Old May 23, 2012, 03:10 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
I always take off and do the whole flight with FBW on.
The only thing to remember is it is sensitive to vibration, so if you are taking off from wheels then the ground roll can upset the IMU if there is significant vibes. Hand launching is sweet.
This clip was hands off in 20Kts. Didn't touch the sticks until she was up and away.
Hands off slope launch of the BigAss (0 min 47 sec)
ommadawn is offline Find More Posts by ommadawn
Old May 23, 2012, 03:57 AM
mr.utopia is offline
Find More Posts by mr.utopia
mr.utopia's Avatar
Latvia, Riga
Joined Feb 2010
On my radio I have set up "launch mode" that pitches the plane up. Altogether with FBW my launches are good every time. Just have to remember to test if baro, AHI and GPS work correctly before each flight.
mr.utopia is offline Find More Posts by mr.utopia
Old May 23, 2012, 04:09 AM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
Originally Posted by superevan View Post
Awesome bakchos, thanks for posting your video. So overall do you feel comfortable launching with fbw on every time or just when conditions aren't the best?
i use it all the time.
bakchos is offline Find More Posts by bakchos
Old May 24, 2012, 01:14 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Originally Posted by Firatp View Post
Hi,
I have the same receiver.
Hi,
today I finish to built an FPV setup on an ICON A5 plane. I connected my second RangeVideoOSD5 and all its components. I power RVOSD5 and it works good except for a big problem... I can not bind the TFRSP FrSky CPPM receiver http://www.frsky-rc.com/ShowProducts.asp?id=80
The procedure is:
- I connect a separate battery (12V 1000mAh) to RVOSD5. I can see the pictures and RVOSD works.
- Then I connect the main battery to the current sensor.
- Then I switch on the bec to feed servos and receiver.
- I Set the R/C receiver connected (Main 4/4) menu item to Yes.
- I set PPM combined signal (Main 4/4)
- I go in PPM configuration menu but no signal moves and when I make Bind procedure pressing receiver’s F/S button unfortunately I do not get any success. And the receiver is disconnected from the radio.
I use a FUTUBA T12FGA radio with TM-14 module.
Please, help I made. I made numerous attempts but now I do not know what to do... I think that the problem is only between Radio Transmitter and receiver.
IMEIV is offline Find More Posts by IMEIV
Old May 24, 2012, 01:55 AM
ivers is offline
Find More Posts by ivers
Norway, Ostfold, Askim
Joined Apr 2012
So its just to solder a 20k ohm resistor between the dragonlink and rvosd rssi signal cable?
ivers is offline Find More Posts by ivers
Old May 24, 2012, 04:59 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Originally Posted by IMEIV View Post
Hi,
The procedure is:
- I go in PPM configuration menu but no signal moves and when I make Bind procedure pressing receiverís F/S button unfortunately I do not get any success. And the receiver is disconnected from the radio.
If you think that the problem is between the TXand RX why add all the other equipment? It only makes it much harder to search for error .To make things simple try again to bind TX/RX but skip all the RVOSD equipment. Just add a rx-battery and a servo to the Frsky RX and try again.
boopidoo is offline Find More Posts by boopidoo
Old May 24, 2012, 09:18 AM
ecampos is offline
Find More Posts by ecampos
FPVEEE ED
ecampos's Avatar
Quebec, Canada
Joined Jul 2010
Someone looking for a RVOSD5 ? Here:
http://www.rcgroups.com/forums/showthread.php?t=1658379
ecampos is offline Find More Posts by ecampos
Old May 24, 2012, 09:20 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Problem solved. Thanks.
Old May 24, 2012, 10:01 AM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
Wow, I never see these things in time..thanks a ton for pointing it out. PMed him.
idletime is offline Find More Posts by idletime
Old May 24, 2012, 06:22 PM
evo101 is online now
Find More Posts by evo101
evo101's Avatar
Australia
Joined Jun 2009
have you guys seen the New AHI in development, WOW!! now it really looks like an f16 hud
Artificial horizon, F16 style HUD (0 min 41 sec)
evo101 is online now Find More Posts by evo101
Old May 24, 2012, 06:37 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
After watching the Fly-by-wire launch videos it got me thinking. Has anyone launched in RTH, Level Flight or Heading Hold mode? It would be a cool trick to leave your radio sitting on the ground, pick up the plane, toss it into the sky, then casually walk back to the ground station and take over control when comfortable.
Stunt Double is offline Find More Posts by Stunt Double
Old May 24, 2012, 06:43 PM
evo101's Avatar
Australia
Joined Jun 2009
I always launch my plane in RTH mode I just launch it into the air and it climbs up to my set altitude and circles above me while I put my goggles on etc, then all i have to do is switch on my controler and then im in control
Old May 24, 2012, 11:01 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
http://www.youtube.com/watch?v=Z08cT...&feature=g-u-u
Is the firmware published or is this still test video?
Firatp is offline Find More Posts by Firatp
Old May 25, 2012, 03:09 AM
HF_ATL is online now
Find More Posts by HF_ATL
Portugal
Joined Nov 2009
Test video
HF_ATL is online now Find More Posts by HF_ATL
Old May 25, 2012, 04:33 AM
ommadawn is offline
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
What do the extra lines indicate?
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
