Yes, I will address this on the next patch. Quote:
If the plane crashes, its possible the motor or battery will disconnect anyway. If not, then I am happy to risk trashing a motor or esc or lipo. Its part of the cost of a crash. |
I can see the valid points from Ommadawn, Sharonx and vertcnc. It would have to be a user selectable option in the setup menu. I now see that a 0 speed trigger would be more practicle then a low altitude one. However as vertcnc suggested the plane's ground speed could be at 0 when travelling into a headwind. So, I think we would have to wait for a proper airspeed indicator and have it combined with the ground speed indicator.
So it would go like this:- When failsafe is activated and at some stage both air and ground speed are at 0, then the throttle would be cut. How does that sound? Have I missed something? |
I agree that user should be able to have an option to set if RTH should automatically disable on certain conditions.
It would be great if RVOSD could register the crash (strong G force jump, rapid gyro change) and, if the altitude is low (below 20 meters), turn off motor. If registered movement speed is greater than 20 km/h after 5 seconds, enable RTH again. Also it would be nice if RTH did not engage if the plane has landed and user turns of a radio or looses connection with the plane. If IMU could register that landing was made, RTH failsafe should be disabled before the plane is launched again. It could look for the following parameters after landing is registered. * Constand ~1G force registered by accelerometer. * GPS movement speed is less than 5 km/h (if user picks up the plane and walks around) * Altitude is less than 5-20 meters (because of baro drift, low GPS altitude precision) |
My voice for disabling autopilot on the ground. GPS is not very good for checking this (it's not accurate), but there is accelerometer in RVOSDv5, so you can very easily check if the plane is in the ground or in the air.
No oscilations at all means the airplane is in the ground. If you've got good configured autopilot with failsafe it's pretty easy to make an accident - just turn off your radio before disconnecting the batteries in the airplane and you are pretty deep in troubles... |
Mesa, Arizona
Joined Nov 2006
An automatic throttle off function is only needed in RTH mode. The most important reason for the function is to prevent an accidental motor start on the ground either before or after flight. A secondary purpose could be to turn the motor off after a crash but IMO this should not be added if it interferes with normal operations.
The simplest approach may be to use the gps and or baro and not let the motor start in RTH mode unless the aircraft is x distance above the ground or x distance from home. Obviously it would have to be a big enough value to allow for the inaccuracy of the sensors and the baro may be the best choice for control since there is a chance of losing home position during flight. Either way the cut off should only be for throttle and RTH should not be disconnected if RC control is inactive. |
Hi,
I'm having an issue with servo noise/chatter when connected via RVOSD5. Servos are Inolab D750MG's going into a flying wing. I have tested the servos directly into DL rx and they they make the usual slight digi servo noise but once connected to RVOSD5 they become very noisy. I have tested with vtx connected and disconnected which makes no difference. I have tested some other slower digi servos and whilst not as evident as the Inolabs, there is still a difference in the centering chatter between no RVOSD and RVOSD connection. Any thoughts? Cheers, Al |
Not a sure fire answer, but this is basic procedure in my installations. I do not own an RVOSD5 at the moment. Next week I hope it's different story But this is what I have done on my other planes. FY21AP with digital servos for example.
Two days ago AHI of my RVOSD5 gave me some problems. During a short flight AHI began to malfunction. I landed immediately and I did some tests that you find in the video below. You will see that the AHI sometimes turns on itself, turn upside down and sometimes is blocked. You will see that I set Neural AHI several times but nothing. I have connected battery in RVOSD first and then battery in current sensor. I make the tests both with rx frsky connected and disconnected and RV board is oriented correctly. I think there is a malfunction and maybe it is better that I send RVOSD to you for a repair. My RVOSD5 is one of the first ordered on 06/23/2011.
My RVOSD5 is one of the first ordered on 06/23/2011 with order 14144. I just try to Contact Range Video support two times with contact page form but no response came. Please reply to me with some indications on returns because I would like to repaire RVOSD and restart to fly... thank Here you can find the video: http://vimeo.com/38508064 |
| Thread Tools | |
| Discussion Maiden Reports | 12345 | Arizona Model Aviators | 466 | Apr 23, 2013 06:29 PM |
| Help! RVOSD thermal sensors | rcmonster99 | Video Piloting (FPV/RPV) | 16 | Jun 20, 2011 10:21 AM |
| Discussion Weekend weather reports | neck | Arizona Model Aviators | 13 | Jun 10, 2011 04:59 PM |
| Discussion where are the Joe Nall horror "reports? | guy hanson | Radios | 49 | May 18, 2011 12:06 PM |
| Discussion Finally Fixed the Country Reports | daboz | Dynamic Soaring | 5 | May 16, 2011 02:51 AM |
