Old May 04, 2012, 04:08 AM
ommadawn is online now
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
A sign of vibration is the AHI diverging from level by itself.
Try turning down the stabilization gains a bit. Also increase your maximum angles. The defaults are very conservative. I turned my max climb to 45 and max bank to 60.
Cheers
Frank
ommadawn is online now Find More Posts by ommadawn
Old May 04, 2012, 08:06 AM
Macattaka is offline
Find More Posts by Macattaka
Beyond the BlackStump
Macattaka's Avatar
Australia, SA, Adelaide
Joined Mar 2006
I've turned up the max roll/pitch angles to a point where I'm happy with them now, 50 pitch & 60 roll from memory (I should put pitch at 90 given how this thing can climb as you found out Frank) What I'm seeing in the video is a rocking motion about the roll axis as I'm holding aileron over as opposed to a super smooth turn without FBW. I'll try the stab gains
Macattaka is offline Find More Posts by Macattaka
Old May 04, 2012, 08:31 AM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Try decreasing the stabilization roll gain until it stops.
Gary Evans is offline Find More Posts by Gary Evans
Old May 06, 2012, 01:38 AM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
Originally Posted by Pixturethis View Post
Are the rvosd's out of stock?
I order mine on the 27th, haven't heard anything from them.
I also ordered mine on the 27th, their website now shows out of stock however when I log into my account it shows it was shipped on the 3rd May Hopefully yours will too!
MrBen. is offline Find More Posts by MrBen.
Old May 06, 2012, 06:31 AM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Bixler with RVOSD 5 doing some autopilot mode testing ..
Testing RVOSD 5 autopilot (12 min 22 sec)
octane81 is offline Find More Posts by octane81
Old May 07, 2012, 04:48 AM
MrBen. is offline
Great Britain
MrBen.'s Avatar
Joined Dec 2008
Hey guys Im wiring my zep2 whilst waiting for rvosd to be delivered, can anyone clarify how many cables I need to run between my EZUHF rx and RVOSD? Im using servo wires running from out on the wing where the uhf rx will be to the centre compartment where rvosd will be and Im going to be using PPM & RSSI.
I think I need 2 cables for RSSI, how many for PPM? and whats the best way to power the RX? I have a Ubec if required so that would be another 2 wires. Can anyone clarify?
Thanks Ben
Old May 07, 2012, 07:03 PM
Pixturethis is offline
Find More Posts by Pixturethis
Pixturethis's Avatar
Wichita
Joined Dec 2008
Anyone have an idea which end is the battery end ? I don't use these, & will be making adaptors.
Description:
Marc
Pixturethis is offline Find More Posts by Pixturethis
Old May 07, 2012, 07:56 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
Marc
Here the battery end.
scrape is offline Find More Posts by scrape
Old May 07, 2012, 08:03 PM
Wichita
Joined Dec 2008
Thanks.
Old May 07, 2012, 08:20 PM
Wichita
Joined Dec 2008
Next question.
Can I only connect the battery to the current sensor & not have a esc on the other end. I'm using this on a gas plane,
No esc.
Old May 07, 2012, 08:29 PM
reznikvova is offline
Find More Posts by reznikvova
reznikvova's Avatar
Miami
Joined Dec 2001
Next question.
No esc.
You don' need to use the current sensor.
Just connect the battery directly to Aux bat input on RVOSD.
Best
Vova
reznikvova is offline Find More Posts by reznikvova
Site Sponsor
Old May 07, 2012, 09:38 PM
Wichita
Joined Dec 2008
Thanks. Great.
Old May 07, 2012, 09:57 PM
Wichita
Joined Dec 2008
I'm not getting video. I have the VTX in the video out, camera in video in & 3s battery in the Aux input. Also have the main battery disabled.
I'm I missing something ?
Old May 07, 2012, 09:59 PM
Wichita
Joined Dec 2008
Description:
Old May 07, 2012, 10:02 PM
Wichita
Joined Dec 2008
Camera & VTX are 12volt.
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 10:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 11:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 05:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 01:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 03:51 AM
