Old Nov 24, 2011, 03:28 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Oops...my bad. I thought I remember meter. hehe
Yeah, it was dark...and I didn't want to climb the fence. It was far enough for this little heli. And it was an informal test anyways. Ideally, you don't want to be holding the heli because your body can act as an antenna.
Daryoon is offline Find More Posts by Daryoon
Old Nov 24, 2011, 05:42 PM
jgestner is offline
Find More Posts by jgestner
United States, WI, Merrill
Joined Jun 2011
Carl
I don't have a 9958.......yet. I do however have the chopper that I believe is the inspiration behind it, a Blade MSr. I had lots of trouble controlling it until I heard about being able to turn on some Expo on my Spektrum DX5e transmitter. What a difference!!!! Now with some extra leeway near center stick, I have pretty much tamed my MSr for indoor flight. I don't need to spend time or money on replacement parts.
I would say adding Expo is the main reason for going to the Turnigy 9X for a 9958.
John in Merrill
jgestner is offline Find More Posts by jgestner
Old Nov 24, 2011, 10:13 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Originally Posted by jgestner View Post
Carl
John in Merrill
I picked up an msr after I owned the 9958.. less than a week later I sold my msr lol. The 9958 is awesome even with stock transmitter. Cant believe I let it sit on my shelf the past week. darn airplanes takin up my time I would love to get the 9x for my 9958 but not being able to use it with my spektrum planes is what turns me off to it. even at that cheap pricetag, just cant pick it up for my $20 heli
oh and HAPPY THANKSGIVING EVERYONE!
3d astronaut is offline Find More Posts by 3d astronaut
Old Nov 24, 2011, 11:18 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Rc_noob, didn't you hear? I am using the 9x with the mSR.
Old Nov 24, 2011, 11:24 PM
monkeyhanger is offline
Find More Posts by monkeyhanger
monkeyhanger's Avatar
Canada, ON
Joined Mar 2010
I use negative expo on mine. I'm used to flying my 250 so I found the 9958 way too easy. -25% expo makes it really sensitive, which is the way I like it. I also found that after mechanically trimming it yesterday, I lost a lot of servo throw in one direction, so I put it back the way it was and added a tiny amount of weight at the tip of the canopy. I also increased the servo throws to 125%, so now with slight moves of the sticks and I can almost roll and flip my bird
monkeyhanger is offline Find More Posts by monkeyhanger
Old Nov 24, 2011, 11:32 PM
MoonShad0w is offline
Find More Posts by MoonShad0w
Hardware hacker
Australia, NSW, Sydney
Joined Aug 2010
400ft is nearly 122m... that's a long way even for a larger (non-FPV) heli.
The difference in controllability between the stock Tx and the 9x is really quite stark. I think the length of the sticks is definitely a factor. I was flying better even without expo. How much expo have you other 9x guys set? I found 60% to be pretty comfortable, but I'm grounded due to a dead gyro at the moment, so I can't experiment with it. Got a second 9958 and a replacement Rx on the way from myRCmart, so I should be airborne again soon.
MoonShad0w is offline Find More Posts by MoonShad0w
Old Nov 25, 2011, 12:04 AM
joshstreet09 is offline
Find More Posts by joshstreet09
United States, TX, Montgomery
Joined Nov 2011
I just manually trimmed mine the other day and noticed a loss in my left roll and and backwards flight guess i need to take it back closer to stock. Monkeyhanger how did you increase your servo throws?
joshstreet09 is offline Find More Posts by joshstreet09
Old Nov 25, 2011, 12:24 AM
ArcFault is offline
Find More Posts by ArcFault
ArcFault's Avatar
Joined Nov 2011
Makes me think I might try temporarily extending the sticks on the stock Tx, shouldn't be hard. I'm not quite ready to jump into the 9x yet.
Edit: Well I tried it and I gotta say, I know its a noob move, but there is something to this. Of course it screwed me all up since I'm already comfortable w/ the stock Tx the way it is, but I think that 1/4" to 3/8" extensions would be helpful to someone just picking it up. Sure beats "junior" mode anyway.
Funny how a parts order results in another heli, I did the same thing.
ArcFault is offline Find More Posts by ArcFault
Old Nov 25, 2011, 12:56 AM
jlk69 is offline
Find More Posts by jlk69
RC Aircraft Junkie
jlk69's Avatar
USA, CA, Chula Vista
Joined Sep 2004
Stock 9958 vs. mod. 9958
I have had a chance to compare the 9958 I bought from rc_noob that is modified with mCx lower blades and a mSr flybar and the stock 9958 I just got from FocalPrice. The pendulum effect is much more pronounced on the mod 9958 and forward speed seams the same. I am using the Turnigy 9x Tx with both and identical settings. I only have had a chance to fly inside so far but if forward speed outside is the same between the two I might put the stock flybar back on.
jlk69 is offline Find More Posts by jlk69
Old Nov 25, 2011, 01:01 AM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
I like negative expo as well. About 30-40.
Mechanically adjusting your servo should technically give even front and backwards flight.
On my t9x, after flashing the er9x firmware, I need to calibrate my sticks. You may want to figure out how to do the same with stock firmware to make sure the entire pot range is used
Old Nov 25, 2011, 01:02 AM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
Funny, at first I thought -35% was good. With 0 heli experience. Then I set low rates at -20% and I find i like to fly it that way more than the high rate. Nothing gets rid of the glitchy rudder, but I can live with it.
I too enabled e.limits and bumped some up over 100% but, only the in the direction and axis that I saw additional movement was actually happening. I don't think its good for these china shop (dual meaning) servos to try to get them past where they mechanically move.
Monkey, take a really close look at the servo arm ends, and while you are upping the limit, when they stop moving, I would not add additional % to that limit. I think it cranks the servo past where it is supposed to, and why set it to 125 when it stops actually moving at 112?
Anyway, I dont believe, looking at my previous video, that teh tail rotor from a bravo sx is any more powerful. Just based on rpm count while pirouetting?SP? spinning rudder locked all the way left. It might help a little to shorten the cf tail boom, I will try that later.
Broke the front mount pin on the skid/batt holder yesterday in a horrific crash into a bookshelf. Tried ca, didnt last long, now I fear that the nub that stayed in the mainframe mate hole will not come out.! Oh well parts on order. Funny, I havnt touched my planes since I got this thing!
P.
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Nov 25, 2011, 01:40 AM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
I like -20 as well. Depends on how warm up I am.
These helis are so convenient to fly. Flying a plane means more of a commitment in time and energy.
Old Nov 25, 2011, 01:47 AM
Hardware hacker
Joined Aug 2010
Interesting results, jlk69. Let us know if you do put the stock flybar back on it.
Planning to keep the new one (black) pretty much stock, and mod the crap out of my current one.
Regarding + / - expo, + seems to be pretty much "n00b mode" but without the reduced servo throw. Much better for indoor flight, but I'm sticking with linear or very small + curve for outside. I doubt I could handle negative expo.
Wheelspinner20, you can carefully drill out the nub if it's stuck. The main issue (I think) with pushing the servos past their limits is that it might be possible to get them stuck at the end of their throw while in-flight, which would probably be disastrous.
Old Nov 25, 2011, 01:52 AM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Jlk69: you'll need the associated longer ball swashplate mod before you can come to a conclusion.
Old Nov 25, 2011, 02:43 AM
ArcFault is offline
ArcFault's Avatar
Joined Nov 2011
Sorry to butt in, but all this talk about upgrading to the 9x has me wondering about something. I'm relatively new to this and until recently all my flying was with 3 ch IR helis. As such I really don't find that I have a whole lot of love for this mode 2 thing. I mean I've adapted just fine, but... why not mode 4? Seems like it would be a much easier transition, but there must be cons or everybody would be using it, right?
Sold Casio G-Shock GW-330-9v Solar/Atomic in New Condition DPage Non R/C Items (FS/W) 1 Apr 16, 2011 01:23 PM
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 06:27 PM
GW/R6NII & GW/R4PII BEC question TeamTEOR GWS (Grand Wing Servo) 6 Aug 22, 2005 07:05 PM
whats the different between GW/HFD3 and GW/HFD4 giannidsg GWS (Grand Wing Servo) 2 Aug 09, 2004 10:30 PM
New receivers GW/R-4PII and GW/R-6NII sheerLuck Radios 0 Oct 22, 2003 06:06 PM
