Old Dec 11, 2013, 02:58 AM
AussieHoppy is offline
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
This sounds like an entirely different plane compared to the starmax P51... I've already posted in the AU WTB thread, I'll see if I get any bites, otherwise next week I may well take the proverbial plunge
Thanks guys for the feedback, much appreciated!
AussieHoppy is offline Find More Posts by AussieHoppy
Old Dec 11, 2013, 11:15 AM
Go4it is online now
Find More Posts by Go4it
Go4it's Avatar
United States, FL
Joined Mar 2004
FYI HobbyKing finally has them back in stock . They also had like a $15 or $20 off on Black Friday sale
Go4it is online now Find More Posts by Go4it
Old Dec 12, 2013, 06:33 AM
kydawg1 is offline
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
Serious?! All stock servos, motor, ESC/bec etc, other than the twist n turn retracts? I am very surprised
The worse Starmax experience was the P51, literally the only half decent electrical component was the motor...
I am all ears, and now getting even more tempted...
Strange I have an original Dago Red with 50 flights all original everything and still flies great. With that said.... the retracts have been the weak point...no failures, but in need to replacement.
On the A1 front, I have one on deck to build. Same family of models from Starmax as the P51 series, so many things are alike. One instant change will be PW-RC retracts during the build. Excited to get the A1 airborne.
kydawg1 is offline Find More Posts by kydawg1
Old Dec 12, 2013, 07:09 AM
mike2663 is offline
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Mines all stock also short of the retracts.So far no issues after many years of flying..
mike2663 is offline Find More Posts by mike2663
Old Dec 14, 2013, 09:38 PM
Joined May 2010
awww bugger... accidentally click the buy button...
Crazy thing with HobbyKing though, I couldn't buy from the Aussie warehouse because the courier they use refuse to deliver to a post box so I had to order from the International w'house.
I have pwrc 180 retracts on the shelf but are 90 deg, I'll prob keep these for my 1700mm P40 I am yet to finish. I also have some WingSpan retracts (originally intended for the P40) I will probably install into this A-1 because they are 100 deg, hopefully should remedy the anticipated nose over dendancy. I'll replace all servos (just dont trust stock cheapies, although I am tempted going by some of the reports here...) and might try a different motor/prop combo for a little more reserve power... I've just watched a few crashes on youtube due to insufficient air speed on takeoff, could be a lot were from holding up-elev too long but makes me think the stock setup on 4S may not quite be enough perhaps?
Anyhoo, looking forward to the arrival
Old Jan 24, 2014, 11:30 AM
619SixFour is online now
Find More Posts by 619SixFour
Alpine Aero Sqdn.
619SixFour's Avatar
United States, CA, Jamul
Joined Mar 2012
Man I hope I get this plane from a member on here. Been reading up on this plane and I love it. Reminds me of the Flight Of The Intruder.
619SixFour is online now Find More Posts by 619SixFour
Old Jan 24, 2014, 12:32 PM
carlcorn is online now
Find More Posts by carlcorn
Joined Apr 2009
It's available new from the US Hobby King location.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
carlcorn is online now Find More Posts by carlcorn
Old Jan 25, 2014, 01:38 PM
Fast_Eddy is offline
Find More Posts by Fast_Eddy
Rc Flying is my Sanity!
Fast_Eddy's Avatar
United States, CA, San Jacinto
Joined Mar 2010
I have what you need........... complete with upgraded retracts from PW-rc......
Fast_Eddy is offline Find More Posts by Fast_Eddy
Old Mar 09, 2014, 09:40 PM
Go4it is online now
Go4it's Avatar
United States, FL
Joined Mar 2004
Originally Posted by P 51 Jockey View Post
I bought one here used off the forums. It had a few flights on it from the previous owner. The carnage was the following:
Bent prop shaft
Delaminated fuselage in the nose (probably from the bent prop shaft)
Retracts not working (epoxied in down position)
Stripped flap servo
So, I put in some PW-RC metal trunion retracts with his Oleo struts, replaced both flap servos (HXT 900), glued the nose back together with Welders glue and machined off the hex area on an FMS prop shaft. Installed a Castle 10A BEC and flew it on 5 cell 3300's. It flew really nice and landed like a Piper Cub. I'm pretty happy with it and I'm only in it for $190.
When you added the 5S lipo did you change the ESC or is the stock ESC rated for a 5S
Old Mar 11, 2014, 12:57 AM
mackone is offline
Find More Posts by mackone
"the bouncer"
mackone's Avatar
Australia, VIC, Vermont
Joined Nov 2006
You will have to change the ESC , the four blades draw a lot of amps .
mackone is offline Find More Posts by mackone
Old Mar 11, 2014, 10:49 AM
Mikey 68 is online now
Find More Posts by Mikey 68
Joined Sep 2004
My friend flies his on 5s with the stock prop not sure if he changed the esc
Mikey 68 is online now Find More Posts by Mikey 68
Old Mar 11, 2014, 01:01 PM
Razerworkz is offline
Find More Posts by Razerworkz
United States, AL, Northport
Joined Apr 2010
I fly a 6s 3000 on my stock setup. No problems since purchase almost 2 years ago
Razerworkz is offline Find More Posts by Razerworkz
Old Mar 11, 2014, 09:16 PM
Go4it is online now
Go4it's Avatar
United States, FL
Joined Mar 2004
Did you change the ESC
Old Mar 12, 2014, 05:13 AM
mackone is offline
"the bouncer"
mackone's Avatar
Joined Nov 2006
Im only going by earlier post in this thread , if you go more than 4s then change your esc .
Always take into account the Temp where you are flying ..... a hot esc may not smoke at 10degreesC but at 40c punching into a headwind it will .
Old Mar 12, 2014, 08:21 AM
Joined Apr 2010
No, stock ESC.
Discussion 1600mm Starmax P-51 Build Report (lots of pics) rgd1065 Electric Warbirds 4801 Sep 17, 2016 04:43 PM
New Product Banana Hobby 1600mm Corsair and Skyraider Mikey 68 Electric Warbirds 0 Apr 25, 2011 07:16 PM
Discussion Anyone order 1400mm Starmax Cub from Hobbyshop Warehouse? highrailer Parkflyers 7 Mar 22, 2011 10:27 PM
Wanted Ziroli ad-1 Skyraider Low Show Aircraft - Electric - Airplanes (FS/W) 1 Mar 07, 2011 04:06 PM
Poll Douglas Skyraider ARF 40-50" Fsk Eflite Parkzone Starmax Hobbylobby Great Planes BigTonE Scale ARF/RTF 32 Sep 10, 2009 11:48 PM
