Old Jun 18, 2011, 09:37 AM
flyingmonkey87 is offline
Find More Posts by flyingmonkey87
Joined Jun 2011
Problems binding DX6i to AR600
I have been meaning to get an answer on this for a while but have been traveling quite a bit lately.
I purchased a Airfield SkyTrainer 182 last year and enjoyed the flying characteristics. I landed it hard one day and haven't flown it since because the nosegear and firewall were in pieces.
I now want to use it as a test platform, but now nothing seems to work. The battery inflated like a balloon so I replaced it with a similar one from HobbyTown USA. After plugging it in, I was still unable to get it to work, so I purchased a new receiver and I used a DX6i that came with another aircraft. I tried several times to bind using the instructions in the manual but the orange LED never changed.
Is it possible the bad battery fried the ESC?
Am I completely missing something?
On a different matter, where do I dispose of bad LiPo battery's?
flyingmonkey87 is offline Find More Posts by flyingmonkey87
Old Jun 18, 2011, 11:15 AM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Canada, ON, Ayr
Joined Apr 2010
If you are getting the flashing orange LED on the RX (indicates bind mode), then the ESC might be OK.
A few suggestions:
1) Make sure you have the bind plug installed on the Bat/Data port.
2) Move the TX further away. You may get interference if the TX is too close.
3) Make sure the TX is going into bind mode as indicated on the display.
4) Disconnect everything from the RX and use an external 4AA pack (4.8V) to power the RX.
There are a few threads on this. The method I generally use:
1) Assuming the lipo is not physically damaged, discharge the battery fully. Use a car light bulb wired in series with the lipo.
2) Once discharged, strip the battery leads and short them together.
3) A lipo battery is actually fairly environmentally friendly unlike Ni-cd and Ni-mh.. You can discard in the trash if you wish. Alternatively, places like Home Depot will recycle batteries.
philipa_240sx is offline Find More Posts by philipa_240sx
Old Jun 18, 2011, 11:27 AM
Joined Jun 2011
I will try your suggestions. How far away should the Tx be from the Rx? I read that and I tried holding the Rx about 3-4 feet away.
Old Jun 20, 2011, 05:32 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
3-4 ft away is good...
freechip is offline Find More Posts by freechip
Old Jul 10, 2011, 11:08 AM
Joined Jun 2011
Ok the orange ESC is solid and is not flashing and there is a solid red light also. What does this mean?
Old Jul 14, 2011, 01:29 PM
Joined Jun 2011
There is also a red solid LED on.
Old Jul 14, 2011, 02:19 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Hold Indicator
The AR600 features a red LED (labeled H). This LED indicates the number of holds that have occurred since the receiver was last powered on. The LED will flash the number of holds then pause (e.g., flash, flash, flash, pause flash, flash, flash, pause) This indicates three holds. Note that holds are reset to zero when the receiver is turned off
Old Jul 14, 2011, 02:29 PM
Kambalunga is online now
Find More Posts by Kambalunga
Kambalunga's Avatar
Deutschland, Hessen, LA
Joined Jan 2009
Wrong polarity?
I think he has the ESC plugged in the wrong direction.
Kambalunga is online now Find More Posts by Kambalunga
Discussion Major problems with DX6i and BNF ar600's ??? herostratus Radios 32 Oct 14, 2012 06:38 PM
Discussion Binding DX6I tx (DSMX) with AR600 rx. vrider Electric Plane Talk 21 Apr 18, 2011 04:59 PM
Help! Problems binding DX6i to UM P-51 nathandarby67 Micro Ready-to-Fly 4 Mar 15, 2011 09:51 PM
Help! DX6i / AR6100 binding problems dvincent Radios 4 Oct 31, 2008 09:42 PM
