Old Sep 15, 2011, 07:49 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Cool! I will have to work hard to catch up..
Old Sep 16, 2011, 10:15 AM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
So you're almost done out there, right?
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Sep 16, 2011, 10:59 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hey Steve..Yep I leave here tue. afternoon at 1:00 then arrive Tue. morning at 10:00 am...cool time warp..
Old Sep 16, 2011, 11:05 PM
Joined Apr 2004
When you settle back in, lets do lunch.
Old Sep 25, 2011, 09:18 PM
Joined Apr 2004
Working on pitching a flat roof.
Maybe a few days before getting back to the 104.
Steve
Old Oct 24, 2011, 04:06 PM
Joined Apr 2004
No haven't neglected the F-104. Will post progress at end of this week. Slow as it may be.
Steve
Old Oct 24, 2011, 04:24 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
what fan size is this going to be suited for?
stoneenforcer is offline Find More Posts by stoneenforcer
Old Oct 24, 2011, 09:52 PM
Joined Apr 2004
90mm and my for my Wren 54MKIII turbine.
However, larger fans can be fitted as well. Should have enough room for lots of lipos in front of the intakes.
Fuse size will be aprox 65.375", wing span with tanks aprox 31" (unless I add to the wing).
steve
Old Jan 25, 2012, 10:00 PM
Joined Apr 2004
So I finally decided on a wing airfoil. The idea is to have a scale size wing, an airfoil that will allow for good speed and be forgiving at landing. And not look like a trainer wing, but more a F-104 wing. The ruler shows around 13.5"
Bearing in mind that it has a large wing tank at the end of it.
The foam wing will not have the LE flap just the TE flap.
If this wing proves to do a good job, it will be wing I make hollow composite wing with. The LE flap will be on the composite wing.
Excuse the mess. It's how i work.
Steve
Old Jan 25, 2012, 10:49 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
flat bottom wing ? that was what i used ,with a "phillips entry" ...i never finished the highly modded throp bros F-104 ...it had LE &TE flaps.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jan 25, 2012, 10:54 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hey Roger....its semi flat at the tip and semi symetrical at the root....sorta hybred with a deg of washout also....well it will be a test bed at first....fun with molds!
Old Jan 25, 2012, 10:55 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
steve..tape the wings and tail on it and post a pic..it looks good..just a bit of tweekin left to do
Old Jan 25, 2012, 11:33 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Scott that what i did with my F-20 .flew them foam core balsa /glassed ....then after the flight testing ,removed them for mold making.
Old Jan 26, 2012, 08:56 AM
Joined Apr 2004
Scott, for a free hand cut on the ribs, the wings are not bad. They did sheet very easily.
If you use balsa on your 243 , use stiff in middle and TE. Use soft pliable at the LE to curve easier on the test wings.
If I were to use the foam wings, once I cut the slots in them for the spars, I would cover that section with .75oz glass to hold the foam section from moving then sheet. It would also help in spreading the load.
I'll mock up the wings and the wing tank plug and post a pic or two.
steve
Old Jan 26, 2012, 01:55 PM
Joined Apr 2004
So here's the crude mock up.
I just got a CS 120. it could fit. Lets see weight first wit 90
Almost there.
Steve
Wanted LTB F-16 1/8 to 1/5 scale fenderbean Aircraft - Fuel - Jets (FS/W) 2 Mar 21, 2011 03:29 PM
Sold Slighly Used Jetlegend 1/7.5 Scale F-4 Landing Gear $350 Shipped FlyBoyTha1 Aircraft - Fuel - Jets (FS/W) 0 Mar 10, 2011 11:17 AM
Sold PRICE SLASHED - PZL 104 Wilga 35 1:5 Semi-Scale Kit - No longer available in the USA Hoverup Aircraft - Fuel - Airplanes (FS/W) 0 May 06, 2010 11:53 PM
F-104 Starfighter Project 1/16th scale lphan Pusher Prop Jet Models 308 Jul 31, 2006 08:34 PM
For Sale F-104 cockpit 1:12 scale by italeri like2fly! Aircraft - Electric - Jets (FS/W) 0 Jul 29, 2006 05:23 PM
