Espritmodel.com Heli Air
Old Jul 05, 2011, 10:58 AM
Elcheapo's Avatar
Joined Oct 2007
Originally Posted by imdone View Post
I was on the RV forum and was reading that some people were having to send their OSD's back because they where faulty. bad gyros and what not. I could be wrong though I didnt read too much into it.
debating on what osd route to go with. I ruled out eagletree(I think) Its either the RVOSDV5 or the EZosd with the ruby.
This is the first batch of a very complex hardware, we had few boards with hardware problems. But also notice that we are replacing them at no extra charge.
Elcheapo is offline Find More Posts by Elcheapo
Old Jul 05, 2011, 11:00 AM
Elcheapo's Avatar
Joined Oct 2007
Originally Posted by GliderLover View Post
my Gen5 has just landed .
i'm doing all cables etc. One question: i have 12v cam & tx and a 4s motor setup.
Does the 12v rail on Gen5 is regulated or not? If i hook a 4s setup on the video connector, do i burn anything?
You have to provide a 3S battery on the auxiliary battery input, and remove the main battery disable jumper. Remove the heat shrink and unplug the boards to do this.
Old Jul 05, 2011, 11:03 AM
Joined Apr 2008
Thanks.
Can you confirm that 5v for servos and rx is provided by a 5v internal regulator inside RV? (eventually can be disabled to use an external battery pack hooked on rx or RV servo ports?)
To end a long story can you provide a power supply scheme of the RV? (including jumpers function)
GliderLover is offline Find More Posts by GliderLover
Old Jul 05, 2011, 11:23 AM
Elcheapo's Avatar
Joined Oct 2007
No, the power to the servos and the receiver have to be provided by a separated BEC. RVOSD does not power them. All servo I/Os on the OSD have the Vcc and ground connected together.
Old Jul 05, 2011, 05:31 PM
Italia, Piemonte, Torino
Joined Jul 2009
http://vimeo.com/26025409
Neo360 is offline Find More Posts by Neo360
Old Jul 06, 2011, 05:40 AM
SX_
.........lost..........
Zambia, Lusaka, Lusaka
Joined Jun 2005
Mine finally arrived! i havent even opened the box.... im letting the anticipation build!!!!!!!!!! (or my finace to go so she doesnt see the prices) LOL!!!
Willie
SX_ is offline Find More Posts by SX_
Old Jul 08, 2011, 12:53 AM
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
I am having composite video pass through issues with the RVOSD.
The attached picture shows the video link bypassed. It works this way with a Vtx connection or a direct wire link. However passing it through the RVOSD there is no video. Simulation as if it was on a plane with ppm on the aux channel and using a ESC BEC did not make a difference either.
No smoke is let out of the gear.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Jul 08, 2011, 02:49 AM
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Willie
All my FPV gear has two prices - the real one, and the one I tell my wife
SpookiePower is offline Find More Posts by SpookiePower
Old Jul 08, 2011, 03:23 AM
SX_
Joined Jun 2005
yea as long as when somethng happens to me she doesnt sell everyhing for wat i told her it costs!
Old Jul 08, 2011, 03:47 AM
Joined Apr 2008
I have a similar issue (same setup, 900mhz): if i pass thru a calble (no tx-rx) everything works, but if i take video signal thru video tx-rx, i don't see any video. I can check tx is working because i have a mic hooked to tx and i can ear from it from the monitor. I changed cables and everything, next step i will try with a mate's gear,... or burn everything
Old Jul 08, 2011, 06:44 AM
avropilot's Avatar
USA, TN, Murfreesboro
Joined Dec 2009
It looks as if you have the video in video out reversed.
avropilot is offline Find More Posts by avropilot
Old Jul 08, 2011, 07:35 AM
reznikvova's Avatar
Miami
Joined Dec 2001
Blurry picture. But seems you have video tx connected to video camera without connecting to OSD
Video in on RVOSD goes to camera.
Video out on RVOSD goes to video tx.
Edit: realized this was a picture of the OSD bypassed.
Please post a picture connected through RVOSD.
reznikvova is offline Find More Posts by reznikvova
Site Sponsor
Old Jul 08, 2011, 10:01 PM
Joined Feb 2011
I sent the unit in for evaluation. The Video in is on the outside pins and out is the next one. Unless defining like some old stereo sound systems do where out goes to out and in means into the others in.
I have had a microwave rcvr chip zapped by a Post Office Xray scanner in the past. Such is a possibility.
http://answers.yahoo.com/question/in...9020452AADyo0b
Old Jul 08, 2011, 10:15 PM
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Still waiting for flight reports.
C'mon guys. How is this thing performing as a stabilizer??
borneobear is offline Find More Posts by borneobear
Old Jul 09, 2011, 03:53 AM
cadders's Avatar
Joined Jul 2004
It's great, and that's even with vibrations in all axis maxed out...I'm woking on that though.
Cadders
cadders is offline Find More Posts by cadders
Discussion Maiden Reports 12345 Arizona Model Aviators 466 Apr 23, 2013 06:29 PM
Help! RVOSD thermal sensors rcmonster99 Video Piloting (FPV/RPV) 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
