Old Jun 03, 2012, 02:43 PM
Thermicdude is offline
Find More Posts by Thermicdude
Still hackin'
Thermicdude's Avatar
Port Elizabeth, South Africa
Joined Nov 2005
Originally Posted by Blackrat View Post
new RV ?
Next step if you still offering
Thermicdude is offline Find More Posts by Thermicdude
Old Jun 04, 2012, 05:14 AM
Still hackin'
Joined Nov 2005
Originally Posted by mark hitchman View Post
Put a 68 ohm resistor between the video signal line and ground on the VTX side of the OSD. The signal level is too high when seeing all white.
You can try a 100 ohm resistor first and if that's not enough try a 68 ohm.
Mark
Thanks Mark, had done some serious googling and had come to pretty much the same conclusion - will try. Have you had a similar experience?
Aussie Pete is offline
Find More Posts by Aussie Pete
Aussie Pete's Avatar
Australia, SA, Adelaide
Joined May 2009
Try tilting the camera down more to see if the drop out still continues when looking mostly at the ground...less of the sky.
....Pete
Aussie Pete is offline Find More Posts by Aussie Pete
Old Jun 04, 2012, 05:22 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Could someone with a Skywalker and well functioning AP-settings chime in here? My Skywalker does return home but does left turns extremely slow. I've tried to increase turn angle and various other settings to almost no avail. It would be interesting to see what settings other use.
boopidoo is offline Find More Posts by boopidoo
Old Jun 04, 2012, 11:13 AM
cabster101 is offline
Find More Posts by cabster101
United States, TX, Austin
Joined Jul 2011
My skywalker works great but I have everything at default. It worked perfect the 1st try so I never had to change anything.
cabster101 is offline Find More Posts by cabster101
Old Jun 05, 2012, 04:13 AM
Nellik is offline
Find More Posts by Nellik
Australia, QLD, Brisbane
Joined Jul 2010
Two weeks ago I crashed the plane carrying my RVOSD. Today I finally finished the repairs and powered everything up. It all still works except for the current reading - it stays on 0.5A constantly. I removed the current sensor pin and measured the voltage while applying throttle and it never goes above 0.13V. So the question is, any idea whats causing this and is there a chance of fixing it or should I just order a new sensor?
Nellik is offline Find More Posts by Nellik
Old Jun 06, 2012, 12:27 PM
Bauf is offline
Find More Posts by Bauf
Norway
Joined Aug 2011
How do i set the rvosd5 to show 2 battery gauges, like the guy in this video have done?
TwinStar II FPV - 7.4km range test (9 min 49 sec)
mine only shows a gauge for the main battery, the aux battery only shows volts.
Bauf is offline Find More Posts by Bauf
Old Jun 06, 2012, 02:16 PM
Joined Jul 2011
He is using old firmware. It was removed from the new firmware to clean up the view.
http://www.youtube.com/watch?v=rmCYYkehYrI&feature
Old Jun 06, 2012, 04:26 PM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
probably best just to buy a new one unless you can see someplace that just needs resoldering.
BushmanLA is offline Find More Posts by BushmanLA
Old Jun 06, 2012, 04:53 PM
Acorns is offline
Find More Posts by Acorns
United States, IA, Mason City
Joined Oct 2008
Originally Posted by Elcheapo View Post
And on top of this the ESC I use will cut motor power if it detect the motor is stuck.
I think this is why it isn't a high priority :/ I'd just like to jump in and note that I would love this feature as well (configurable on/off is fine!). My ESC's apparently don't shut off, and every plane I have had the RVOSD on has sat on the ground trying to spin the motor at one time or another.
Seems like the conditions are already watched for - the end of flight display screen conditions - and I've only seen those pop up once while in flight, and then only for half a second.
Setting cruise and glide to 0 is a good idea, but only doable if you have plenty of time to jump into the menu and set them.
Acorns is offline Find More Posts by Acorns
Old Jun 07, 2012, 07:40 AM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
Flap integration question
Hi,
I'll be using cppm to drive aileron, rudder(camera pan), elevator and throttle through the RVOSD, but I'm unsure how I can connect my wing flaps or the tilt for the camera. any help would be great.
I'm using a Frsky V8R7SP receiver.
Cheers
matt
Psionic001 is offline Find More Posts by Psionic001
Old Jun 07, 2012, 07:17 PM
evo101 is offline
Find More Posts by evo101
evo101's Avatar
Australia
Joined Jun 2009
anyone see the new video using the upgraded AHI
Getting high, 4600mts FPV. (13 min 18 sec)
evo101 is offline Find More Posts by evo101
Old Jun 07, 2012, 10:24 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
Originally Posted by Psionic001 View Post
Hi,
Connect them direct to the receiver.
Elcheapo is offline Find More Posts by Elcheapo
Old Jun 07, 2012, 10:51 PM
Psionic001's Avatar
Joined Apr 2006
Thanks. I had assumed the rest of the Chanel outputs from the Rx were disabled.
My mistake.
ALSO... Will Rvosd ever have individual aileron tuning for fixed wing, or will it always operate via a Y-Lead?
Old Jun 07, 2012, 11:11 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
http://www.youtube.com/watch?v=Ar8mQ...&feature=g-u-u
That is a great flight he did.
Martin Y is online now Find More Posts by Martin Y
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
