Old Jun 17, 2011, 10:50 PM
runester351 is offline
Find More Posts by runester351
Josh Fisk
Joined Jun 2011
Question
Torque Roll solutions
im looking to start a scratch pusher prop jet and im trying to figure out a way to reduce the torque roll on a single prop thrust vectoring? my thoughts put use a gear between the prop and motor but i would have to have a larger mount on the elevator causing tail heavy? anyway i would like to hear any other solution to torque roll besides two counter rotating props( trying to stick with one motor) or would thrust vectoring itself reduce the torque roll?
runester351 is offline Find More Posts by runester351
Old Jun 19, 2011, 07:59 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
Smaller diameter prop, build in a little right thrust.
ATIS is offline Find More Posts by ATIS
Old Jun 25, 2011, 01:36 PM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
if you build her with a low wing to weight ratio "floater" just back off the throttle on launch.
I have a few 20" pushers, swinging a 7x5 @2200+ kv they all have termendous torque roll.
But built light, i can under hand these things at a tad above half stick and they just go out and up.
Now when i punch them, boy oh boy, blistering left hand torgue roll. At first it was a struggle hitting top speeds with that amount of torque roll.
So I use a mix channel "throttle-Aileron" on a switch i can turn on and off.
Another route would be to use a gyro on the aileron if a mix isnt possable on your tx.
D_FAST is online now Find More Posts by D_FAST
Old Jul 04, 2011, 11:06 PM
jirkajiranek is offline
Find More Posts by jirkajiranek
dzejdzej
jirkajiranek's Avatar
Czech Republic, Pardubice
Joined Oct 2008
Propeller diameter / Wingspan ratio
Hello,
The rule is to keep the propeller diameter up to 33% of the wingspan. For more info go to www.parkjets.com , the getting started section.
JJ
jirkajiranek is offline Find More Posts by jirkajiranek
Old Jul 05, 2011, 11:52 AM
62pilot is offline
Find More Posts by 62pilot
Don't look at me like that....
62pilot's Avatar
United States, AR, Piggott
Joined Aug 2005
You can also add about a 1/4 oz of lead to the right wingtip. I've tammed many a wild beast this way.
62pilot is offline Find More Posts by 62pilot
Old Jul 06, 2011, 11:33 AM
DreamArcher is offline
Find More Posts by DreamArcher
DreamArcher's Avatar
Joined Apr 2008
With my Draken I had some luck mixing in throttle -> aileron. It definitely worked but I just didn't spend enough time getting it perfect.
DreamArcher is offline Find More Posts by DreamArcher
Old Jul 06, 2011, 01:35 PM
wilmracer is online now
Find More Posts by wilmracer
United States, VA, Herndon
Joined May 2007
I'll second the suggestion to use a Gyro. I've been happy with the performance on my F/A-22. I can go from near-stall and punch it to WOT with almost no torque roll.
wilmracer is online now Find More Posts by wilmracer
Old Jul 07, 2011, 06:37 PM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Yup the mix route does take time to dial in, but then when the lipo drops voltage and you torgue roll decreases the aileron movement stays the same. So you have to be carefull. That why i throw mine to a switch.
Gyros are 100% the way to go.IMHO + You also get a bonus, flying in the wind is a breeze.
Old Jul 07, 2011, 10:48 PM
RickAvery is offline
Find More Posts by RickAvery
Moorpark, Ca.
Joined Apr 2004
Build your jet big and it becomes a non issue. I have two larger pusher jets ~36" WS, 51" L with 1410kv motors, on 4s Lipos & 8X6e APC props. 3/4 throttle and they fly straight away from the toss with no funny business. Blue skies!
RIck
RickAvery is offline Find More Posts by RickAvery
Discussion Funjet massive torque roll- need help kingkyle Flying Wings 10 Apr 30, 2011 09:23 PM
Discussion Too much torque roll 3DHS KillerCut 3D Flying 5 Mar 31, 2011 03:08 PM
Discussion Habu torque roll! Ara Tidwell Foamy EDFs 0 Mar 30, 2011 08:19 PM
Aerobatic 'park flyer'? Hover, torque roll, etc? Any ideas what to get? Joe B Parkflyers 25 Nov 09, 2001 11:44 AM
"Torque roll" with Twin-Jet Jurgen Heilig Foamies (Kits) 23 May 17, 2001 05:06 PM
