Espritmodel.com Heli Air
Old Mar 16, 2012, 04:50 AM
Joined Jul 2010
Ground speed < some threshold
AND
Distance < some threshold
AND
Height < some threshold THEN MOTOR OFF
just my two cents.
3frcg is offline Find More Posts by 3frcg
Old Mar 16, 2012, 08:50 AM
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Originally Posted by IMEIV View Post
Two days ago AHI of my RVOSD5 gave me some problems. During a short flight AHI began to malfunction. I landed immediately and I did some tests that you find in the video below. You will see that the AHI sometimes turns on itself, turn upside down and sometimes is blocked. You will see that I set Neural AHI several times but nothing. I have connected battery in RVOSD first and then battery in current sensor. I make the tests both with rx frsky connected and disconnected and RV board is oriented correctly. I think there is a malfunction and maybe it is better that I send RVOSD to you for a repair. My RVOSD5 is one of the first ordered on 06/23/2011.
My RVOSD5 is one of the first ordered on 06/23/2011 with order 14144.
I just try to Contact Range Video support two times with contact page form but no response came. Please reply to me with some indications on returns because I would like to repaire RVOSD and restart to fly... thank
Here you can find the video:
http://vimeo.com/38508064
Replace the top board.
ommadawn is offline Find More Posts by ommadawn
Old Mar 16, 2012, 09:31 AM
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Do you mean that I have to replace with this ? http://www.rangevideo.com/index.php?...roducts_id=259
But maybe just a repair ?.. and perhaps it is better that RV check the two boards. Anyway I'm a fan of Range Video OSD and one of the first owner of the GEN5 but now I'm a little disappointed because from two days none reply from Range Video support.
IMEIV is offline Find More Posts by IMEIV
Old Mar 16, 2012, 10:19 AM
2Vision-Air
bakchos's Avatar
Blainville, Quebec, Canada
Joined Aug 2009
Get ready to wait for a long time, in my opinion RVOSD is dead on my list...
bakchos is online now Find More Posts by bakchos
Old Mar 16, 2012, 11:34 AM
Joined Jul 2011
I had the exact same issue a few months back. Had to send it back to RV for repair. It took a little over a month to get it back. But it works great now.
cabster101 is offline Find More Posts by cabster101
Old Mar 16, 2012, 02:50 PM
Registered Loon
Blackrat's Avatar
Jeffreys Bay South Africa
Joined May 2006
i had the same problem ,
i changed the bearing in my motor and fitted a new balanced prop , problem solved
Blackrat is offline Find More Posts by Blackrat
Old Mar 16, 2012, 04:07 PM
Joined Jul 2011
His issue is not related to vibrations caused by an out of balance motor/prop. The motor isn't running. RV replaced my OSD when mine had this issue.
Old Mar 16, 2012, 06:07 PM
IMEIV's Avatar
Joined Apr 2009
Today Range Video support send me a new graph board. Great.. I hope to restart to fly soon and I can truly be considered satisfied of RV support. Thanks Vova and thanks Alex.
It's easy to replace the graph board ?
Old Mar 16, 2012, 07:07 PM
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
Plug n play.
You got spare clear plastic heatshrink?
Old Mar 17, 2012, 12:22 AM
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Plug n play.
Do you know a shop which sells wide clear plastic heat shrink to cover RVOSD? Thanks
Firatp is offline Find More Posts by Firatp
Old Mar 17, 2012, 10:50 AM
Start of next project = crash!
CN I Dawg's Avatar
SoCal
Joined Nov 2010
You can buy on ebay. I forget the size but search in this thread and you will find it. Also, you can carefully slit the old one off and put it back on with some Scotch Tape.
CN I Dawg is offline Find More Posts by CN I Dawg
Old Mar 17, 2012, 11:07 AM
IMEIV's Avatar
Joined Apr 2009
Plug n play.
Yes, Vova put heatshrink in the package also.
Old Mar 18, 2012, 03:25 PM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Regarding heat shrink tube, this one works great: http://www.ebay.com/itm/66MM-42MM-PV...item7914af59ba
boopidoo is offline Find More Posts by boopidoo
Old Mar 19, 2012, 11:54 AM
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
Heres my latest effort from Downunder. Its my latest platform, a 3.1m flying wing called BigAss. It carries 30,000mAh of 3s lipos. (6x 5000/3s).
Max distance 24km (15 miles). I engaged the RTH at about 12k out and was a passenger for the last leg of the flight. The autopilot tracked perfectly, right down to zero, and then orbited waiting for me. It was beautiful to see, like a cruise missile, or homing pigeon. At one stage I removed my goggles, put down the RC and walked 100m from the GS. I phoned the plane, and it responded with an SMS of its coordinates. I love this stuff.
Congratulations to Alex for a truly brilliant piece of software and hardware engineering.
Cheers
Frank
Tapanappa to Newland Head, South Australia. Flown with Dragon Link and RVOSD Gen 5 (11 min 3 sec)
Old Mar 19, 2012, 12:54 PM
superevan's Avatar
United States, TX, Austin
Joined Aug 2007
Quite an accomplishment, congrats! What exactly did you phone on your plane? Or do you have you planes full specs posted somewhere?
superevan is offline Find More Posts by superevan
Discussion Maiden Reports 12345 Arizona Model Aviators 466 Apr 23, 2013 06:29 PM
Help! RVOSD thermal sensors rcmonster99 Video Piloting (FPV/RPV) 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
