Old Jun 17, 2011, 11:23 AM
CaptainCarling is offline
Find More Posts by CaptainCarling
Yo Mamas toy boy
CaptainCarling's Avatar
UK
Joined Dec 2008
Are there any physical signs when a brushless motor packs up?
I suspect my motor has given up as the ESC has smoked.
Long story, but ive had the motor off and there doesnt appear to be anything wrong with it
CaptainCarling is offline Find More Posts by CaptainCarling
Old Jun 17, 2011, 11:54 AM
Balr14 is online now
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Depending on the heli, the ESC is often the weakest link. Many helis, especially with belt or shaft driven tails, come with an ESC that can't handle the load. It's pretty common to use a separate BEC for the tail and gyro, to reduce the load on the ESC.
Balr14 is online now Find More Posts by Balr14
Old Jun 17, 2011, 06:27 PM
micronut is offline
Find More Posts by micronut
dont play with rc anymore
micronut's Avatar
United States, MO, St Joseph
Joined Feb 2005
Not really. Sometimes the coils will be blackened, but usually no way to tell.
Best to rewind or replace.
micronut is offline Find More Posts by micronut
Old Jun 18, 2011, 02:32 AM
Yo Mamas toy boy
UK
Joined Dec 2008
Thanks guys
Old Jun 18, 2011, 03:14 AM
fishfiend is offline
Find More Posts by fishfiend
Joined Jun 2008
The usual reason for the esc to smoke, is a broken coil due to heat, this transfers the load to the remaining coils. Higher current, means higher temperature and most esc are quite sensitive things... In a normal outrunner, wired in star or delta all the trailing wires of the motor are common. The quick way to check if your coils are sound is to continuity check between all the connecting leads of your motor. No continuity...bad motor...
Greg
fishfiend is offline Find More Posts by fishfiend
Old Jun 18, 2011, 04:48 AM
Yo Mamas toy boy
UK
Joined Dec 2008
There seems to be continuity, but there is a small amount of play in the bearings (pinion end)
Old Jun 18, 2011, 11:45 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Beware of screeching!
I've not had any ESC's fail yet, touch wood, but I've had a motor fail. First of all, it started to run quite noisily, and it turned out that the bearings were spinning in their housings. When I took off the motor can, I could see that the play that had developed had been enough to cause the magnets to rub on the stator, and there was quite a bit of magnet dust in the can. I got a bit more life out of the motor by using threadlock to fix the outer races in the housings, but I could also see that the motor shaft was also worn down a bit where it had been spinning in the front bearing. I bodged that with more threadlock.
After a few more flights, the motor failed - the shaft broke off at the front bearing, causing me to do my first and only auto to date with my 450.
2Doggs is offline Find More Posts by 2Doggs
Discussion Are there any scale Laister or Laister-Kaufman models out there? ISPYFROMABOVE Scale Sailplanes 8 Dec 23, 2014 03:20 PM
Discussion are there any micro edf kits? burro breath Micro EDF Jets and Power Systems 16 Apr 20, 2011 10:30 AM
For Sale Is There Any Interest In This? (Souped Up Hawk Sky) theleetbeagle Aircraft - Electric - Airplanes (FS/W) 5 Mar 19, 2011 04:28 PM
Discussion Are there any "built-up" kits available? netmav Electric Ducted Fan Jet Talk 13 May 23, 2008 07:40 PM
Discussion Are there any competitions coming up in poland? stanradzikowski Żar 2006 1 Jul 31, 2006 03:38 PM
