Old Jun 18, 2011, 08:03 AM
yomgui is offline
Find More Posts by yomgui
Joined Feb 2011
Propeller wind tunnel tests
Hi,
I’m the happy owner of a DIY wind tunnel for propellers tests. This allowed me to make thrust and power consumption measurements of props up to 9 or 10 inch diameter, at speeds up to 16 – 17 m/s. I’m just doing this because it’s an interesting challenge, but I guess this might be useful for designers…
In order to share my results I was thinking of a useful and easy way to present them.
So the question is “what do you think would be interesting to know about prop’s behavior in flight?”
and how can such data help in choosing the right prop for a given drive and airplane…
I can make an excel sheet that can simulate a drive quite well, giving amps, thrust and rpm figures at increased speed (see the pics).
Or many others calculated values…
This needs so much factors that it’s impossible to assume it really shows what would happen in flight, but it’s still a good illustration…
More, the way I get the prop’s data should be discussed and compared with other testers…
So, what do you think about all this?
yomgui is offline Find More Posts by yomgui
Reply With Quote  (Disabled)
Old Jun 18, 2011, 03:40 PM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
Nice work!
Many have been waiting for years for this type of data.
The curves below demonstrate what NACA does.
One interesting data point is the Zero Thrust Speed.
From this it is possible to calculate the true pitch of the prop.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Jun 18, 2011, 06:21 PM
yomgui is offline
Joined Feb 2011
Hi Martyn,
Which report is that? one from the 20s ? I love those stuff from the NACA… Reports #73 and #98 helped me a lot while I was building the wind tunnel, they’re from back in 1919…!
Here’s some pictures of what I have for an APC 10x6E, it’s very close to the one quoted “P/D = 0.6” on your graph.
At higher P/D it differs a bit, due to Reynolds I think, and prop shape. Also my airspeed measurement might be slightly higher than the actual airspeed at the prop in the test room.
Old Jun 18, 2011, 06:30 PM
Toronto Canada
Joined Dec 2002
TR-237
http://hdl.handle.net/2060/19930091305
Old Jun 18, 2011, 06:31 PM
landru is offline
Find More Posts by landru
landru's Avatar
Vancouver, Canada
Joined Mar 2003
I'd love to see some pictures of your set-up.
landru is offline Find More Posts by landru
Old Jun 18, 2011, 06:57 PM
Toronto Canada
Joined Dec 2002
Early wind tunnel tests.
Old Jun 18, 2011, 07:28 PM
yomgui is offline
Joined Feb 2011
Nice! I love the wirings... reminds me something !
Old Jun 18, 2011, 07:43 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
"..Originally posted by a contributor in 2003..."
Right! You're not trying to distance yourself from that effort by any chance, are you?
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jun 18, 2011, 08:05 PM
Toronto Canada
Joined Dec 2002
Jack
Nah, I did all my testng by poking the fuselage out the car wndow.
Old Jun 18, 2011, 08:25 PM
Jack
USA, ME, Ellsworth
Joined May 2008
OK, I can visualize that.
I wonder if you can get an air start on a fuelie that way, and if so how much speed it takes?
I got to see a Reeve Aleutian Airways crew do an air start on one motor of a DC-4 out on Shemya Island in the Aleutians in 1965. Then I got on the plane and flew away to Adak on it. I always sort of wondered why they made the passengers get off for the air start if it was safe enough to board an airplane with one engine running.
Yomgui (or Martyn) if you guys can tell us what the definitions of the variables like "Cf" and "Ct" are in the spreadsheet and graphs it would be interesting.
This is pretty much over my head but I am fascinated by the the data and the potential value in it.
Of post a link to a sort of propellers 101 lecture...
Jack
Old Jun 18, 2011, 08:52 PM
Toronto Canada
Joined Dec 2002
The Thrust(Ct) and Power(Cp) coefficients are dimensionless coefficients which allow you to determine propeller thrust and absorbed power if you know the RPM, Pitch and Diameter and the air density (rho).
The coefficients in the TR-237 Technical Report are determined using Imperial units (Pounds Thrust - Horsepower).
From the Advance graphs, the Thrust and Power may be determined for any airspeed.
On the Advance Curves, the X-axis may be considered airspeed.
The Y-axis gives the value of the coefficients for that airspeed.
On the X-axis the Pitch Speed (RPM X Pitch) is equal to an Advance equal to the Pitch/Diameter ratio.
A prop with a P/D ratio of 0.8 has a Pitch Speed (RPM X Pitch) with an Advance of 0.8.
The Zero Thrust Speed is equal to the Pitch Speed Advance + 0.2.
For a prop with a P/D ratio of 0.8, the Zero Thrust Speed occurs at an Advance of 1.0.
Old Jun 18, 2011, 08:55 PM
yomgui is offline
Joined Feb 2011
This explain Cp, Ct and V/nD... :
http://www.mh-aerotools.de/airfoils/index.htm
Things are not so easy unfortunately, Cp and Ct increase with rpm.
This numbers are useful to predict prop's behavior.
Old Jun 18, 2011, 08:58 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Very nicely done !
Looks like you've got a cross section for the size of prop displayed -- no side wall influence.
I did an open jet version w/ a gambit of motors that could be place at either end:
jrb is offline Find More Posts by jrb
Old Jun 18, 2011, 09:50 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Martyn, yomgui, et. al.,
Thanks for the help and links. There is some interest there but the math is just too intensive for me. I'm still getting a lot of value out of the way Robert Goble has the prop data at FlyBrushless.com. That is about the level of interest and practicality I enjoy.
As a last question, knowing that each different testing setup can change the results a little, if you turn a given prop at a specific RPM with a number of different motors, wouldn't the thrust produced be about the same for every motor?
jrb,
I like the "hang in there baby!" testing setup, that is one I have used myself.
Jack
Wind Tunnel Smoke zagisrule! Power Systems 23 Feb 06, 2015 01:28 AM
Mini-Review Turbo Ace 915 V2 9g Motor with Pictures, Video, Flight Tests, and Thrust Tests Tom Z Micro Helis 96 Aug 12, 2011 08:48 PM
Question Wind Tunnel for kiteboarding tests? DougE Sailplane Talk 1 Jan 16, 2008 04:42 PM
Discussion Wind Tunnel Tests Aphorism's Dream Ornithopters 0 Apr 30, 2007 12:36 PM
sources of wind tunnel pics Tim Green Modeling Science 0 Feb 10, 2003 08:29 PM
