Hi
Here is a link to dc motor math model formulas. But only in German available. http://www.powercroco.de/Modellierung-Theorie2.doc Best regards Micha |
Louis,
Seems like I was tired when I wrote the formula! I should have wrote (Ri+a.rpm).I instead of (Ri+a.rpm.I) : rpm = kv * (U - ( Ri+a.rpm).I ) and Pout = ( rpm/kv ) * ( I - Io[rpm] ) But! a.rpm.I in this model is the voltage drop due to inductance... which I've called L in the other model (stupidly because of confusion with inductance L !). L[rpm] just means that, in this model, L is function of rpm... I've wrote rpm/kv because it's shorter than U-Ri.I-L[rpm], this is what is sometime called back EMF I guess, and written U-R.I. I know it isn't all exact and very "science looking", but easy to use and accurate enough to have a good idea of the torque when the prop is near the peak efficiency domain (at this point, small measurement errors can have big effects on the calculated efficiency). BTW, interesting things on this paper (2.3.3 Why Control is Necessary: Motor Inductance): http://web.mit.edu/scolton/www/SCThG.pdf and the author's blog: http://scolton.blogspot.com/ You may know it already? Micha, thanks for sharing this file! I think that any good drive model can use props data from wind tunnel tests as long as it shows well the main effects. Propcalc is not based on props tests but on airfoils tests and props geometry but in fact it goes in the same direction. I don't understand why there is no software using those data with an electric motor model. Is there any? |
Hi yomgui
model in flight is very hard. You must solv iterative a lot of equations. My father has written a program in tcl/tk with a matlab interface. But due to the complexity of system, sometimes the results are imaginary, not solvable. My father has used propeller formulas from http://www.mh-aerotools.de. But anyway, it is an interesting scope. We are flying mostly powered gliders, so it is very important to have an efficient drive chain, adapted to the glider. Our goal is to achieve a good (max) altitude with a given battery energy. Best regards Micha |
There is a difference if you consider a) Overall formulas in steady state at the ESC input (Vbatt, I averaged, rpm..) given a hardware ESC b) or "transitory states" inside one "electrical cycle" and six steps sub cycle when you are designing a PM-BLDC controler In case b) inductance is important to consider (with the term L di/dt) In case a) L is of no importance and the "classical formulas" : rpm = Kv * (V - Rm I) Kv = rpmo / (V - Rm Io) @ no load are quite valid but Rm is a function of copper temperature Louis |
| Thread Tools | |
| Mini-Review Turbo Ace 915 V2 9g Motor with Pictures, Video, Flight Tests, and Thrust Tests | Tom Z | Micro Helis | 96 | Aug 12, 2011 07:48 PM |
| Wind Tunnel Smoke | zagisrule! | Power Systems | 22 | Oct 19, 2008 12:54 PM |
| Question Wind Tunnel for kiteboarding tests? | DougE | Sailplane Talk | 1 | Jan 16, 2008 03:42 PM |
| Discussion Wind Tunnel Tests | Aphorism's Dream | Ornithopters | 0 | Apr 30, 2007 11:36 AM |
| sources of wind tunnel pics | Tim Green | Modeling Science | 0 | Feb 10, 2003 07:29 PM |
