Spain
Joined May 2011
As stated in the manual: ".... if you enter the autopilot submenu with any of the autopilot modes activated, on the autopilot menu screen the autopilot will switch to level flight, and resume the previous autopilot mode after leaving the menu screen. But some menus cant be changed if any stabilization mode is active."
does anyone knows what specific menus cant be changed if any stab mode is active? |
RVOSD can also accept PWM RSSI but has to be like the EZUHF output, this is exactly like a servo output but with pulse width proportional to RSSI level. Also it can get analog RSSI output from your Rx, but most 2.4Ghz receivers don't have that option. |
The thing is that changing autopilot settings with the autopilot already controlling the airplane is a delicate issue. |
Then I will select as RSSI input "Analog" and connect rssi plug to rssi/temp input port. Correct ? |
Straight from the horses mouth:
http://rangevideo.com/forum/showthre...0724#post20724 |
Maybe try this guy if you are quick (post 168)
http://rangevideo.com/forum/showthre...0753#post20753 |
Anyone have a diagram of how to hook a DL to OSD? I read through the posts here and it doesn't make any sense. I hooked it up according to manual and went into configurations and made sure its set to combined ppm and ppm1. My ESC is beeping at me, not happy :-)
Here is how I have it hooked up. All the servos go to their respective outputs on OSD. I have one wire running from CH 9 (PPM Ch) on DL to the PPM1 (Elevator input) on the OSD. What am I missing here? |
| Thread Tools | |
| Discussion Maiden Reports | 12345 | Arizona Model Aviators | 466 | Apr 23, 2013 06:29 PM |
| Help! RVOSD thermal sensors | rcmonster99 | Video Piloting (FPV/RPV) | 16 | Jun 20, 2011 10:21 AM |
| Discussion Weekend weather reports | neck | Arizona Model Aviators | 13 | Jun 10, 2011 04:59 PM |
| Discussion where are the Joe Nall horror "reports? | guy hanson | Radios | 49 | May 18, 2011 12:06 PM |
| Discussion Finally Fixed the Country Reports | daboz | Dynamic Soaring | 5 | May 16, 2011 02:51 AM |
