Old May 26, 2012, 11:14 PM
gzmann is offline
Find More Posts by gzmann
Joined Aug 2007
Originally Posted by bakchos View Post
1st question : did you do the RC safety wizrard ?
if no, do it.
If yes, when asked for level flight, did you give cruise throttle of left throttle to zero ?
I did that mistake once.
Hello - thanks for the response
Yes - I did do the rc wizard and also set the cruise throttle at the same time
When the RTH function was started, the throttle went to the required setting -- it was just the sharp right turn that was the problem
gzmann is offline Find More Posts by gzmann
Old May 27, 2012, 02:48 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Originally Posted by CN I Dawg View Post
Did you precisely balance the prop using a magnetic balancer? The prop, of course, is the main source of vibration. There is some vibration caused by turbulence but usually very little. Also, try varying your throttle setting. The vibration at different RPM's can be dramatically different.
Best,
Steven
The two blades of my folding prop have exactly the same weight on the balance. So are balanced. In all RPM low or high the vibration in flight are at full scale.
if no, do it.
Yes i do the RC wizard. For Level Flight I give cruise throttle.
I think the problem is caused by RVOSD contact with other elements inside Zephyr bay. I think this amplifies the vibrations. Do not believe ?
IMEIV is offline Find More Posts by IMEIV
Old May 27, 2012, 03:54 AM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
Why dont you hold down the plane, give it full throttle and put your finger onto the RVOSD unit and feel for vibrations?
Stunt Double is offline Find More Posts by Stunt Double
Old May 27, 2012, 05:17 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
On the ground vibrations are a little less at low values but at full throttle they always reach full scale.
Old May 27, 2012, 08:00 AM
CN I Dawg is online now
Find More Posts by CN I Dawg
Crash=start of next project
CN I Dawg's Avatar
Joined Nov 2010
I think the problem is caused by RVOSD contact with other elements inside Zephyr bay. I think this amplifies the vibrations. Do not believe ?[/QUOTE]
Yes, it is possible you are at a point in the Zephyr cavity that's at resonance, thus actually amplifying the vibration amplitude. You can try moving to a different location, try a different dampening material or some have had luck with weighing down or compressing the RVOSD. Hope you sort it out soon.
CN I Dawg is online now Find More Posts by CN I Dawg
Old May 27, 2012, 12:52 PM
gzmann is offline
Joined Aug 2007
I think there are/were 2 questions going on at the same time here
I was asking about the problem with my RVOSD always wanting to go right and up everytime I engage RTH
Anything I might be able to do?
Old May 28, 2012, 12:24 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
I think the video below can tell more than 1000 words.
You can see three Level Flight test, one vibration test in flight and one on the ground.
Sorry for quality.. I uploaded the video in the shortest possible time..
http://vimeo.com/42940473
Old May 28, 2012, 03:59 AM
HF_ATL is offline
Find More Posts by HF_ATL
Portugal
Joined Nov 2009
Your AHI is not well calibrated. Set properly neutral AHI procedure on the ground with motor off.
HF_ATL is offline Find More Posts by HF_ATL
Old May 28, 2012, 05:17 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Wow, I've seen the vibration graphs so maxed out (0:50).
boopidoo is offline Find More Posts by boopidoo
Old May 28, 2012, 07:05 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
I set AHI neutral first time on the ground and second time in air but nothing change in Level Flight...
Do you saw the vibrations ? ... they are a lot. I think this is the problem.
Though I set neutral AHI with high vibration I suppose that AHI drift right or left..
Old May 28, 2012, 08:18 AM
HF_ATL is offline
Portugal
Joined Nov 2009
Set cruise and glide throttle to idle and set again neutral AHI on the ground with motor off.
Remember to save configuration.
Then, try again the level flight mode at high altitude. Now you can eliminate (or not) the vibration variable.
Old May 28, 2012, 11:07 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
I just try to set neutral AHI on the ground with motor off but when I go in flight.. however with controlled flight or autopilot... the AHI drift left or right.
You can see in the video..
Old May 28, 2012, 01:24 PM
CN I Dawg's Avatar
Joined Nov 2010
[QUOTE=IMEIV;21733555]I just try to set neutral AHI on the ground with motor off but when I go in flight.. however with controlled flight or autopilot... the AHI drift left or right.
Is there anyway the RVOSD could be shifting position once in flight? Your vibration is quite high on X and Z axis. You can concentrate there. El Cheapo would have to weigh in on your vib levels being capable of over driving the rest of the electronics.
Old May 28, 2012, 04:57 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
If the vibrations are upsetting the IMU, when the motor is stopped the AHI settles down by itself after a short time. Have you tried getting up some altitude and letting the plane glide for a minute or 2? The AHI should correct itself if the vibes are the cause of the problem.
ommadawn is offline Find More Posts by ommadawn
Old May 28, 2012, 06:19 PM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
[QUOTE=CN I Dawg;21734566]
You mean that RVOSD it's not fixed properly inside the plane and it moves once in flight ?
No but I will try. thanks for the advice
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
