Old Jun 18, 2011, 04:38 PM
zanek is online now
Find More Posts by zanek
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
Question
How do you run the prop shaft through the hull
I am starting to build an RC boat, and I have been wondering about this. I have heard talk of a 'stuffing box'. What is that? Any pics?
Thanks, Zane
zanek is online now Find More Posts by zanek
Old Jun 18, 2011, 05:23 PM
ZZ56 is online now
Find More Posts by ZZ56
Nickel Belter
ZZ56's Avatar
Canada, MB, Winnipeg
Joined Jun 2009
A stuffing box is a chamber through which a shaft passes that is 'packed' with a material to stop liquid traveling through the box while still allowing the shaft to turn freely. Models use a stuffing tube consisting of a brass tube, bushed at both ends to the diameter of the shaft, that can be filled with grease or oil.
ZZ56 is online now Find More Posts by ZZ56
Old Jun 18, 2011, 06:31 PM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
I am a member of both these boards, both are great for different reasons. WMU has how-to's that we do not on this board, although this board is much much more active.
http://wmunderway.8m.com/cont/shaft/shaft.htm here is shafts/stuffing boxes
and here is the page for their construction tips http://wmunderway.8m.com/cont/cont.htm. Hope this helps, once you get some more specific questions either post on this thread or start a new one and you will get all the answers you will ever need.
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Jun 18, 2011, 07:45 PM
Mikedown is offline
Find More Posts by Mikedown
Closed Account
Joined Jul 2006
stuffing tube
I just remembered ;go to google and type in rc stuffing tube. Now it shows a Mutineer boat of which i still have 2 in prime shape.Now it shows steps and pictures. Pictures of your boat kind of shows a solid shaft from motor to transom. The Mutineer is using flex cable with loner to stop water entering up the stuffing tube.
Mikedown is offline Find More Posts by Mikedown
Old Jun 18, 2011, 08:32 PM
Apismelifera is offline
Find More Posts by Apismelifera
1/2 a bubble off
Apismelifera's Avatar
United States, NY, Schenectady
Joined Mar 2011
Have a look here, post #6.
http://www.rcgroups.com/forums/showthread.php?t=1282947
Apismelifera is offline Find More Posts by Apismelifera
Old Jun 18, 2011, 08:38 PM
zanek is online now
Agressive driver
Joined Jun 2011
Thank you guys for your help
Help! How do you balance a motor with prop installed ? zaguruinzasky Electric Motor Design and Construction 1 Jun 14, 2011 06:01 AM
Question How Do You Balance a Folding Prop Xptical Electric Sailplanes 11 May 30, 2011 06:36 AM
Discussion How Do You Determine Motor/Prop/ESC Combination? Av8Chuck Multirotor Talk 6 May 22, 2011 12:01 AM
Discussion How loose do you keep your folding prop? hog2soar Electric Sailplanes 4 May 13, 2011 11:56 PM
How do you fit a GWS SF prop to a Cobri Prop adapter/shaft? AdrianM 3D Flying 2 Mar 23, 2004 11:17 AM
