Old Feb 16, 2013, 09:21 AM
bladebreaker65 is offline
Find More Posts by bladebreaker65
United States, TX, Kemah
Joined Jan 2013
Thanks found it. I searched crystal and found the later post with the spec.now to see if I can find it local ?
bladebreaker65 is offline Find More Posts by bladebreaker65
Old Feb 17, 2013, 07:08 PM
siriusflier is offline
Find More Posts by siriusflier
GOT WINGS
siriusflier's Avatar
United States, TX, Wilbarger
Joined Apr 2012
I have still been following this thread, but haven't had anything to contribute for a while. I have been neglecting my 9958s, the last time I flew my best one was about a month ago, and I broke a tail motor wire off flush with the can. I had another tail motor, but then decided I needed to replace the main motor at the same time, but did not have a new replacement. I have also been busy with 2 V929s, a V202, and a DIY quad using Syma pcb and motors. I realized that the V929 motors were the right size for the 9958, and the Syma pinions were close, syma x1 pinions have 9 teeth, 9958 has 8. So I got it ready to solder about 3 weeks ago, but I hate soldering those tiny wires. Today I finally did it! Put a used V929 motor with a new X1 pinion on my 9958. And it flew! Could not fly outside because its too windy so I basically hovered inside through a battery. It needs some mechanical trimming because it drifts forward a bit, but had very little TBe and looks like it is going to fly fine So if you add a tooth to the pinion, would that make the head speed faster? I also guess that the motor may have a different rpm too. I will report back when I get a chance to try it outside
siriusflier is offline Find More Posts by siriusflier
Old Feb 17, 2013, 07:51 PM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
My new 9958 is doing much better and more time will improve even better. I like to fly these and buzz around the house for fun. Today flew all three 9958's with my MSR/ MSR-X. I have a six lead charger and makes it easy to charge them all,.. To my delite they all fly fine and had a good time. All are bone stock and fly well. I plan on making an adjustable boom for 9958. The tail will be longer than stock and have means of trying different settings on lenght.
dankar04 is offline Find More Posts by dankar04
Old Feb 17, 2013, 08:28 PM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Cool. An adjustable boom sounds interesting. Look forward to the pix.
RoboHeli is offline Find More Posts by RoboHeli
Old Feb 17, 2013, 10:24 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Thank you for sharing that experience. I'm sure it will come in handy one of these days, cause I have all the same models. Let us know once you get more test data. I'm curious, because the 9958 motor uses metal 8-t pinion, and you're giving it a nylon 9-t pinion. I wonder what you would say about the performance and noise level.
Heli Pad is offline Find More Posts by Heli Pad
Old Feb 17, 2013, 11:52 PM
borkencorter is offline
Find More Posts by borkencorter
Weltherrschaft will be mine
Germany, SN, Leipzig
Joined Nov 2012
@E2 Entschuldigung, ich dachte du wärst aus wien, meinte da am anfang des threads ma was gelesen zu haben.... hat mein wirres hirn wohl durcheinander gebracht.
Man braucht halt kleine ziele im leben die man stück für stück erreichen kann(weltherrschaft), leider ist kleptokrat noch keine annerkannte berufgruppenbezeichnung....
borkencorter is offline Find More Posts by borkencorter
Old Feb 18, 2013, 12:39 AM
urthlight is offline
Find More Posts by urthlight
Joined Jun 2008
What do you want for it?
urthlight is offline Find More Posts by urthlight
Old Feb 18, 2013, 03:39 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Na dann mal frisch ans Werk, vielleicht schaffst du's ja noch, das zu aendern ...
Old Feb 18, 2013, 07:12 AM
connerESP is online now
Find More Posts by connerESP
connerESP's Avatar
Spain, CT, Barcelona
Joined Jan 2013
May be this is a stupid question but what if you try to put directly a v929 motor with a 11 teeth pinion? The upgrade could be so great.....
connerESP is online now Find More Posts by connerESP
Old Feb 18, 2013, 07:54 AM
GOT WINGS
Joined Apr 2012
The diameter of the V929 pinion is too large for it to fit into the motor holder and mesh with the gears properly. The X1 pinion just happens to be the right diameter.
As far as using a nylon pinion, if I remember correctly, the nylon to nylon gears on my Syma s107g never wore out. The brass pinions on my other helis seem to wear out all the time, long before the motors.
Old Feb 19, 2013, 10:51 PM
Joined Jan 2013
wobbles
carbon main shaft ,msr paddle, msr grips and blades, did the solopro swash mod cutting the center and glueng to a stock 58 swash test flight great but wobbles on a deadstick hoover
reinstalled a stock swash wobble be gone . blew crystal (where did that pole come from)
waiting on crystal . moded #2 9958 same only used the solopro complete swash drilled and attached a carbon rod to the swash in correct position for guide rod and canted slightly down
aligned everything and drilled new carbon main shaft to fit flys great . alot more stick but now my wobble at dead stick is back ? I thought my first swash was out of round (freehanding the hole to fit over the stk ring ) now I am not so sure . Any Ideas ?
Old Feb 19, 2013, 10:53 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Not sure. Nice mods though. Can you post some pictures? I'd like to see your handiwork. Might also get some folks thinking about your problem a little better as well.
Old Feb 20, 2013, 09:32 PM
Joined Jan 2013
Be nice to me guys I have been playing with rc helis for all of 4 weeks or so.
ok added 1 shim washer on blade axel filed the exess off were I removed the wide set of link balls on the swash (the narrow set are twice as wide as stock ) wobble is gone . she flys faster than my 911 fwd now and has more cycle 25$ worth of msr parts made this thing come to life !!!
Old Feb 20, 2013, 09:45 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Lookin' sharp!!!
Have you tried swapping out individual components to see whether that makes a difference?
Old Feb 20, 2013, 10:24 PM
Joined Jan 2013
Ok I added 1 more washer to the blade axel (2 on 1 side 1on other 1 more made blade too tight) ground down flush were I removed the wide set of ball sockets (narrow set is twice as wide as the stock) now the wobble is gone!! this bird flies faster than my 911 and is more agile now!! these mods are easy to do and about 25$ well worth it. Thanks for the info !
msr paddle blades, msr head, msr carbon main shaft, msr ball links and servo rod ends, modified solopro swash plate
BRAVO SX TAIL ON THE BENCH !!
Sold Casio G-Shock GW-330-9v Solar/Atomic in New Condition DPage Non R/C Items (FS/W) 1 Apr 16, 2011 01:23 PM
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 06:27 PM
GW/R6NII & GW/R4PII BEC question TeamTEOR GWS (Grand Wing Servo) 6 Aug 22, 2005 07:05 PM
whats the different between GW/HFD3 and GW/HFD4 giannidsg GWS (Grand Wing Servo) 2 Aug 09, 2004 10:30 PM
New receivers GW/R-4PII and GW/R-6NII sheerLuck Radios 0 Oct 22, 2003 06:06 PM
