Old May 18, 2012, 01:20 AM
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Originally Posted by IMEIV View Post
Yes I understand that the distances are on the air but I was wondering if you had done a distance test on the ground in Low Power mode...
No, not ground test with low power mode.
Firatp is offline Find More Posts by Firatp
Old May 18, 2012, 08:34 AM
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
I made this test when I make the first flight of a new FPV airplane to learn more about how far I can get.
IMEIV is offline Find More Posts by IMEIV
Old May 21, 2012, 04:24 PM
IMEIV's Avatar
Joined Apr 2009
Please, can someone explain me why it's necessay a resistor 100 kilo ohms on yellow cable of the rssi signal ?
Old May 21, 2012, 04:48 PM
Norway
Joined Aug 2011
i was told to use between 10-100k ohm, so i went with a 22k ohm..
have no clue why its necessary.
Bauf is offline Find More Posts by Bauf
Old May 21, 2012, 07:13 PM
Portugal
Joined Nov 2009
The resistor protect RVOSD input - RSSI analog input on RVOSD is not buffered. Without it, any voltage spike above 3.3V could kill the RVOSD main board MCU.
HF_ATL is offline Find More Posts by HF_ATL
Old May 21, 2012, 08:41 PM
2Vision-Air
bakchos's Avatar
Blainville, Quebec, Canada
Joined Aug 2009
Hey guys, i made a quick clip of my RTH, it was ok on my skywalker but since i have it on my wing, i have a strange problem, it works and get my plane over me but the throttle is on and off in short burst, i have redone the wizard before this flight and get the same result, i have the throttle around at 50% when asking level flight, is this ok or should i ignore the throttle on this step of the wizard ?
Watch that clip, btw never mind the shaking, it was 60+ km/h winds today !
Return to home problem RVOSD G5 (0 min 50 sec)
bakchos is online now Find More Posts by bakchos
Old May 22, 2012, 12:54 AM
IMEIV's Avatar
Joined Apr 2009
Yes but the red cable is disconnected so I don't understand why a spike above 3.3V could kill the RVOSD.. The only cables connected are black and yellow ?
Old May 22, 2012, 01:12 AM
IMEIV's Avatar
Joined Apr 2009
I use a FrSky receiver 8ch and to obtain the rssi signal I put this electronic modules by Mieciu http://uav.org.pl/index.php?page=sho...id=105&lang=en
I can see on Mieciu's electronic modules a couple of resistor.. So do you think that in this case it's necessary another 10-100 kilo ohms resistor ?
Old May 22, 2012, 03:08 AM
Portugal
Joined Nov 2009
The signal wire carries the RSSI signal and is that signal that can have spikes above 3.3v, nothing to do with the power.
Old May 22, 2012, 03:59 AM
Norway
Joined Aug 2011
http://www.youtube.com/watch?v=kVgpc36f-wc
i see that the "return to home" text is flashing a little, i think you have the failsafe points to close. http://rangevideo.com/forum/showthre...n-progress-%29
maybe you need to adjust step 7. ?
i had that problem same problem,the return to home text was flickering, and the servos and motor went on and off.
Old May 22, 2012, 05:47 AM
IMEIV's Avatar
Joined Apr 2009
Ok thanks.
Old May 22, 2012, 08:25 PM
superevan's Avatar
United States, TX, Austin
Joined Aug 2007
Does anybody have any experience or videos of launching with RVOSD stabilization on?
I've found some with FY-31ap and Ruby, but not RV.
superevan is offline Find More Posts by superevan
Old May 22, 2012, 08:28 PM
2Vision-Air
bakchos's Avatar
Joined Aug 2009
i have, let me upload the take off
Old May 22, 2012, 08:36 PM
2Vision-Air
bakchos's Avatar
Joined Aug 2009
there you go, that take off is with Fly By Wire.
fly by wire (0 min 15 sec)
The shaking is because of the 60km/h winds, i always take off with FBW, that way you only have to worry about the elevator.
Old May 22, 2012, 10:48 PM
superevan's Avatar
Joined Aug 2007
Awesome bakchos, thanks for posting your video. So overall do you feel comfortable launching with fbw on every time or just when conditions aren't the best?
Discussion Maiden Reports 12345 Arizona Model Aviators 466 Apr 23, 2013 06:29 PM
Help! RVOSD thermal sensors rcmonster99 Video Piloting (FPV/RPV) 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
