Old Jan 28, 2012, 11:38 PM
jeff2215 is offline
Find More Posts by jeff2215
jeff2215's Avatar
United States, MI
Joined Dec 2002
Originally Posted by cabster101 View Post
Setting up RSSI has nothing to do with getting RTH working. RTH, once configured properly, will work with or without having RSSI hooked up.
Well it must be causing some issues if my RTH quit working. Once I unplugged the RSSI input it was working again. Hence the resistor on the signal pins.
jeff2215 is offline Find More Posts by jeff2215
Old Jan 29, 2012, 06:48 AM
bakchos is online now
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
No it has nothing to do, its a coincidence, when you run the rc wizard, that's when it all get calibrated, so if you did not rerun the wizard thats why it was not working.
The resistor also helps your RX, it can drain power without it and causing problem/short range.
bakchos is online now Find More Posts by bakchos
Old Jan 29, 2012, 06:50 AM
2Vision-Air
bakchos's Avatar
Joined Aug 2009
anyone here using an LC filter with RVOSD ?
my ESC is very noisy and i am not sure where to place it, should it be after the current sensor -> osd or between the osd -> VTX ?
Old Jan 29, 2012, 07:49 AM
jeff2215 is offline
jeff2215's Avatar
United States, MI
Joined Dec 2002
I still think its causing the issue but that's not worth discussing :-)
So I'm assuming you still have to calibrate the RSSI. Can you just set the minimum RSSI by turning your tx off?
Also, the 10K resistor just gets soldered in the signal line then going from the rx rssi out to the temp/rssi in on the osd?
Old Jan 29, 2012, 08:04 AM
2Vision-Air
bakchos's Avatar
Joined Aug 2009
You can set the minimum but i think you should redo the wizard, you will be sure that 100% and minimum will be set at the same time.
And yes for the resistor.
Old Jan 29, 2012, 08:09 AM
jeff2215 is offline
jeff2215's Avatar
United States, MI
Joined Dec 2002
Will do. Thanks!
Old Jan 29, 2012, 09:13 AM
SLCPilot is offline
Find More Posts by SLCPilot
Stillwater, Oklahoma
Joined May 2004
Flew with the RVOSD autopilot for the first time yesterday. The plane is a Sig Rascal (40 size) with the camera on the bottom of the plane. The fly-by-wire and level flight modes worked really, really well! The RTH not so much.
What bank angle does should the RVOSD command after passing home? How quickly should the turn start? At what angle should the plane climb or descend? Does it climb or descend based on the input limits?
For what it's worth, it amazing what it does for the cost!
To the developers...PLEASE have a display feature that lets the pilot know what mode they're in all the time. Also, an option to control the display without using the right stick would be nice!
Cheers!
SLCPilot
SLCPilot is offline Find More Posts by SLCPilot
Old Jan 29, 2012, 09:22 AM
jeff2215 is offline
jeff2215's Avatar
United States, MI
Joined Dec 2002
I agree. It would be nice to know what mode your in. It only flashes briefly on the screen.
Old Jan 29, 2012, 12:23 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
The only mode that disappear from screen is the fly by wire mode, all the other modes will stay on screen. The reason for this is that I am not only a programmer, but I do also FPV.
I turn FBW ON from the very moment the plane take off, so is annoying having it on the screen, so I made it disappear after few seconds. However notice that you will see four dots blinking around the flight path mark(FPM) when regular FPM is selected, or two additional radials steady when smaller(default) FPM is selected.
And the plane on FBW mode is to much stable to be unnoticed.
Elcheapo is offline Find More Posts by Elcheapo
Old Jan 29, 2012, 10:12 PM
cabster101 is offline
Find More Posts by cabster101
United States, TX, Austin
Joined Jul 2011
Between the osd and VTX seems to work best for me.
cabster101 is offline Find More Posts by cabster101
Old Feb 02, 2012, 03:36 AM
Aussie Pete is offline
Find More Posts by Aussie Pete
Aussie Pete's Avatar
Australia, SA, Adelaide
Joined May 2009
Aussie Pete is offline Find More Posts by Aussie Pete
Old Feb 02, 2012, 04:12 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Hi Pete,
I havent looked at the whole thing yet as the web service is a bit slow here. Im on Koh Samui atm, just chillin.
Cant wait to get back and do some real flying.
ommadawn is offline Find More Posts by ommadawn
Old Feb 03, 2012, 03:08 AM
Phelec is offline
Find More Posts by Phelec
TBs are GO!....FAB....no..FPV!
Phelec's Avatar
Australia, NSW, Yamba
Joined Nov 2010
Can any one tell why the waypoint function for the OSD5 is "disabled for outside of the USA"?
By the way I am here at home "atm, just chillin".
Phelec is offline Find More Posts by Phelec
Old Feb 03, 2012, 03:11 AM
lrrps is online now
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Because everyone living outside the US is considered a potential terrorist.
lrrps is online now Find More Posts by lrrps
Old Feb 03, 2012, 07:52 PM
Phelec is offline
Phelec's Avatar
Joined Nov 2010
So, from this I understand it's ok to make some sort of guided (even destructive I guess)) flying object to go to a waypoint situated in the USA, but you are forbidden to do this outside of the US?
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
