Old Jun 14, 2011, 02:48 AM
Frank_fjs is offline
Find More Posts by Frank_fjs
2011 - Year of the clones!!!
Frank_fjs's Avatar
Australia, SA, Adelaide
Joined Nov 2010
New Product
Nine Eagles Solo Pro 228
Not much info available on this heli, but it reminds me of a CB180D. The 228 is a larger sized four channel fixed pitch single rotor with 45 degree flybar. It appears to be using a new TX, the J5 but also appears to be compatible with the J6.
Specifications
  • Length: 498mm
  • Rotor diameter: 395mm
  • Weight: 250g
  • Transmitter: 2.4GHz
  • Battery: 7.4V 1000mAh
Frank_fjs is offline Find More Posts by Frank_fjs
Old Jun 14, 2011, 05:11 AM
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
The design is so close to the CB180D that it is difficult to tell the two apart. I am not going to say it is a clone because Nine Eagles is suing Walkera for copying its head design in the CB180D and CB100
The CB180D flies horribly outdoors. Any wind and it drifts off like a kite. Also, it is very difficult to make it fly L circuits: it just won't move. Given that the CB100 itself is more agile than the Solo Pro outdoors, I will not put too much hope in it.
zadaw is online now Find More Posts by zadaw
Old Jun 14, 2011, 05:54 AM
Frank_fjs's Avatar
Joined Nov 2010
Yeah, this one doesn't interest me that much. Once you start getting into this size category, I think a 90 degree or flybarless set up is best.
Old Jun 14, 2011, 09:20 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Walkera copied the Quark tail drive design, but made "improvements" that proved to be disasters. Now, NE does the same damn thing. I have always felt these Chinese companies have a bunch of bright young mechanical engineers designing their helis that don't know a thing about them. They get the mechanical parts right, but miss all of the subtleties of what makes a good heli.
Balr14 is offline Find More Posts by Balr14
Old Jun 14, 2011, 02:43 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Can you explain what makes the NE tail design so bad compared to the Quark one?
SoloProFan is online now Find More Posts by SoloProFan
Old Jun 17, 2011, 07:31 AM
Frank_fjs's Avatar
Joined Nov 2010
New video of the 228 (in fact, the first one that I've seen):
NineEagles Solo Pro 228 フライト動画 (2 min 44 sec)
Tail looks a little twitchy.
Old Jun 17, 2011, 07:41 AM
zadaw is online now
Hong Kong
Joined Jan 2010
http://www.youtube.com/watch?v=FSAUQRrcQqQ
This video does not show the heli in good light. It seems that the tail gyro gain is too high, I hope it is adjustable. We need a video of it flown by a more experienced person.
Old Jun 17, 2011, 03:03 PM
Rick Hauler is offline
Find More Posts by Rick Hauler
ClubHeli.com
Rick Hauler's Avatar
Allentown, PA
Joined Mar 2009
It's not great conditions to be flying in either. Looks like the same day the 328A was flown, which was way too windy. We want to be able to handle a little wind, but I don't think anybody expects it to fly in those conditions. The gain should be adjustable on the RX, since all of NE's larger helis had pots for this, along with extent. I've said this before...I'm just not crazy about the design. They could have easily made this a shaft drive and 90 degree flybar and made it a good contender. Just an outdated design.
Rick Hauler is offline Find More Posts by Rick Hauler
Old Jun 23, 2011, 07:22 AM
helicopcat is offline
Find More Posts by helicopcat
helicopcat's Avatar
Joined Jan 2011
I found an old video of a test flight:
nine eagle 의 새로운 헬기 테스트 동영상 (1 min 46 sec)
Now on Hitec there is the complete list of spare parts:
http://www.hitecrcd.co.jp/RC/nine_ea...o228/index.htm
also here:
http://item.rakuten.co.jp/rc-yumekuu.../?p=1&type=all
helicopcat is offline Find More Posts by helicopcat
Old Jun 23, 2011, 08:29 AM
Frank_fjs's Avatar
Joined Nov 2010
This is the only heli in NE's new lineup that isn't really doing it for me. In this size I want a shaft driven tail with pitch control, try a V120D01 and you will never want to go back to a motor driven tail.
Old Jul 04, 2011, 09:30 AM
Frank_fjs's Avatar
Joined Nov 2010
Another video of the 228, it looks a lot better in this one:
NineEagle SoloPro 228 Coming Soon ~~ (2 min 26 sec)
Old Jul 04, 2011, 09:57 AM
helicopcat's Avatar
Joined Jan 2011
http://www.youtube.com/watch?v=OhlGwg_s2xM
I don't understand the reasons to insert those slowmotion sequences...
however it performs well.
Old Jul 04, 2011, 10:15 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Bevel cut gears have lots more contact surface than straight cut gears, thus more friction and resistance. It may not seem like much, but it increases the load on that type of tail motor design which means more heat and more amps going to the tail. That design is also very poor at dissipating heat. The Quark design used a drum and pinion, which has much lower contact area and a coreless motor with internal cooling. Even though it worked pretty well, Hirobo went direct drive when they upgraded.
Shaft drive tails with bevel cut gears work fine for helis with one motor driving the rotor and tail. The extra resistance just means a little more powerful main motor. You may have observed that belt and shaft drive conversion kits are always accompanied by a motor upgrade.
I also question why they would come out with a new flybar equipped heli now? It seems kind of late.
Old Aug 06, 2011, 10:16 AM
laurentjeuxlille is offline
Find More Posts by laurentjeuxlille
France, Nord-Pas-de-Calais, Croix
Joined Jul 2011
Have a solo pro, and if this one is as good as its little brother, i'm going to buy one. Would love to fly more often outside with a fp.
laurentjeuxlille is offline Find More Posts by laurentjeuxlille
Old Dec 26, 2011, 12:35 AM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
The Solo Pro 228a is now available but is called a 228p:
http://www.ebay.ca/itm/Nine-Eagles-N...item3a6e56e7d2
It's bigger than the 328a, which I have, but I'm not really sure what the 228 has going for it? What do you think?
gordonzo is offline Find More Posts by gordonzo
New Product Nine Eagles Solo Pro 100D / Solo Maxx 3D Frank_fjs Micro Helis 1873 Jan 17, 2016 01:29 AM
New Product Nine Eagles Solo Pro 328 (Nine Eagles' answer to the Blade 120 SR?) SoloProFan Micro Helis 1758 Feb 27, 2015 04:24 PM
Discussion Nine Eagles Solo tail motor problem?? dangerousatom Micro Helis 39 Aug 24, 2011 08:00 PM
Discussion Falcon 8193 vs Nine EAgles Solo cvrle1 Coaxial Helicopters 3 Mar 12, 2011 11:32 AM
