstable plane like most wings it reduces the work load while still giving you the control desired. I use FBW all of the time even on autostable planes because it takes care of wind gusts and thermal activity so your not constantly cranking the stick. If for whatever reason you want it off it is controlled switched by a radio switch.
Old Jul 12, 2011, 04:55 PM
BushmanLA's Avatar
Joined Dec 2005
I see what you are saying but that's pretty much what I want. I'm going to be using my camera to look down on the world. I don't want to have to worry about keeping my airplane flying. I just want to make slow lazy boat turns with my rudder while I look straight down.
I wish I didn't have to manage my throttle or elevator at all and it would manage my altitude for me, but that's not really too big a deal. I can set the throttle and just give a touch of elevator when I need it.
Old Jul 12, 2011, 05:10 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Bushman you will Love FBW. Its brilliant for thermalling. You just bank into the lift and sit back. It does all the work keeping the plane stable during gusts.
ommadawn is offline Find More Posts by ommadawn
Old Jul 12, 2011, 05:19 PM
johnorama is offline
Find More Posts by johnorama
UAV Dude KF7HYV
johnorama's Avatar
United States, NV, Silver Springs
Joined Mar 2007
and if you just crank the roll trim over a few clicks you can be hands-off while riding the thermals.
johnorama is offline Find More Posts by johnorama
Site Sponsor
Old Jul 12, 2011, 09:55 PM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
I will try this.
It will be interesting watching the video while rotating over a bumpy ride of a thermal uplift. Most of my flying is done with trimming with a FY stabilizer.
From what I have read the plane will react similar with FBW on the RVOSD.
I hope Borneobear will finish his UAV pilot instruction manual soon
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Jul 13, 2011, 01:29 AM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
'rvosd5 first osd with imu autopilot'
crashmeup, first person to fly fpv!
CrashMeUp is offline Find More Posts by CrashMeUp
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
