Old May 12, 2012, 03:46 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Originally Posted by Doubletap View Post
The Hobby King Atom Mini Glider is now at the USA warehouse:
http://www.hobbyking.com/hobbyking/s...dproduct=24386
And on backorder already.
Rickochet is offline Find More Posts by Rickochet
Old May 13, 2012, 05:43 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
That didn't take long! Like they say, "the early bird gets the worm!
Doubletap is offline Find More Posts by Doubletap
Old May 13, 2012, 05:46 PM
Doubletap's Avatar
Joined Jul 2005
Originally Posted by CPMBOY View Post
nice little ...upps.....1340mm glider......hows the performance?
haven't built mine yet, although my SuperFly X is getting close to the top of my build queue, but just too many other models waiting to be built.
Old May 13, 2012, 05:50 PM
Doubletap's Avatar
Joined Jul 2005
Hey D-tap,
hows your atom?....what is the conn type for the ESC and batt that comes with the package (HK Atom)...dean@xt60?
The little Atom is a real peach, such a sweet flyer in school yard size spaces. The connector is a standard small orange JST BEC type, which is the type of connector is included with small 2S/3S lipos, see my post #64 for a pic of the actual connector included.
Old May 13, 2012, 06:57 PM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
did you put ailerons on your atom?
CPMBOY is offline Find More Posts by CPMBOY
Old May 13, 2012, 11:50 PM
Doubletap's Avatar
Joined Jul 2005
No, I'm going to leave it stock 3 channel, I don't want to make it any heavier, as it flies so nice the way it is. I have lots of other EZ style models with 4 channels so no need.
Old May 14, 2012, 04:07 AM
4x4rc is offline
Find More Posts by 4x4rc
Fly, crash, glue. Repeat.
Belgium, Walloon Region, Plombières
Joined Jul 2011
Coming back to the BMI Arrow there is now a dedicated thread for the 1400mm version of the AXN Floater/Clouds Fly here: http://www.rcgroups.com/forums/showthread.php?t=1640298 As could be expected the 1400mm version is reported to glide quite a bit better than the 1200mm AXN by those flying both side-by-side.
BMI also sells another, still larger version with 1500mm wing span here: http://www.bmi-models.com/index.php?...ow_1500/6/4620
- Mark
4x4rc is offline Find More Posts by 4x4rc
Old May 14, 2012, 10:50 AM
Doubletap's Avatar
Joined Jul 2005
- Mark
Just ordered! The RC Aerodyn special promotion is still valid, so how can one resist the buy 1 and get 1 free PNF BMI Arrow 1400,
too good to pass up. My total was $123.78 shipped for 2 kits to So Cal.
http://www.scaleflying.com/Glider-14...ly_p_2031.html
Old May 29, 2012, 02:15 PM
cloudbuster is offline
Find More Posts by cloudbuster
Joined Dec 2001
Is the wing on the solo 1500 glued in?
What about the other clones?
cloudbuster is offline Find More Posts by cloudbuster
Old May 29, 2012, 09:07 PM
Doubletap's Avatar
Joined Jul 2005
None of these have permanently attached wings, that wouldn't make any sense. most of these EZ style models have the standard 2 piece plug-in style wings using interference fit to retain the panels, but my SOP is to use a section of clear hockey stick grip tape on the seam between the wing panel and the fuselage wing root, which keeps the panels attached securely but allows easy removal if desired, although, I leave my wings attached for most of my planes, there is no reason really to detach them, which is a hassle to continually connect and disconnect the servo connector, I only disassemble my largest models which are 2.5 meter span and larger, to facilitate transportation.
Old May 30, 2012, 01:26 PM
Joined Dec 2001
I could swear I read the solo1500 wing was glued in. That's why I asked.
Do you also have the sirius 1500
http://www.bevrc.com/sirius-the-best...ters_p281.html
and the 1400 Glider
http://www.scaleflying.com/Glider-14...ly_p_2032.html
If you would have to do a list from good to worse what plane would take the top from the ones you have flown.
small description of mod if they need them or stock form.
Old May 30, 2012, 01:32 PM
sahil80 is offline
Find More Posts by sahil80
United States, VA, Sterling
Joined Mar 2012
hockey stick grip tape sounds like a good idea. Do you have to change this tape often?
I always have to take the wings apart as I cannot get my plane to fit in my toyota camry's trunk! - so I have been looking at options. Someone tipped me to use 3M clear mounts on wings and rubber bands - I am thinking to use it!
sahil80 is offline Find More Posts by sahil80
Old May 30, 2012, 03:04 PM
Doubletap's Avatar
Joined Jul 2005
I just leave the tape on unless it gets damaged then I replace it, but so far, I never really have to replace it on any of my models, and I like the adhesive because it leaves practically no residue. and it is inexpensive, a large roll can be had at Big Five sporting goods for I think a couple of bucks.
Old May 30, 2012, 03:06 PM
4x4rc is offline
Joined Jul 2011
Check out the AXN thread - lots of creative ideas on fixing the wings in there, some really elaborate.
http://www.rcgroups.com/forums/showthread.php?t=972336
- Mark
Old May 30, 2012, 04:02 PM
sahil80 is offline
Joined Mar 2012
What brand tape are you using?
- Mark
That's a loooooooong thread man! - I will someday spend a few hours searching for it. Do you have any summary in mind?
Discussion Sander-style (Ez)UHF antennas ssassen FPV Talk 56 Feb 17, 2015 04:09 PM
Off Site Ebay listing - Window decal for Easy Star Canopy - Space Shuttle style Easystarguy Aircraft - Electric - Airplanes (FS/W) 3 Mar 12, 2010 11:47 PM
Discussion Torsion on 'shocky style' foamie airframes Nethole Foamies (Scratchbuilt) 9 Aug 23, 2006 05:14 PM
Discussion Where can I find foamie plans for a trainer style plane stafphoto Foamies (Kits) 4 Mar 21, 2006 01:09 AM
Discussion style changes to ASRO's DS Listing site nwoods Dynamic Soaring 16 Feb 02, 2006 11:10 AM
