Old May 01, 2012, 12:10 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Sounds like a bad tail transistor. A like to the correct one was posted a few pages back. Replace that and you'll fix your problem. Hope you can solder.
Good luck.
Daryoon is online now Find More Posts by Daryoon
Old May 01, 2012, 12:47 PM
jpconard is offline
Find More Posts by jpconard
Joined Feb 2007
Originally Posted by tamron View Post
I may try shortening the swash arms today, I'll have to hunt around for that post as I can't recall if it was better to re-glue them to the top or bottom.
Next time I go out I'll try your pulling out of the dive move. I'm sure it'll be as heart stopping as the diving flip
I've glued two swashes to the bottom of the stubs (not flipping the arms over or anything) with good luck, nothing has broken for many flights, I'm only running mcx2 14mm ball spacing though and stock flybar. I like MSR flybar on stock heli but with the mods and stock controller I can't recover especially in wind. With stock flybar when I get in trouble I can recover usually by just centering right stick and throttling up, sometimes opposite stick is required. But when a heli is so out of control in a fast multiple axis spin, opposite stick is nearly impossible.
I just cut the lower part of arm right in half, maybe favoring the stub to be a little longer (approx. 3 mm each). Then use leatherman file to take rib off the arm portion until it is completely smooth and black plastic has a little white, roughed up appearance. Then I just use Walmart superglue (purple stuff with brush can't remember brand) and put on plenty of glue then hold arm to bottom of stub. Takes a little while to set up, then I put a little more glue around the edges. Wait maybe 10-15 min. and good to snap back on. Will require slight trim adjustments, but not really a whole lot. Probably allow a little longer cure before getting too rough with crashes, etc. My son's don't have that mod yet but will, I haven't seen any reason not to do it, after having many flights on other two with it. It will be twitchy with your 16mm ball spacing to get used to, but I can adjust electric trim more back and still fly pretty good inside.
My son did fwd flip before me, I was always thinking backflip, never occured to try forward. Later that night somebody kind of dared me to try it at night, pure luck I pulled that off (roughly 20 feet from me when it came down), all I could see up high was the little red light and couldn't tell which way I was even facing.
The dive is OK, especially first time when it almost noses over it seems against physics that it can pull out. The flip is still maybe cooler, less control though but that makes it fun. I suppose if you get good at it you can more accurately judge height and dist. away to make them fairly consistent on placement, but I think the flip itself will always be a little inconsistent.
Next time I get to park I'll try to remember my better camera and get son to fly and see if I can zoom in and get better video than we did before. Pretty tough to do though.
jpconard is offline Find More Posts by jpconard
Old May 01, 2012, 01:20 PM
Scott in NH is offline
Find More Posts by Scott in NH
Joined May 2010
I haven't gone high enough yet to complete the flip, but I do dive it and pull out at about 3'. Probably the 9958's most impressive maneuver!
Scott in NH is offline Find More Posts by Scott in NH
Old May 01, 2012, 01:22 PM
RoboHeli is online now
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Does anyone know how to tell the 9958 main motor from a v911? I got one of each from myrcmart.com recently to have spares in case I needed them (I hate waiting for shipping...) but they don't include labels on their parts (reduce shipping costs?) and so I have no idea which one is which... Does it matter?
RoboHeli is online now Find More Posts by RoboHeli
Old May 01, 2012, 01:51 PM
Pancari is offline
Find More Posts by Pancari
What Do You Drive?
Pancari's Avatar
United States, PA, Folsom
Joined Jan 2012
Hat Cam
Attached are 3 photos indicating how I mount a camera to a baseball cap. It requires purchasing a mini-tripod from Ebay or equal and extracting the camera screw mount.
The key is to tilt the hat for best video framing.
Editing is done with Windows Live Movie Maker or equal.
Pancari is offline Find More Posts by Pancari
Old May 01, 2012, 02:07 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
9958 has 8teeth
v911 has 7teeth
Old May 01, 2012, 02:21 PM
tamron is offline
Find More Posts by tamron
Canada, ON, Barrie
Joined Jan 2009
I think you can tell by counting the teeth on the gear. 9958 has 1 more than the 911. I think I read that somewhere.
Edit: I'm to slow lol
tamron is offline Find More Posts by tamron
Old May 01, 2012, 02:25 PM
RoboHeli's Avatar
Joined Dec 2011
Originally Posted by Daryoon View Post
9958 has 8teeth
v911 has 7teeth
Thank you, Sifu!
What would happen if I ran the v911 motor in the 9958 and vice versa?
Old May 01, 2012, 02:37 PM
tamron is offline
Canada, ON, Barrie
Joined Jan 2009
Thank you, Sifu!
Using the 911 motor would give you better pickup but less top end. The blades would spin slower if the rpm's are the same.
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
LOL. That animation makes me laugh.
If you ran different teeth than stock, you change the gear ratio and thus the headspeed.
We had a discussion about this on the v911 thread just last week.
http://www.rcgroups.com/forums/showp...postcount=6758
You also have to think about gear mesh too. From what I understand, putting the 9958 motor in the v911 works fine. Higher head speed and I have seen people reported it's not as loud.
The higher head speed should make it better to fight wind. You should lose some punchiness by increasing the teeth by one, but I don't think that's detrimental to the v911/Solo Pro.
For the 9958 since we're on that thread, I think you should stick with the 8teeth pinion.
I think a Bravo SX motor with 8teeth pinion would be best.
Old May 01, 2012, 02:38 PM
erdnuckel2 is online now
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Thank you, Sifu!
You gonna loose headspeed on the 9958 and gain headspeed on the V911.
Consequently, you should loose torque on the V911 and gain torque on the 9958.
What would happen? I would expect the V911 to get more agile, while the 9958 might get troubles in keeping up with its usual self ...
erdnuckel2 is online now Find More Posts by erdnuckel2
Old May 01, 2012, 03:02 PM
tamron is offline
Canada, ON, Barrie
Joined Jan 2009
Thanks jp. Thats just the info I was after And I agree about the multiple axis spins. Those can be killers if your to low.
I was out diving and flipping again today and found I can do it really quick without much loss in hight. So...wanting the spectacular, I just gave it 3/4 thro. and now I'm getting these really looong hair raising dives before it noses under Looks fantastic!!! LOL.
@ Pancari
nice job! Thanks for those pics. I'm going to try that with the wifes camera tomorrow! Would be nice to see more vids of everyone working this heli I think!!
Old May 01, 2012, 03:09 PM
SpiritofStLouis is offline
Find More Posts by SpiritofStLouis
SpiritofStLouis's Avatar
United States, MO, St Louis
Joined Mar 2012
Good luck.
FOR SALE BY OWNER
Slightly used Xeida 9958 available. This helicopter has been a big hit everywhere it has been flown. It has a tail motor that just won't quit. Make offer.
SpiritofStLouis is offline Find More Posts by SpiritofStLouis
Old May 01, 2012, 03:17 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Well, once of these days if that 9958 ever makes it to San Diego. We can patch her up and get her posing for a photo op or two.
Old May 01, 2012, 08:34 PM
RoboHeli's Avatar
Joined Dec 2011
After hearing all this talk about issues with trying to solder in wires for the tail motors and such (e.g. doing a Bravo SX tail swap), would it make sense to solder a socket onto the 9958 mainboard so that the plug of whatever heli's motor we're using can be more easily installed? If so, does anybody know what sort of plug size would be appropriate?
Sold Casio G-Shock GW-330-9v Solar/Atomic in New Condition DPage Non R/C Items (FS/W) 1 Apr 16, 2011 12:23 PM
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
GW/R6NII & GW/R4PII BEC question TeamTEOR GWS (Grand Wing Servo) 6 Aug 22, 2005 06:05 PM
whats the different between GW/HFD3 and GW/HFD4 giannidsg GWS (Grand Wing Servo) 2 Aug 09, 2004 09:30 PM
New receivers GW/R-4PII and GW/R-6NII sheerLuck Radios 0 Oct 22, 2003 05:06 PM
