Raleigh, NC
Joined Aug 2008
BL and Staggerflyer,
Thanks for the additional input. As I see it, battery placement is the biggest challenge for this conversion. The hatch project scares me as I am great at hacking up such undertakings. BL, I would be interested if you have posted any additional pictures of your battery placement in the forward cockpit, perhaps taken from behind the upper wing? Did either of you consider any other battery placement ideas? I have seen another similar model where the modeler inserts the batteries through the firewall with the cowling off. This has the advantage of preserving the scale look of the fuselage, but just how much trouble is cowling removal to change batteries? Is there any possibility of inserting batteries through the bottom wing with the wing fairing plate removed? I know I will be able to answer a lot of these questions when my box arrives. Just brainstorming. Paul |
BL was able to place his batteries further back because the power 110 is much heavier, plus it requires 8-9 cells, vrs the rimfire, which runs on 4-6 cells. any other placement requires balancing (dead lead)weight. Ultimately it's up to you. I will post more detailed pics if you would like, of the hatch area. I like mine. It's only noticeable when close up. I built mine to be seen in the air, and from stand-off distance, not close-up, full-on scale competition. |
United States, FL, Orange Park
Joined Oct 2006
Sold Waco!!
Raleigh, NC
Joined Aug 2008
Ship Has Come In
Now that I have received the ARF kit, I am very impressed with the overall quality of this model. Before accomplishing any actual assembly, I need to determine how I am going to mount the battery and what servos I am going to use. I would like to switch to digital, metal gear Hitecs, as I have a programmer. However, I am pretty sure I would need to install CC's 20 Amp BEC Pro to handle six or seven digital servos going all at once. I wonder how the additional draw of digital servos will effect flight times using Gens Ace 5s5300? Any feedback on this subject greatly appreciated.
As I understand it, Big Lacy put his series batteries in the forward cockpit to offset the additional weight of the Power 110 motor. Staggerflyer dropped his straight down behind the firewall by creating a hatch, and presumably, that worked well with the Rimfire 1.20 that I will probably use. I am working on a compromise that involves a 'hatch' cut in the 'floor' of the front cockpit with ramp that will slide the battery at an angle forward and down against the firewall. The CG of the battery will not be quite as far forward as Staggerflyer's installation, but he did feel that he was nose heavy. If I have to add weight to achieve balance I don't have a problem with that as I do not intend to fly this model 3D. I will post some pictures of this installation when I get a chance. I am planning to use APP connectors (75 amp) on my 5s batteries and the ESC. Since this is my first venture into giant scale EP, I should probably build a Safety Plug from the connectors, but I am not familiar with accepted practice for wiring this. Presumably, it is just an interruption in the positive lead to the ESC? If using the onboard BEC then all power would be interrupted, but if using an external BEC, then the receiver and servos would be powered as soon as the battery is connected, but the ESC would not come online until the plug was installed? Thanks for any help, Paul |
Raleigh, NC
Joined Aug 2008
Don't see why I could't place the safety plug on the ground side (black lead) and even use black APP housings and 'hide' it in the front cockpit. One new question about the motor mount. I have noticed that the firewall is canted with right thrust, but does not appear to have any down thrust. Did you simply make all four dowels the same length and are happy with the trim situation like that? Did you mount the dowels on a set of the hole marks on the firewall, or did you have to interpolate? I'm planning to use the same motor you did. Regards, Paul |
I kept the thrustline of the firewall. Do not seem to have any problem with ballooning on power changes, the reason for downthrust. I also setup to use the original centerline on the firewall, no changes. Used the "X" mount to drill the holes directly on the square stand-off for the gas engine. Then mounted the dowels as usual, which kept the prop drive washer in the proper position/location.
The 45amp rating on the mpii power plugs is plenty, as the max time over that during a flight is less than ten seconds, which occurs in less than 1 second bursts. Highest amp draw time is during runup on take-off run, and lasts less than 1 full second. So, even if they are "slow blow" fuses, they never get warm, soo... However, they do act as a type of efficiency reducer, as any and all connections and wire size reductions tend to do. As we are overpowered and do not require anywhere near max sustained output the loss is negligible/unnoticed. |
Raleigh, NC
Joined Aug 2008
Paul |
By "original centerline" I mean the one imprinted on the firewall. It is set up to put the prop drive in the center allowing for the thrust offset. Center your "X" mount on that location, mark and drill your screw holes, then when your prop drive is at the recommended distance, everything will line up perfectly. No need whatsoever to re-engineer anything. If you will look closely at the pics of mine and Big Lacey's firewalls, you can see the factory markings giving the centerline. |
Raleigh, NC
Joined Aug 2008
Well Underway
Well, guys, I finally have enough progress to post some of my implementation of the electric conversion of this great model. I'm lazy, so I went with the same basic power system as Staggerflyer, RimFire 120 on a 5s lipo. I wrestled a long time with battery placement. I really didn't want to cut a hatch in the cover in front of the front cockpit, knowing I would really goober it up. I also didn't want to lay them out in the open in the forward cockpit like Big Lacy did. There is nothing wrong with either approach, but I wanted to try something different. Here's what I cam up with:
Picture 1: I cut an opening in the floor of the forward cockpit. Picture 2: Looking through the opening, and through the bulkhead to the back of the firewall, you can see a slight lip running across the back of the firewall. Note that the opening in the bulkhead has had the lower corners squared to provide the rear support for the battery box, which will be inserted at about a forty-five degree angle. Picture 3: This is the battery box shown at the approximate angel it will be at once in the model. The vertical support will bolt to a bulkhead in two places. It has 75 amp APPs secured to it. PIcture 4: Battery box shown with battery secured and connected. Leads shown are for a battery charger. Installation will have 10 gauge wire. Picture 5: Battery box about to go into forward cockpit. Actually, you have to insert it through the lower wing opening and assemble the rear post once inside the fuselage. Picture 6: The battery box has a blind nut in the surface that lies against the back of the bulkhead. The bolt near the bottom of the firewall engages that blind nut and secures the battery box in place against the firewall. Picture 7: Once the battery box is installed, the battery slides over the back edge of the forward cockpit opening and into the box, shown partially inserted here. I'll probably make a plywood hatch with a pilot attached that is secured by Velcro. Picture 8: Once the battery box is installed, the battery slides over the back edge of the forward cockpit opening and into the box, shown partially inserted here. I'll probably make a plywood hatch with a pilot attached that is secured by Velcro. I have no idea how this is going to work out CG wise, but will probably put as much electronics as far forward as I can. Even if dead weight is necessary, I'm not too concerned, as I don't ever intend to fly this plane in any manner other than scale. Paul
| Thread Tools | |
| Article Great Planes Waco YMF-5D Biplane ARF 72" with OS 95AX 2-Stroke Review | kingsflyer | Scale Fuel Planes | 45 | Mar 02, 2013 08:33 AM |
| Discussion Great Planes Waco YMF-5D Biplane ARF .91-1.20 | jonnyspeed | Glow to Electric Conversions | 23 | Apr 30, 2012 05:51 PM |
| Build Log Dumas 1807 - WACO YMF-5 Log | w.s.chase1 | Parkflyers | 3 | Dec 31, 2011 01:10 PM |
| Help! Decals for WACO YMF-3 or YMF-5 | mustangmarty | Flight Accessories | 0 | Jul 20, 2009 04:08 PM |
