United States, FL, Orange Park
Joined Oct 2006
Hey Gord!!
Thanks again for the inspiration, will post more pics tomorrow, the other mods I have going on. By the way if I can find the pics of my Fun Cub, I fixed all the problems you are having by cutting off the nose, glue in a liteply firewall mounted my E-flite 10 and then glueing the nose back on with a couple drops of Ca. It was one of the first sold here in the states and I always warm up with it first,can't tell u how many times we had to get that Cub out of a Fla. pine tree, easiest plane I've ever had to fix quick.. Sorry,off subject. BL,,, BTW I flew Ringmasters in the 50s we must be close in age.
Chilliwack, BC Canada
Joined Mar 2010
Wish I could say that! I hit 68 on the 27th.
But the good side of that is that I can still get out back and cut down trees, shovel dirt and the like. The alternative to getting older does not allow a guy to do much flying. Or anything else!
Weight
Hello, I have a 72" Pica Waco completed but never flown that I'll probably do EP some day
if I ever stop changing priorities from buying more projects & am curious what yours might weigh w/o lipos. Also, can you pls tell me the ID of your cowl ? BTW, lots of Ringmaster time also on this 72 yr old airframe. You can see a few of my bipes in my blog including my two ultralights. Rgds Bob |
Bob, haven't gotten to the weighing part, yet, but will soon. Will try to get you a measurement on the cowl soon, also.
Did some more work on the battery mounting compartment this weekend. It's not pretty, I'm not an engineer/designer. I can copy someone elses work pretty good, but coming up with my own, not so good. Sure could have used some pics of the inside of that compartment, BL. Anyway, here's mine. I'm sure someone will be able to come up with a cleaner job on theirs, but if this helps at all, then I'm happy. Some pics...
Joined Aug 2008
Staggerflyer,
Thanks for posting this build thread. The WACO is on my short list to aquire as a future build. Looking at your battery hatch it looks like you may be using PowerPole (Anderson) connectors as an arming plug. If so are you using the 75amp version? I'm looking forward to the next installment. al |
Joined Aug 2008
Staggerfly,
I've used the same MPI/MAXX arming plugs on a 60 sized FW-190. They seem to work fine. I did panic one day when I saw that the connector size was rated at 45amps, but I have never had a problem even though the motor pulls 55 amps at full throttle. I was just curious if you were using the 75 amp rated connectors. Ok carry on with the build, I've got my snacks and drinks at the ready waitng for the next installment. al |
Is that what they are rated at?? 45amps? I have one on that Staggerwing in my avatar, Power 160 on 10 cells, pulls 78 amps and 2750 watts, and it never gets warm.
Hope to get back to work on it and fly it this 4th of July weekend, if the weather and my job allows time to finish it. |
Nice conversion. It's a bit late to suggest now, but I am considering building a slide-out motor/battery module when I convert my 1/6 scale Sterling Stearman. I think this method would work great for most any electric conversion where you don't want to cut a battery hatch.
Joined Aug 2008
Hi Staggerflyer,
Here is a link to the Power Werks page for the PP connectors http://www.powerwerx.com/anderson-po...owerpole-sets/ the ones I have from MPI measure in the 45 amp size but like you I have never had a problem. So using your expirence and mine I feel pretty comfortable using them in the WACO as you have. It is such a nice safety feature to be able to use while putting in batteries and moving the plane about. More building and pictures please I'm starting to go into withdrawl! al |
| Thread Tools | |
| Article Great Planes Waco YMF-5D Biplane ARF 72" with OS 95AX 2-Stroke Review | kingsflyer | Scale Fuel Planes | 45 | Mar 02, 2013 08:33 AM |
| Discussion Great Planes Waco YMF-5D Biplane ARF .91-1.20 | jonnyspeed | Glow to Electric Conversions | 23 | Apr 30, 2012 05:51 PM |
| Build Log Dumas 1807 - WACO YMF-5 Log | w.s.chase1 | Parkflyers | 3 | Dec 31, 2011 01:10 PM |
| Help! Decals for WACO YMF-3 or YMF-5 | mustangmarty | Flight Accessories | 0 | Jul 20, 2009 04:08 PM |
