This thread is privately moderated by frank26all, who may elect to delete unwanted replies.
Old Jun 15, 2011, 11:59 PM
frank26all is offline
Find More Posts by frank26all
helicrazy
frank26all's Avatar
United States, AL, Robertsdale
Joined Nov 2009
Gallery
tiger moth
well I was able to fly my tiger moth again today with no damage,I did however encounter some strange flying characteristics,aside from being very windy the plane had a strange bobbing manner,not sure if it was the wind or my cg,maybe the servos are a little slow to react,I sure could use some more experienced opinions from my fellow flyers. thanks for any help
tiger moth (5 min 1 sec)
tiger moth fpv (3 min 28 sec)
frank26all is offline Find More Posts by frank26all
Old Jun 16, 2011, 12:54 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Nice Tiggie.
Your main wheels were up before the tailwheel...
I'd start by checking your CG, it looked a little tail heavy when it took off nose-first and the tail started to yaw earthward as she stereotypically rolled to the left. It's usually easy to spot tail-heaviness by making a few "bank and yank" turns... if the tail sags as you roll, you are most likely tail heavy. ("Sagging tail" could also be adverse yaw, but I doubt it on a Tiger Moth... that's more of a high-wing/high-aspect-ratio issue and most biplanes don't have that problem... but you could always mix in some rudder with the ailerons for good measure).
If your CG is to spec, next check your motor thrust angle... it might need more down-thrust and you have instead trimmed the elevator down to compensate. An easy way to tell if the thrust is off is to eliminate the motor from the equation... get some height, cut the throttle, and see how she glides in a shallow dive. If you are still porpoising with the motor off, then it's not the thrust angle.
Are your interplane struts backwards? More than once I've seen someone assemble a biplane with the struts backwards, so the top wing ends up with too much positive incidence.
Lastly, I'd just check that elevator servo... maybe it's twitchy (test it with a bit of load on it), or maybe it's too sensitive and you need some exponential. I'd try 30% and go from there.
P.S. - I see you are from Gulf Shores. My in-laws go there every other year or so for family vacation. I always make a trip to Pensacola while I'm there to check out the air museum.
warhead_71 is offline Find More Posts by warhead_71
Old Jun 17, 2011, 04:04 PM
helicrazy
frank26all's Avatar
Joined Nov 2009
cg
thanks for the input,the plane was in fact very tail heavy,I made a few changes in the battery compartment and I think I have it balanced out pretty good now but I will fly it again soon and report back,, thanks again
Old Jun 24, 2011, 04:57 PM
semc is offline
Find More Posts by semc
SEMC
Cleethorpes, England
Joined Sep 2004
Originally Posted by warhead_71 View Post
Nice Tiggie.
you mentioned that the interplane struts could be backward, i have just purchased an old 1/4 scale pilot tiger moth which is being refurbished and i have fitted my interplane struts but i'm not sure if they are fitted the right way, i have fitted the longest strut to the front and the shorter strut to the rear does this sound right to you, thanks in advance
semc is offline Find More Posts by semc
Old Jun 24, 2011, 05:04 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
I would think the longer strut would be to the rear, to offset for the wing being thicker at the front.
http://www.aristocraft.com/polksvbul...ead.php?t=1733
Discussion 25 Size DH 82 A Tiger Moth mchandrayan Scale Fuel Planes 15 Jul 08, 2011 07:30 AM
Sold ARFs: Sig WACO, GP PT-17 Stearman, 1/4 scale Tiger Moth pmisuinas Aircraft - Fuel - Airplanes (FS/W) 1 Mar 11, 2011 10:25 AM
Sold ARFs for conversion: Sig WACO, GP PT-17 Stearman, 1/4 scale Tiger Moth pmisuinas Aircraft - Electric - Airplanes (FS/W) 0 Mar 11, 2011 06:20 AM
Discussion GWS Tiger moth chihkwen Aerial Photography 3 Mar 09, 2011 03:51 AM
Found Searching for the elusive Tiger Moth excoastie Aircraft - Electric - Airplanes (FS/W) 5 Mar 07, 2011 04:03 PM
