Old Sep 05, 2011, 10:50 AM
Joined Apr 2004
My F-104 will have LE and TE flaps like. This may eliminate the need for washout. However, I have no problem adding washout into the wing if one does not want flaps, or just TE flaps. Since the wings are small and carry no landing gear, a few "plug in" wing configurations can be made very quickly. Then that version will become the composite one.
2/3's of lift from the fuse. Anything can lift at the speeds this thing goes in real life I guess. Like the "lifting body" airframe that was made years ago.
Scott, rained kinda heavy out here today at 3am this morn for around 20 min. Then a few sprinkles. Lots of thunder though.
MY BVM and Yellow both have washout. Probably cut into the foam core.
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Sep 05, 2011, 10:00 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i'd go with a least 2 degrees , these thing took off at like 200 mph and landed at about 150 -160 i think . they sounded wicked in the pattern ,the J-79 howl and growl
AIR SALLY is offline Find More Posts by AIR SALLY
Old Sep 05, 2011, 10:01 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i'd go with a least 2 degrees , these thing took off at like 200 mph and landed at about 150 -160 i think . they sounded wicked in the pattern ,the J-79 howl and growli used @3 degrees on my F-20 with little wings and there was no tip stall .
Old Sep 07, 2011, 01:11 AM
turbonut's Avatar
upland CA
Joined Dec 2004
Yea I think 2deg would be good...and keep the aileron inboard of the tip by a good bit..
Old Sep 09, 2011, 11:16 PM
turbonut's Avatar
upland CA
Joined Dec 2004
Update???? dont leave me hangin.....
Old Sep 11, 2011, 09:48 AM
Joined Apr 2004
Hi All and Scott.
Looking to get the ribs made to cut the wings today. canopy also being worked on.
Steve
Old Sep 11, 2011, 09:07 PM
turbonut's Avatar
upland CA
Joined Dec 2004
Goody a update......I am sitting in my room with SLOOOOW internet...tried to call but bad connection was not working
Old Sep 11, 2011, 10:08 PM
Joined Apr 2004
Hey Scott, I figure you trying to call, but all I get is an echo of various noises.
Hope your departure date stays the same.
At this point I have worked the fuse a bit more and turned the front of the wing tank out of florist foam. Messy.
Primer color change to give me and idea of uneven spots when sanding and depth for scribe panel lines and panels.
Also shaped the compound section of the canopy and sprayed it chrome silver to give me an idea of how smooth it is and true via the reflection. It"s good .
Next the rear section of the wing tank.
And the rest of the canopy sections cut from styrene plastic. Then border the sections with a canopy frame out of alum duct tape.
Old Sep 11, 2011, 10:29 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
man, thats starting to look awesome!
corsair nut is offline Find More Posts by corsair nut
Old Sep 11, 2011, 11:21 PM
turbonut's Avatar
upland CA
Joined Dec 2004
Hey Steve...yea now were talkin..it looks good ..I have some catchin up to do when I get back...cant have you done before the 234
Old Sep 12, 2011, 08:26 AM
Joined Apr 2004
Scott, be ready for the cooler weather.
Steve
Old Sep 12, 2011, 10:30 AM
turbonut's Avatar
upland CA
Joined Dec 2004
Yep lots of molding!
Old Sep 12, 2011, 12:18 PM
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Steve, that is looking really nice. Here's a pic of the inlet area if it helps, looks like you'll be dealing with that area soon. I was too lazy to scan it out of the book...
strictlyscale is offline Find More Posts by strictlyscale
Old Sep 12, 2011, 02:20 PM
Joined Apr 2004
SS
Thanks for the pic. I do have the rough mock up of the intakes already. The idea is to get the boundary layer as it's shown along with the all the other unique things that come with this intake! While keeping the size looking scale.
Thanks again
Steve
Old Sep 15, 2011, 02:21 PM
Joined Apr 2004
Found some 2" PVC pipe and it looked like a wing tank.
Turned the pipe down a bit, then turned the tip and tail out of florist foam, glassed and about to finish entire piece. Both composite tanks will be made from this one. That way I know they are the same.
steve
Wanted LTB F-16 1/8 to 1/5 scale fenderbean Aircraft - Fuel - Jets (FS/W) 2 Mar 21, 2011 03:29 PM
Sold Slighly Used Jetlegend 1/7.5 Scale F-4 Landing Gear $350 Shipped FlyBoyTha1 Aircraft - Fuel - Jets (FS/W) 0 Mar 10, 2011 11:17 AM
Sold PRICE SLASHED - PZL 104 Wilga 35 1:5 Semi-Scale Kit - No longer available in the USA Hoverup Aircraft - Fuel - Airplanes (FS/W) 0 May 06, 2010 11:53 PM
F-104 Starfighter Project 1/16th scale lphan Pusher Prop Jet Models 308 Jul 31, 2006 08:34 PM
For Sale F-104 cockpit 1:12 scale by italeri like2fly! Aircraft - Electric - Jets (FS/W) 0 Jul 29, 2006 05:23 PM
