Old Aug 15, 2011, 07:49 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Originally Posted by LexusFPV View Post
DoubleTap , 4x4RC
How is your SuperFly X coming along?
what upgrades did you do to yours? ..... I'm planning on changing the motor and prop
on this bird and use this power setup...
http://www.readymaderc.com/store/ind...roducts_id=245
My Superfly is still in it's box and is in line in the build qeue, as lots of others models are waiting to be setup also. As far as the motor package you plan to choose, keep in mind that is intended an upgrade to a stock brushed motor Easy Star type model. I see that the KV of that Himax HB2815- 2000 motor is2000kv, which should be fine for a 2 blade prop like the APC 6x4E on a 3S lipo. The stock brushless motor that comes with the Superfly is a 1050kv, it's low because it will be turning the included 4 blade prop. If you are planning on using a standard 2 blade prop instead the included 4 blade job, then that is fine, but the 2000kv would be probably too high if you are going to try to turn the stock 4 blade prop on a 3S lipo.
Doubletap is offline Find More Posts by Doubletap
Old Aug 15, 2011, 08:02 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
DoubleTap.....
thanks for the reply,....yes I plan on using everything I said upabove.
(power package link)
I will not use the 4 blade prop and the original motor.....
LexusFPV is offline Find More Posts by LexusFPV
Old Aug 16, 2011, 03:16 PM
4x4rc is offline
Find More Posts by 4x4rc
Fly, crash, glue. Repeat.
Belgium, Walloon Region, Plombières
Joined Jul 2011
LexusFPV, my Phoenix is in the recyclables bag as of last night:
As for power setup, mine was a no-name 2208/8 2600 kV motor, APC 6x4 prop, and RCtimer 40A ESC. Motor mount from 4mm plywood patterned after the RCSuperpowers motor mount. Original mount removed via Dremel and plywood epoxied on instead, see closeups below. The foam "tail" underneath the motor also needs a bit of shortening.
Measured values: 680g thrust, 29A static current, 20k rpm. Timed at 72 mph via GPS trip logger in level flight. LOTS of power, big fun. Total for parts on Ebay about $35.
I also had a GY48V gyro on the ailerons, highly recommended. Fits nicely in a recess cut into the foam on the back side of the cockpit. Remove a bit of the foam on the inside of the canopy to clear.
Hope this helps.
- Mark
4x4rc is offline Find More Posts by 4x4rc
Old Aug 16, 2011, 04:28 PM
LexusFPV is offline
Joined Feb 2011
4x4rc
Thanks for those images.....
what was your runtime with the 3s-2200mah?
I'm planning on using 3s-2650mah with the 2200kv, 6x4APCe prop.
Hoping I get more than 20min runtime :-)
Old Aug 16, 2011, 06:19 PM
Doubletap's Avatar
Joined Jul 2005
- Mark
OUCH!! What happened to your Phoenix/SuperFly Mark?
Old Aug 17, 2011, 04:32 PM
4x4rc is offline
Joined Jul 2011
@LexusFPV: I was using several 1500 mAh batteries, flight times were around 6 minutes mostly 1/2 - 2/3 throttle with some WOT in between. Be aware that you need batteries capable of delivering up to 30A, so at least a 20C 1500. I tried a light 20C 2200 mAh Turnigy pack as well but didn't like it at all. The additional weight made for quite sluggish handling. Loop diameter almost doubled. I'd rather come back down more often, swap packs, and go up again. I especially like the Turnigy Nano-tech packs as they can be charged at 5C. So basically with three packs you can fly non-stop, two charge off your car/truck battery while you fly the third.
@Doubletap: massive vertical crash from about 60 feet. I was coming out of a roll that went bad. Shut power off and tried to catch her with the elevator but with the high speed and additional weight of the 2200 pack the elevator just flexed out of the way and she went straight in. Fuse was broken in multiple places above and below the wings as well, just can't really be seen in the photos.
Ah well, the power train is now in my AXN Floater. Should be fun! :-)
- Mark
Old Sep 14, 2011, 03:32 PM
Doubletap's Avatar
Joined Jul 2005
More EZ style kits at Hobby King
Hobby King has just added the big SkyWalker and Eagle Wing:
SkyWalker:
http://www.hobbyking.com/hobbyking/s...Warehouse.html
http://www.hobbyking.com/hobbyking/s...0mm%5FARF.html
Eagle Wing:
Old Sep 14, 2011, 11:18 PM
Doubletap's Avatar
Joined Jul 2005
hobby King FPVRaptor Composite 1600mm PNF
HobbyKing FPVRaptor PNF
http://www.hobbyking.com/hobbyking/s...00mm_PNF_.html
Old Sep 15, 2011, 08:39 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Hobby King FPVRaptor
Wow, that looks pretty well thought out. If the kit is of decent quality and it flies well that should do very well (if HK can keep it in stock).
Rickochet is offline Find More Posts by Rickochet
Old Sep 15, 2011, 08:59 AM
Doubletap's Avatar
Joined Jul 2005
It's not really a "Foamie" as the fuselage is blow molded plastic like their Phoenix 2K, but, it's close enough. Of course availability is always a problem with Hobby King because everyone loves a great deal so most of their product line sells briskly.
Old Sep 17, 2011, 09:46 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
And unfortunately it will probably be many months before it shows up in the US warehouse.
Old Sep 17, 2011, 12:52 PM
Doubletap's Avatar
Joined Jul 2005
Yeah, so I'll just wait for it like all the other models I'm waiting for to make it to the USA warehouse, because I have more time than money!
Old Sep 17, 2011, 01:04 PM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I just received a Mini Swift from them. They had been out of stock for 9 months.
Old Sep 17, 2011, 01:17 PM
Doubletap's Avatar
Joined Jul 2005
I was thinking about grabbing one of those Mini Swifts also, it's cool that it comes with a whole extra airframe.
Old Sep 21, 2011, 12:22 PM
Doubletap's Avatar
Joined Jul 2005
Another model from Hobby King: Vector 850 V-Tail Glider
Looks like a mini Bixler/Sky Surfer with a V-Tail:
http://www.hobbyking.com/hobbyking/s...r_EPO_PNF.html
Discussion Sander-style (Ez)UHF antennas ssassen FPV Talk 56 Feb 17, 2015 04:09 PM
Off Site Ebay listing - Window decal for Easy Star Canopy - Space Shuttle style Easystarguy Aircraft - Electric - Airplanes (FS/W) 3 Mar 12, 2010 11:47 PM
Discussion Torsion on 'shocky style' foamie airframes Nethole Foamies (Scratchbuilt) 9 Aug 23, 2006 05:14 PM
Discussion Where can I find foamie plans for a trainer style plane stafphoto Foamies (Kits) 4 Mar 21, 2006 01:09 AM
Discussion style changes to ASRO's DS Listing site nwoods Dynamic Soaring 16 Feb 02, 2006 11:10 AM
