Old Sep 02, 2011, 07:07 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Why are you in China Scott?
rvincent is online now Find More Posts by rvincent
Old Sep 02, 2011, 07:36 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Working on fullsize electric aircraft! Google yuneec int
Old Sep 02, 2011, 09:31 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
I just saw a full size electric in MAN a few months ago. that thing looks pretty neat.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Sep 02, 2011, 10:54 PM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
Scott
Fuse could be ready. Bob said he would cut the wings and stab when I have ribs ready.
Maybe in a few days.
steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Sep 02, 2011, 11:34 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice...then the fun starts..panel lines and hatches
Old Sep 03, 2011, 05:30 PM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Looks good Steve. The dihedral angle is -10 degress on the wings. Looks really cool, but quite unique to orientate in the air as by the time you see the far wing panel in a turn you're likley about to be banking it over too much.
Still really cool shape in the air. Keep going! What do you expect your auw weight to be in the end? What power size?
Sean
strictlyscale is offline Find More Posts by strictlyscale
Old Sep 03, 2011, 10:01 PM
Joined Apr 2004
A 90mm set up. I have a 90mm shubler, which is very light. Depending on cell count/size, I'm thinking 7 to 8lbs. LE flaps and the air brakes may add a bit. But I'll lay it up light and strong.
The fuse can be made to carry a turbine also. I have a Wren 54MKIII, that would be perfect for this size. Even a 100mm edf. Many options really.
I will make 3 of these at the same time. All EDF.
The first one will be for CG and throws, so it will get a bunch of Chinese power systems and a beating I'm sure.. I also have an assortment of 90mm fans. Change Sun, RCLander, Scott's Wemotec, Hoya....
Steve
Old Sep 04, 2011, 12:22 AM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hey Steve, I cjust picked up one of the new Houya 90mm fans for you...I see they seem to take a lot of power....
Old Sep 04, 2011, 09:27 AM
Joined Apr 2004
Now I have to finish it.
I will get my wing/stab ribs made today and have Bob cut the cores. He's on vacation till Thursday.
Of all the times to be in china.
We're suppose to fly Tuesday. Forecast is 102 degrees. Early!
Old Sep 04, 2011, 06:59 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
102 ...nice...its only about 85 still here...humidity has come down a tick..but not enuff...have you desided on wash out and airfoil yet? yesterday went to shanghi to a model show...lots of foamies..some were pretty nice...a few glass jets but not much...some BIG esc over 200amps..almost picked up a big foam(canyousayplug) Eurofighter Typhoon but no boxed ones in stock..o well saved my self from myself...say hi to Robert
Old Sep 04, 2011, 10:06 PM
Joined Apr 2004
I figure the airfoil will be something like the yellow F-16 I have apart. i'll trace the root and tip then cut my cores. Will not put in washout at this point. Also Bob strongly suggested molding in the fairing. So the fairing will be molded in.
Steve
Old Sep 04, 2011, 10:33 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
why no washout ?
AIR SALLY is offline Find More Posts by AIR SALLY
Old Sep 04, 2011, 11:03 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
did the Yellow f 16 use any washout ? or is it in the airfoil shape?
Old Sep 04, 2011, 11:53 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
F-16 dont need much washout due to the awsome vortex lift generated by the LEX's. if the Avons F-104 has washout out i would copy that ,the 104 will need all the help it can get ,wing tanks add lift to 104's too
Old Sep 05, 2011, 08:56 AM
Philadelphia, PA
I agree with AS and would suggest reconsidering building the wing without any washout. Even though they are very stubby, a little will still be helpful. plus you're cutting these cores from foam so that is the easiest type of wing to add washout to. I haven't looked close enough at my Avonds F104 to see how much is in there but I bet it has some, I do know for sure it's not a scale airfoil. I know my Avonds F-16 has quite a bit...it also has a slight undercamber which helps it fly so well as slow speeds too.
I read somewhere that the 104 gets 2/3's of its lift from it's fuselage....guess that's obvious with how small the wings are.
Wanted LTB F-16 1/8 to 1/5 scale fenderbean Aircraft - Fuel - Jets (FS/W) 2 Mar 21, 2011 03:29 PM
Sold Slighly Used Jetlegend 1/7.5 Scale F-4 Landing Gear $350 Shipped FlyBoyTha1 Aircraft - Fuel - Jets (FS/W) 0 Mar 10, 2011 11:17 AM
Sold PRICE SLASHED - PZL 104 Wilga 35 1:5 Semi-Scale Kit - No longer available in the USA Hoverup Aircraft - Fuel - Airplanes (FS/W) 0 May 06, 2010 11:53 PM
F-104 Starfighter Project 1/16th scale lphan Pusher Prop Jet Models 308 Jul 31, 2006 08:34 PM
For Sale F-104 cockpit 1:12 scale by italeri like2fly! Aircraft - Electric - Jets (FS/W) 0 Jul 29, 2006 05:23 PM
