Old Jun 19, 2011, 09:04 AM
edwong3 is offline
Find More Posts by edwong3
edwong3's Avatar
Central Florida, USA
Joined Sep 2010
Turnigy 130 maH Size Compared To E-Flite 120 maH?
Are the dimensions of the Turnigy NanoTech 130 maH cells the same or close to the stock E-Flite 120 maH units? The reason I ask is that I am planning to buy some for my mCX2 and would like to know if I can push the Turnigy all the way in the battery mount just like the stock cells without interfering with the servo gears.
Anyone know?
Thanks in advance.
Ed
edwong3 is offline Find More Posts by edwong3
Old Jun 19, 2011, 10:44 PM
edwong3 is offline
edwong3's Avatar
Joined Sep 2010
Found it!
OK never mind guys. I found the measurements of these two different cells.
E-Flite 120 maH 14C
Length: 33.7 mm
Width: 11.2 mm
Height: 5.59 mm
Turnigy Nano Tech 130 maH 25C
Length: 39 mm
Width: 12 mm
Height: 7 mm
Seems like the Turnigy cell will be a bit of a tight fit but from what I read, it will slide into the mCX2's battery holder. It happens to be longer so I'm not still sure if I'll be able to slide it all the way into the battery holder without hitting the servo gears.
Honestly, E-Flite made a mistake with that design in that they could have either placed the servos just a little higher or made the molded plastic battery holder sit a little lower to avoid this issue.
Ed
Old Jun 19, 2011, 10:51 PM
papa38 is offline
Find More Posts by papa38
Recovering nitro addict
papa38's Avatar
Everett,Washington
Joined May 2005
I ran mine with a Thunder Power Prolite V2,160,but if you pushed it in too far,it would hit the servo gear.I just left like a 1/16" to the gear.Balance was fine,and I got probably a 10-12 minute flight out of it.$12 at my hobby store.This one.http://www.hobby-lobby.com/g4_pro_li...34182_prd1.htm
papa38 is offline Find More Posts by papa38
Sold E-flite 120 mah batteries outflying3d Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jun 10, 2011 03:39 PM
For Sale E-flite 120 SR/msr/ UM mosquito andresmirt Aircraft - Electric - Helis (FS/W) 13 Apr 15, 2011 10:36 PM
Sold Parkzone BF-109 w/E-Flite Power 25 $130, $115 shipped (electronics only) jpt1205 Aircraft - Electric - Power Systems (FS/W) 1 Mar 18, 2011 09:36 AM
Sold e-flite 4 port charger, ac adapter, and 4 120 mah Lipos skydve76 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Aug 02, 2010 11:06 AM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
