Old Jan 19, 2013, 09:23 PM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
The molds opened 5 minutes ago. Untrimmed and unwashed.
I am happy that the plug survived so well. Thanks to the wax and PVA.
Sorry Scott couldn't wait.
The intakes will have an insert made later.
Now the 2nd hard part. Make it fly and come back safely.
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Jan 19, 2013, 09:34 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
freaking awesome. id love to buy a set of glass parts when/if you get to that point!
corsair nut is offline Find More Posts by corsair nut
Old Jan 19, 2013, 10:33 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Me too. (I think you're going to get a lot of "me too's")
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Jan 19, 2013, 11:00 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
me too
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jan 19, 2013, 11:12 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
me three.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jan 20, 2013, 12:22 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
O very nice!..I will come by in the morning..
Old Jan 31, 2013, 04:42 PM
Joined Apr 2004
First one out of the mold. Usually the worst one because this is the one that teaches you where the trouble sections will be in the lay up. A quick trim of the part. The way we do our lay ups, we get perfect surface finish and detail transfer every time. Can't see in pics.
I never paint in the mold. For this pic, to show the model better I painted one side of the fuse. I need to see into the fuse to make sure my bulkheads and V-stab supports are in the right locations. And also bonded well.
This one is also made out of polyester resin. It is the test drone for CG and throws. I will make an epoxy one with all the bells and whistles once I get my drone flying well.
Why use expensive epoxy for the test drone. Although, using polyester reminded me why I never use polyester. Stinky crap. Never again. I would rather crash an epoxy one next time for next models drone .
We will sling shot the first one into the air, then bolt a good edf into it.
Ultimately a Wren 54MK2, and maybe a MK3.
The fuse measures exactly 69" as is shown from tip of nose to tail "stinger" at base of rudder.
Steve
Old Jan 31, 2013, 05:26 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
nice ...that feels good to have the first one popped out
Old Jan 31, 2013, 09:15 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Nice!!! Love me some Starfighter
rvincent is online now Find More Posts by rvincent
Old Feb 01, 2013, 01:05 AM
Joined Jan 2009
well, she turned out pretty awesome, didn't she!? very cool.
Old Feb 01, 2013, 03:15 PM
Joined Jan 2004
The surface details and skin look really good. It doesn't have that homogeneous look that plastic models have.
Planning ahead: What will the hot setup be? I know the high blade count fans sound cool (we're never going to replicate the spooky howl of the 1:1 in EDF) but what will make the power and speed? This is going to have long intake ducting and a short exhaust right?
Old Feb 01, 2013, 03:34 PM
xmech2k is offline
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Check this out:
F-104 howl reproduced
Don't know what it might do to EDF thrust but.....
xmech2k is offline Find More Posts by xmech2k
Old Feb 01, 2013, 03:55 PM
buckaroo is offline
Find More Posts by buckaroo
Banzai Institute
buckaroo's Avatar
United States, NY, West Seneca
Joined Oct 2005
Steve she is looking great. Nice job in documenting the build for us. I have a question on your use of polyester. Did you have to add wax to your last coat to get it to harden? And what do you think the actual cost difference would have been between the polyester and epoxy?
By: CarreraGTSCS: This is going to have long intake ducting and a short exhaust right?
I think you would be in the same place with a large bell mouth on the fan housing, nice radius lips on the fuse. intakes and no inlet ducting. Especially gauged against very long intakes. Its just my opinion though, and I know its not in majority thought, but I base this on the performance of the old Byron powered kits, of which none used internal inlet ducting. You may gain some efflux with internal ducts, but at the expense of static and dynamic thrust. Again I know I am in the minority here but the few direct comparisons I have seen seem to reflect this.
buckaroo is offline Find More Posts by buckaroo
Old Feb 01, 2013, 07:51 PM
Joined Apr 2004
Thanks Gents
Buckaroo
For the wax on the last polyester coat. No, hung it out in the sun till cured. Problem was cold damp weather when laid up. Once the sun came out and the air was dry, it cured.
First choice is to make the intakes look as close to scale as possible. The first one will fly with no intake ducting and only a bell mouth edf unit. thrust tube.
I had a Byron F-16. It had thrust but not much speed.
For me, I am shooting for speed without over amping my equipment. The 104 is the perfect air frame for that. Also, one of the reasons I did not put wing fairings on my fuse is because I am ultimately looking to put the thinnest high speed wing I can land safely with.
On the intake ducting. I have always kept ducting on a high priority with fans. Airflow is the one key variables to performance.
The intake ducting will also be used as a structural support for sections of the fuse in place of bulkheads. I have used the ducting on my K/A F-100 to reinforce the nose section on that model using seam tape in a loop configuration. Can take a hit and doesn't let go cause the loop flexes just a bit.
The epoxy on average is around $125.00 an aprox gallon (1.2 gal). Polyester maybe $30.00
Steve
Old Feb 02, 2013, 12:20 AM
Joined Jan 2004
Originally Posted by xmech2k View Post
Check this out:
That was very cool. Thanks.
Wanted LTB F-16 1/8 to 1/5 scale fenderbean Aircraft - Fuel - Jets (FS/W) 2 Mar 21, 2011 03:29 PM
Sold Slighly Used Jetlegend 1/7.5 Scale F-4 Landing Gear $350 Shipped FlyBoyTha1 Aircraft - Fuel - Jets (FS/W) 0 Mar 10, 2011 11:17 AM
Sold PRICE SLASHED - PZL 104 Wilga 35 1:5 Semi-Scale Kit - No longer available in the USA Hoverup Aircraft - Fuel - Airplanes (FS/W) 0 May 06, 2010 11:53 PM
F-104 Starfighter Project 1/16th scale lphan Pusher Prop Jet Models 308 Jul 31, 2006 08:34 PM
For Sale F-104 cockpit 1:12 scale by italeri like2fly! Aircraft - Electric - Jets (FS/W) 0 Jul 29, 2006 05:23 PM
