Old Aug 13, 2011, 11:55 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hey Steve...dont worry the 104 just needs a bit more sanding and you will be there!....I will be bad axx
Old Aug 19, 2011, 10:54 PM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
Some more progress. The V-stab shaped and tail cone top fairing (clear plastic).
Should have left rudder attached. Dang!
And the first carving of the canopy plug out of florist green foam. Needs a bit of shaping still.
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Aug 19, 2011, 11:14 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice! its starting to look the part...U need to fix the spine...it bugs me to see it like that..ha
Old Aug 19, 2011, 11:34 PM
Joined Apr 2004
The spine will be next. Right after I get the canopy down. That way I'll get the spine at canopy termination right. Maybe by the time you see it again.
Steve
Old Aug 25, 2011, 06:07 PM
Joined Apr 2004
Decided to glass and prime portions of the fuse. Foam kept getting damaged.
Old Aug 31, 2011, 12:42 PM
Joined Apr 2004
Figured out how to put the spine on straight and clean. A wood dowel cut in half and an 1/8" channel down the bottom to center on fuse vert porfile.
Final alignments later.
And of course sand, patch,sand.ect x infinity.
Steve
Old Aug 31, 2011, 12:46 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Looking good Steve!
rvincent is offline Find More Posts by rvincent
Old Aug 31, 2011, 12:56 PM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Great progress Steve! I just finished covering my fuse and can appretiate how difficult all the curves are. There isn't a single flat panel on that fuse!
But then if it was easy everyone would have an F104, right!?
Nice work...keep plugging (no pun intended) away!
strictlyscale is offline Find More Posts by strictlyscale
Old Aug 31, 2011, 05:51 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
maybe it is the photos but the nose looks too short and too much curve on the bottom .....hope it just the photo . looking good though ,a lot of work for sure. i feel your pain im in same boat with a fuse plug.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Aug 31, 2011, 05:53 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i think it is the photo ...it looks about right back a few pages where you posted the pic of the full scale.this will be a popular kit if it flys well .
Old Aug 31, 2011, 06:31 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
It will fly well or else!!!!!! nice Steve..I like it...sitting here in my room in China ....Its HUMID!!!!! must be close to 95%...water is on the walls...
Old Aug 31, 2011, 07:05 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
china what the......they dont have porche's over there
Old Aug 31, 2011, 11:57 PM
Joined Apr 2004
In real life the nose looks ok to my eye. And the drawings, and Chino museum pics I am using...................And Scott's eye.
And, a buddy of mine from years ago, veteran master fabricator.
Also once the panel line and hatches are put on, that will bring the various shape together.
However, I must agree that in the pic it looks short.
Please point out shape concerns as needed. (F-104G)
I want to do this right the first time so i can move to the next ones sooner (Mig 21 and F-105 90mm both) before burn out, or before my wife says, "is that all you do with your spare time?"
Target dates to mold is December 2011. Cooler weather!!!
It will fly well. "Fly" to our group means, it takes off how, and when you want it to, and it lands how, and when you want it to. Plus the wings will be composite, allowing the TE/LE flaps to be easily configured. The idea is to have as close to scale wing size as possible. Minimize drag and not tax the power system as much.
That's the thinking at this point anyway.
Steve
Old Sep 02, 2011, 05:54 PM
Joined Apr 2004
I mocked up the wing and wing tank according to the 3 view drawings. They looked small, so I did a calculation using the length of the fuse as my constant to divide by and get percentages for my model.
Drawing wing root size, divided by drawing fuse length...ect
Good news is the wing gets and extra 1" at the root and .5" at the tip to be scale size. Span remains the same.
Wing droop (anti-hedral?) between 10 and 12 degrees.
Enlarged top view drawing a bit off. Will also check H-stab before cutting.
Wing tank was .125" off. I can live with that one. All the side views proportions were correct.
Steve
Old Sep 02, 2011, 06:59 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice! you will have it ready to mold by the time I get home...man they are small wings..
Wanted LTB F-16 1/8 to 1/5 scale fenderbean Aircraft - Fuel - Jets (FS/W) 2 Mar 21, 2011 03:29 PM
Sold Slighly Used Jetlegend 1/7.5 Scale F-4 Landing Gear $350 Shipped FlyBoyTha1 Aircraft - Fuel - Jets (FS/W) 0 Mar 10, 2011 11:17 AM
Sold PRICE SLASHED - PZL 104 Wilga 35 1:5 Semi-Scale Kit - No longer available in the USA Hoverup Aircraft - Fuel - Airplanes (FS/W) 0 May 06, 2010 11:53 PM
F-104 Starfighter Project 1/16th scale lphan Pusher Prop Jet Models 308 Jul 31, 2006 08:34 PM
For Sale F-104 cockpit 1:12 scale by italeri like2fly! Aircraft - Electric - Jets (FS/W) 0 Jul 29, 2006 05:23 PM
