Old Jan 11, 2013, 09:26 PM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
On my first 9958 it would spin and thought motor was bad. Then looked at it and whole tail assembly was pushed foward from crash. Pulled it back to proper position and glued it and flys fine. Lucky it did not pinch wires. Problem with 9958 boom is to short. If you had a V911 side by side you see V911 tail is about 1/2" longer. Trim will not correct flight turning to right but helps. Little left stick and flys fine.
dankar04 is offline Find More Posts by dankar04
Old Jan 11, 2013, 09:58 PM
RoboHeli is online now
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
The Bravo SX tail boom increases the tail length a bit as well.
RoboHeli is online now Find More Posts by RoboHeli
Old Jan 12, 2013, 03:21 AM
Hellbore is offline
Find More Posts by Hellbore
RC Airplane Crasher
Mesa, AZ
Joined Jan 2007
Wow that's interesting, my 9958 tail holds perfectly but.. guess what, when I think back, i am not sure but I think I might have replaced the tail with a Bravo SX tail!! Haha... That could sure explain why my 9958 tail is so rock steady
When I compared my friend's 9958 tail motor to the one on my 9958 it did not look the same. I just assumed it was a different revision. And my 9958 doesn't have the tail fin at all. I got sick of it flying off and having to go find it and put it back on, then I realized the heli flies fine without it and left it off
Thanks for the tips!
Hellbore is offline Find More Posts by Hellbore
Old Jan 12, 2013, 07:57 AM
RoboHeli's Avatar
Joined Dec 2011
AFAIK the 9958 doesn't have revisions. At least all of the spare parts I've purchased over the last year haven't shown any differences from the first helis I bought.
If someone knows differently, let me know..
Old Jan 12, 2013, 09:15 AM
Hellbore is offline
RC Airplane Crasher
Mesa, AZ
Joined Jan 2007
It might. My co-worker's 9958 has a different circuit board. There are slight differences and it has a different number on the back of it (the side touching the frame).
Old Jan 12, 2013, 11:12 AM
dankar04 is offline
Tucson, Az
Joined Feb 2007
Even with 100% stock set-up flying is fine. Correcting flight is no problem and it spins fine either way. I made a trade and looks like I will have an MSR coming. Look foward to see how they compare. MSR has padels on flybar and that would give an advantage. I was going to get a MSR-X but the Mcp-x is slightly more and its a good bird.
Old Jan 12, 2013, 02:33 PM
RoboHeli's Avatar
Joined Dec 2011
Cool! If you could snap a close-up picture of the front and maybe a couple of the back of the board and post it here, that would be really interesting!
Old Jan 12, 2013, 02:34 PM
RoboHeli's Avatar
Joined Dec 2011
Nice. The MSR is a high-strung bird and is a lot of fun to fly.
Old Jan 12, 2013, 09:32 PM
Hellbore is offline
RC Airplane Crasher
Mesa, AZ
Joined Jan 2007
I also have an MSR and it's a fantastic little bird. IMO the gold standard for micro FP helis
But then again, my 9958 is less touchy and thus in a way, easier to fly. And my Bravo SX is by far the most relaxing and scale-flying helicopter of the 3. So I guess they all have their strengths
When in doubt collect all 3 :P
Old Jan 13, 2013, 09:03 PM
dankar04 is offline
Tucson, Az
Joined Feb 2007
I fly my 9958's with nano-tech 160ma. and so far not to impressed. Local Ace hardware sells Blade helis and picked up some 150ma 25c batteries and like them big time. I will never/ever buy nano-techs again. several DOA from the start.
Old Jan 13, 2013, 09:21 PM
RoboHeli's Avatar
Joined Dec 2011
That's interesting. My 160mAh Nano-Techs are just fine for my 9958. I did have one die early out of 12 that I originally ordered but now have 25 cycles on each of them and they're still going fine. I fly my Blade Nanos on the NanoTechs but I don't fly in stunt mode with them. They work fine for all the other helis I have.
The ones that seem to be weaker are the regular Turnigy 160mAhs (non-Nanotech). I've gone to LVC on my MSRX with those a few times at around 3:30 when I always expect 4:00+ minutes with my other battery tpes even when flying outside.
However---I do have the EFlite 150mAhs and they are by far the best that I have right now. My TRex 100X with its weak motor only flies to 4 minutes with these. The other Turnigy batteries (both nanotech and non) can't even keep it up past 2 minutes. When I take my Blade Nanos outside, the ONLY batteries I feed them are the EFlites. I'm REALLY happy with these guys!
Old Jan 16, 2013, 08:37 PM
RoboHeli's Avatar
Joined Dec 2011
Hey, check it out. Banggood is selling a 9968 with a different canopy style:
http://www.banggood.com/Wholesale-Gw...r-p-61607.html
Old Jan 17, 2013, 07:02 AM
treff is offline
Find More Posts by treff
Joined Jan 2013
Wonder if any one can help. Very new to heli's but trying to change tail motor on xieda 9958 but having problems. Does any one have a wiring diagram or picture of the wire up on main circuit board. Would appreciate any help. You can contact me direct trev.waters@btinternet.com.
Cheers
treff is offline Find More Posts by treff
Old Jan 17, 2013, 08:14 AM
jgestner is offline
Find More Posts by jgestner
United States, WI, Merrill
Joined Jun 2011
Cheers
All 4 motor wires are connected to the main circuitboard at the top front. Near center top is the blue main motor wire, next to that to the right is both main and tail wires connected to the same contact. Just a bit further to the right is the small green tail motor wire. The green tail motor wire and the blue main motor wire have there own contacts while both motors share a contact for the red wires. hope you can see it in the attached photo.
John in Merrill
jgestner is offline Find More Posts by jgestner
Old Jan 17, 2013, 10:54 AM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Cheers
Let me show you a good trick. Go to the top of the page, find the thread tools pull down menu, select show attachmens in this thread. You will find most of the pictures in this post. Among them, you will find what you are looking for. Once you learn how to do this, it will be helpful to you in many occasions.
Heli Pad is offline Find More Posts by Heli Pad
Sold Casio G-Shock GW-330-9v Solar/Atomic in New Condition DPage Non R/C Items (FS/W) 1 Apr 16, 2011 12:23 PM
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
GW/R6NII & GW/R4PII BEC question TeamTEOR GWS (Grand Wing Servo) 6 Aug 22, 2005 06:05 PM
whats the different between GW/HFD3 and GW/HFD4 giannidsg GWS (Grand Wing Servo) 2 Aug 09, 2004 09:30 PM
New receivers GW/R-4PII and GW/R-6NII sheerLuck Radios 0 Oct 22, 2003 05:06 PM
