Old Jun 15, 2011, 10:29 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Help!
ParkZone P-51 Motor vs ParkZone Sukhoi XP Motor
I'm looking to upgrade the motor in my Champ on floats so that I can get fast ROW...Which motor is more powerful---The Mustang motor or the SU-26XP motor???...Or, are the both the same???
THANKS!!!...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Jun 15, 2011, 10:31 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
THANKS!!!...
Kevin
Same specs... the mustang wires are longer. Both wires work in a champ, though the XP wire stretch tight and the mustang wires are easier to plug in.
UNGN is offline Find More Posts by UNGN
Old Jun 15, 2011, 10:59 PM
Joined Mar 2007
GOTCHA!!...THANKS!!!
Kevin
Old Jun 16, 2011, 04:38 PM
MellowFlyer is offline
Find More Posts by MellowFlyer
NEK of VT, U.S.A.
Joined Nov 2010
Somebody correct me if I am wrong; but I do not think the champ RX will be able to handle the higher amp load that the p51 motor will require.
MellowFlyer is offline Find More Posts by MellowFlyer
Old Jun 16, 2011, 08:14 PM
flashkick is offline
Find More Posts by flashkick
Flash, AAAAAAAAAAAHhhhhhhhhh
flashkick's Avatar
United States, UT, West Jordan
Joined Dec 2008
im pretty sure that was only the older cub/vapor bricks. the champ one is based on the ar6400 and has the 2amp esc.
flashkick is offline Find More Posts by flashkick
Old Jun 17, 2011, 02:14 AM
Lberry.88 is offline
Find More Posts by Lberry.88
If in doubt, add accelerant
Lberry.88's Avatar
United Kingdom, England, Stansted Mountfitchet
Joined May 2007
Correct.
From my experience the difference between P51 and Champ motor is negligible.
Lberry.88 is offline Find More Posts by Lberry.88
Old Jun 22, 2011, 11:49 AM
tripleup05 is offline
Find More Posts by tripleup05
tripleup05's Avatar
United States, GA, Grayson
Joined Mar 2008
I have a UM J-3 cub that I stuck a T-28 motor in. I am the second owner of the cub, and I have no idea how old it is, or which brick is in it. Should I be concerned about burning up the brick? This is the first I have heard of such.
tripleup05 is offline Find More Posts by tripleup05
Old Jun 22, 2011, 01:01 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
You are good.
It's the old Vapor bricks that have a problem with motors over 1 Amp.
Old Jun 22, 2011, 04:19 PM
tripleup05's Avatar
Joined Mar 2008
You are good.
Fantastic Man do you ever sleep? You have been helping me out left and right!
Question PARKZONE Sukhoi Su-26m & Micro P-51 GEARBOX richos Scratchbuilt Indoor and Micro Models 9 Apr 20, 2011 02:12 AM
Sold Parkzone Sukhoi XP, Sukhoi Parts, and UM Brushless Kit S.R.G. Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 17 Mar 23, 2011 11:49 AM
Discussion Parkzone P-51 BL or T-28 w/ Motor/ESC Upgrade pvtparts Electric Warbirds 4 Mar 17, 2011 02:01 PM
Found Parkzone UM Sukhoi 26m Motor Trade for UM P-51 Motor microflitedude Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Nov 08, 2010 01:56 AM
