Old Aug 05, 2011, 07:42 PM
United States, DC, Washington
Joined Mar 2011
Bixler/Sky Surfer or Dolphin
Has anyone on this thread tested either the
1) Sky Surfer/Bixler or the
2) Dolphin Micro Sport?
How do they compare to the others mentioned below?
Virginia Jim is offline Find More Posts by Virginia Jim
Old Aug 06, 2011, 02:57 PM
Fly, crash, glue. Repeat.
Belgium, Walloon Region, Plombières
Joined Jul 2011
J. Perkins/E-Scale/E-Sport Phoenix: http://www.jperkinsdistribution.co.u...%20-%20E-Scale
4x4rc is offline Find More Posts by 4x4rc
Old Aug 06, 2011, 05:21 PM
Si Vis Pacem Para Bellum!
Doubletap's Avatar
PRC (People's Republic of Commiefornia)
Joined Jul 2005
That's nice! I like the 4 bladed prop. Can't find a vendor who sells the PNF version and will ship to the USA for a reasonable price.
http://www.fasmamodels.gr/index.php?...69&language=en
Doubletap is offline Find More Posts by Doubletap
Old Aug 07, 2011, 03:37 AM
Joined Jul 2011
I have a Phoenix (well, what's left of it - it was my first plane). I don't think it'd be worth it. Get a AXN Floater/Clouds Fly (or BMI Arrow if you want a 1.4m plane) or a Dynam Hawksky for half the money.
In stock form the Phoenix doesn't have much power. The 5" 4-bladed prop looks kinda cool but it's inefficient and weighs a ton, as does the stock motor. I ended up putting a Grayson Microjet V3-equivalent power system in which is nice but adds still more to the price.
The fuselage is very weak in the cockpit area and will break on every crash. There isn't even enough "meat" to add crashproofing CF rods. The stock servos are crap as well, one broke during the maiden flight. :-/
Old Aug 07, 2011, 03:39 AM
Joined Jul 2011
Another one, the bigger brother of the AXN Floater/Clouds Fly, called the BMI Arrow: http://shop.righthere.nu/airplanes-e...prod_1161.html
Old Aug 07, 2011, 04:48 PM
Doubletap's Avatar
Joined Jul 2005
Hobby People SuperFly X, 4 blade prop and ailerons
http://www.hobbypeople.net/index.php...-ailerons.html
http://www.hobbypeople.net/index.php...ns-no-tx.html#
http://www.hobbypeople.net/index.php...mhz-radio.html
Old Aug 07, 2011, 11:18 PM
Doubletap's Avatar
Joined Jul 2005
I got both of those, my Bixler is ready to fly, but hasn't had a chance to get out to the flying field yet. my Dolphin MS is still in the box.
Old Aug 08, 2011, 03:08 PM
Joined Mar 2011
Let me know how you do with both of them. I crashed my Sky Surfer several weeks ago, broke the wing spar, ordered replacements and smaller carbon fiber tubes to go inside the 6mm spar, and should get them in this week.
My new Dolphin is in that same shipment.
VJ
Old Aug 08, 2011, 08:32 PM
Doubletap's Avatar
Joined Jul 2005
Hobby People SuperFly X, 4 blade prop and ailerons kit ordered.
According to FEDEX, my Hobby People SuperFly X ARF kit will be arriving tomorrow to join my EZ style fleet.
Old Aug 10, 2011, 10:08 AM
Doubletap's Avatar
Joined Jul 2005
SuperFly X received yesterday from Hobby People just as scheduled. Did a quick inspection of the kit, and is impressed. Although listed as a Kit, but it is more like a PNF less the servos and ESC. The brushless motor is already installed and 3.5mm gold male bullet connectors installed on the motor leads, just add your ESC with corresponding Female 3.5 connectors., Supply your own 9g servos for elevator/rudder and 2 ailerons, rudder/elevator linkages are already installed in the fuselage.
This model has good sized ailerons, with substantial control surface chord length, should be very responsive and aerobatic on roll axis, unlike the AXN clouds Fly and the Dynam offerings which both have inadequate ailerons size IMO which makes them somewhat unresponsive on roll. The SuperFly is more like the Sky Surfer/Bixler with much larger ailerons. Looking forward to setting up and fly this one!
Old Aug 11, 2011, 11:58 PM
Doubletap's Avatar
Joined Jul 2005
Micro Cushat:
http://www.nitroplanes.com/91a-cushat-arf.html
Dragonfly 1:
http://www.hobbyking.com/hobbyking/s...dproduct=11439
Turnigy Super Light Slow flyer:
http://www.hobbyking.com/hobbyking/s...lug_n_Fly.html
Old Aug 12, 2011, 01:55 AM
Joined Jul 2011
Doubletap, the Superfly-X is the Phoenix with different stickers. Not even a copy, it's the exact same thing.
Be aware of the points I mentioned above, specifically the fragility of the nose area. Also look at the hinges and tape them if required. On mine all were fine and have held up well except the elevator.
Also, there's a relatively hefty weight inside the nose at the very front, embedded in the foam. If you fancy a bigger battery dig it out. The plane will balance nicely by moving the battery back and forth, lots of room inside since there are no servos to get in the way. Speaking of balance, CG right on the mold release "pods" at the front underside of the wing works for me.
You're right about the ailerons, they do work. May want to program some dual rates for the maiden.
Good luck,
- Mark
Old Aug 12, 2011, 11:33 AM
Doubletap's Avatar
Joined Jul 2005
Good luck,
- Mark
Right on!, thanks for the feedback. I'll definitely remove the weights so I can use a standard 2200mah 3S. The HK Bixler also had a thick stack of large washers hot glued into the nose for balancing. I always set up my planes with dual rate and plenty of expo, to insure I will have smooth and precise roll control just off center, but at the same time, when I bang the ailerons hard over, I like my planes be able to roll like they were chucked up into a drill motor!
Old Aug 12, 2011, 12:01 PM
Doubletap's Avatar
Joined Jul 2005
JoysWAY foamies
Anyone has heard of this company, they have 3 different EZ style foamie models
Sprite 750:
http://www.joysway-hobby.com/Product_show.asp?proid=494
Performer 1100:
http://www.joysway-hobby.com/Product_show.asp?proid=495
Freeman 1600:
http://www.joysway-hobby.com/Product_show.asp?proid=496
Hobby People has a listing for the Sprite 750:
http://www.hobbypeople.net/index.php...-airplane.html
Old Aug 15, 2011, 06:35 PM
USA Beautiful
LexusFPV's Avatar
Joined Feb 2011
DoubleTap , 4x4RC
How is your SuperFly X coming along?
what upgrades did you do to yours? ..... I'm planning on changing the motor and prop
on this bird and use this power setup...
http://www.readymaderc.com/store/ind...roducts_id=245
LexusFPV is offline Find More Posts by LexusFPV
Discussion Sander-style (Ez)UHF antennas ssassen Video Piloting (FPV/RPV) 18 Apr 09, 2013 07:02 PM
Off Site Ebay listing - Window decal for Easy Star Canopy - Space Shuttle style Easystarguy Aircraft - Electric - Airplanes (FS/W) 3 Mar 12, 2010 11:47 PM
Discussion Torsion on 'shocky style' foamie airframes Nethole Foamies (Scratchbuilt) 9 Aug 23, 2006 05:14 PM
Discussion Where can I find foamie plans for a trainer style plane stafphoto Foamies (Kits) 4 Mar 21, 2006 01:09 AM
Discussion style changes to ASRO's DS Listing site nwoods Dynamic Soaring 16 Feb 02, 2006 11:10 AM
