Joined May 2012
maybe you remember , 2x predator 30-8 made this cricri MC-15 fly during 30 minutes
schultze controller was then the weak point , they burned together in the same time !! now with schultze 333 , do you think a fiability step will be reached if someone decides to place predator 50 in a true ultralight aircraft? (for a sigleprop aircraft , 30" prop is a little small ... don't know about global efficiency at usual electric aircraft speeds -80-90mph -for such a small prop) Or maybe this 500A peak (400 continuous) controler , that seems to be the most powerfull in the market , someone knows? http://mgm-compro.com/index.php?tid=...-32-bit-system ![]()
Moss, Norway
Joined Jul 2003
Plettenberg have rated the Predator 30/8 at 210A max, while the 37/6 and 50/6 are rated at 310A max.
Jeti (and Hacker/Jeti) have excellent ESC's suitable for these power levels. Of course, none of these regulators are approved for manned flights. Magne |
but it suprises me if the P30/8 could destroy the 40.303. But with installation in a plane like Cri Cri, I see some trouble with cable lengths. ESC should be close to LiPo (0,5m) or a massive capacitor bank needs to be added. About manned flight, I would never recommend any of the Predators as they have a relativley weak mechanical design (that of course is a trade of for the low weight) In particular, the bearing arrangement is far to weak to give relevant margins for manned flights and other applications with, compared to RC, high mean load. The P50 uses the same bearings as the other Predators and I expect the beraings to fail sooner or later. The use of a folding prop is mandatory if you intend to do aerobatic manouvers like spin and snaps. Plettenberg was reluctant to the use of fixed prop already on the P30 and P37. But it works but a prop strike leads in most cases to a bearing failure. |
I can ad that the SPIN300 worked very well on the PR37 up to and above 300A. After i believe 4 or 5 years of hard use with fixed props on the Predator 37 i send my motor to Pletti for inspection and service if needed, they asked me "what is wrong with it" and my answer was maby a bearing or two... !?!?
so for me both the Terminator and Predator 30 and 37 have worked good on fixed prop, but i have also made sure to use a sturdy mount and carbon props, with a weak prop (wood or plastic) and a sloppy mount that gives flex and vibrations one could wear the bearings very fast.
Joined May 2012
@magne : yes ,30 min fligh + 15 min reserve WITH pilot , on 8kwh kokam Lipo , see discussion here http://forum.pegase.tv/viewtopic.php...978&start=1290
@pontus : huge condo is behind each engine in the carbon cover , see also on the forum , there's even a picture somewhere predator is 2kg ... and yes ,advantage is really weight. I have started a electric aircraft project too (40kg heavier ... because I'm not with the same budget http://www.velectris.com/forum/s1812...jet-Rutan.html ), already have an brushless engine , very reliable , very adapted in rpm (around 3000...) ... but 7kg also regarding batteries , have lifepo4 50kg/5kwh , but if I had to invest in better performances , was thinking about kokam 16ah cells (best density compared to 200ah ones) or NCR panasonic 18650 pack ,harder to make (lot of BMS) but good density and longevity in 2.9ah (better than 3.1ah one) I also take profit beeing on this forum to ask if it is possible to RC a small aircraft (120kg empty like cricri) with servo used in modelism ... was really thinking about put this and a 80kg manequin for first flights in mine... |
A 7kg 3000 rpm motor sounds like a very good choice for ultra light aircraft. Guess it incorporates bearings up to the job to handle a large and efficient prop (+40" ??)
I think the only man carrying application for Predator series would be paragliders, there is every kg of importance as you land on your legs and has to carry all the stuff too. However, the Predator will not get enough cooling in a paraglider if the full power needs to be utilised. A fan unit can solve it but then you add some weight again. Predators as sold and rated are for model use only. But Plettenberg has also an industrial business, many products based on the model motors but of course rated and mechanically executed in a different manner. |
Joined Aug 2011
I don't know if quality on bike/scooter is good enough.
Guess they are much more cost optimized and do not have the very best weight to power to efficiency relation you should look for for an aircraft application. I don't think Hacker A100-200 is a much better choice, heard about both failure of bearings and bad magnets. Made in China...and definitely no to aircraft standards ![]() Are we of topic or entire forum ![]() ??
| Thread Tools | |
| Build Log 102'' OMP YAK SP55M with Plettenberg Predator | bluelevel | Giant Electric Planes | 12 | Oct 01, 2009 04:48 AM |
| Discussion Plettenberg Predator magnet | jratzing | High Performance | 0 | Sep 09, 2008 01:15 PM |
| Discussion 39% Krill Katana with Plettenberg Predator 37/6 | Wolf F. | Giant Electric Planes | 39 | Jan 29, 2008 12:19 PM |
| For Sale PLETTENBERG HP 370BM/50/A1 S motor | K.R.Joye | Aircraft - Electric - Power Systems (FS/W) | 0 | May 11, 2006 09:33 AM |
| Plettenberg 300/25/A3 heli motor and Schulze 35Ho ESC - PERFECT for 30-50 size ehelis | Jason M | Aircraft - Electric - Airplanes (FS/W) | 2 | Nov 05, 2003 07:07 PM |
