Old Jun 18, 2011, 11:45 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
SAPAC Gripen with HABU 32 80mm fan/motor
Just installed the HABU 32 80mm fan/motor in our Gripen. The stock setup was underpowered but this new fan makes it fly with authority. Not 1 to 1 thrust but plenty for scale flying. Guessing around 90mph speed in level flight. We have a thrust vectoring nozzle installed (SU34 Freewing type) which makes for some interesting maneuvers like flat spins! The outlet is a tad small for the 80mm fan but it seems to work fine. Balancing the 6S 5000mah pack requires the compartment opened up way back into the duct. An aluminum tray was added to hold the battery. You have to be creative to hold the battery from sliding forward. We used a stopper that velcro's in front of the battery. Flight times of 5 minutes are easy. The only mod planned next is to move the main landing gear closer to the CG to make take-off rotation easier. Now it seems to leap into the air and I want a more gentle rotation.
4stripes is offline Find More Posts by 4stripes
Old Jun 18, 2011, 11:55 AM
foamjet is offline
Find More Posts by foamjet
Joined Mar 2011
very nice gripen.
could you post more details, photos about
1/ what retracts, struts you use?
2/ some photos of the retracts's location?
3/ current draws?
4/ photos of lipos in the chamber...
video would be nice
thanks
foamjet is offline Find More Posts by foamjet
Reply With Quote  (Disabled)
Old Jun 18, 2011, 12:33 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Howdy Foamjet,
Here are some shots of the LG and TV. Don't have any battery shots as its buried deep in the rear of the cockpit. My father had the great idea of using thin walled tubing to open up the compartment aft. Just cut numerous holes until the opening fits. The aluminum tray was held in place with a block of light wood screwed with thin plastic wingbolts from the belly and countersunk wood screws from the tray side. The battery opening was kept tight around the battery to keep from moving upwards and the tray is bent up at the rear to keep the battery from sliding into the duct. The spring/air retracts were purchased from SAPAC and are well made. The 3mm wire may need upgrading to 4mm but it seems to work for now. The struts came with the Gripen kit.
Cheers
PS I should add that the HABU 32 80mm fan/motor were top quality and needed no balancing. Just assemble with locktite and run!
Old Jun 21, 2011, 05:22 PM
Ken Lilja is offline
Find More Posts by Ken Lilja
I'm slow but I'm expensive
Ken Lilja's Avatar
United States, GA, Snellville
Joined Nov 2003
I received my Gripen kit a couple of weeks ago and I just ordered this fan for it. I am glad the hear that I am on the right track.
Ken
Ken Lilja is offline Find More Posts by Ken Lilja
Old Jun 21, 2011, 05:59 PM
tweeter1 is offline
Find More Posts by tweeter1
Joined Feb 2011
the specs of this 80mm fan looks very impressive
Delta-V 32 80mm EDF Performance
Installed Data*
Installed Static Thrust: 4.50 lbs
RPM: 38,500
Watts: 1,400
Current: 62A
* Data measured installed in Habu 32 DF using BL32 DF Brushless Motor, 2150Kv & 6S 5000mAh 30C Battery
Static Data*
Static Thrust: 5.40 lb on 6S (21.9V)
RPM: 39,640 on 6S (21.9V)
Watts: 1,160 on 6S (21.9V)
Current: 53A on 6S (21.9V)
*Data measured in lab conditions using bell mouth intake and tail pipe measuring 159mm in length with 72.0mm exit diameter
tweeter1 is offline Find More Posts by tweeter1
Old Jun 21, 2011, 08:11 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Hi Ken,
You should plan on moving the main gear forward as well if you are using landing gear.
Moved the landing gear to about 1" behind the CG and takeoffs are now smooth and scale like. Better ground handling by far than stock position. Was able to just cut the plywood plates a new retract opening and shorten the legs about 3/4". The nose leg was replaced with a single wheel and it extends much better into the slipstream than the fat original two wheel setup.
Cheers
Old Jun 22, 2011, 01:12 AM
foamjet is offline
Joined Mar 2011
also if the the front landing gear is a little taller
than main gears, which creates a little high AOA,
that will help the jet taking off with shorter distance.
my two cents.
For Sale NIB Sapac Gripen JAs 39 splitpilot Aircraft - Electric - Jets (FS/W) 3 Oct 24, 2011 02:55 PM
Sold NIB delta 32 fan unit & 32 motor for habu 32 yf22raptor Aircraft - Electric - Jets (FS/W) 2 Apr 29, 2011 10:23 AM
Wanted Sapac Viper MKII with Fan / Motor or air frame only yf22raptor Aircraft - Electric - Jets (FS/W) 1 Apr 21, 2011 09:47 AM
Sold ** HABU Eflite Delta-V 15 EDF Unit with Eflite BL-15 3200kv Motor ** $60! Sammy70 Aircraft - Electric - Power Systems (FS/W) 0 Mar 05, 2011 11:18 AM
Sold NIB Sapac JAS-39 Gripen W/ Motor and Fan **Price lowered** AndyTheLegend Aircraft - Electric - Jets (FS/W) 4 Oct 14, 2009 08:25 PM
