Old Nov 16, 2012, 08:58 PM
Joined Apr 2004
[QUOTE=LuvEvolution7;23285487]what brand of F-16 is that, hanging up in the background? the F104 is starting to look very nice. you are doing a wonderful job with it.
Rich[/QUOTE
The F-16 is the BVM, with it's scale gear/doors/brakes and stuff. I converted it to a DynEmax/scopion 630kv on 12s. It will ultimately be powered by my Wren 54 MKII. It has not flown much.
It also has functional LE flaps. Since the LE/TE flaps work well and are not a big deal to set up, I am going to put LE/TE flaps on the 104 as well. I figure the 104 will need it since I have not really enlarged the wing.
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Nov 16, 2012, 09:40 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
wow!!!!
corsair nut is offline Find More Posts by corsair nut
Old Nov 16, 2012, 09:52 PM
Joined Apr 2004
Will not be posting much till Nov. 23rd.
Steve
Old Nov 16, 2012, 11:50 PM
Joined Apr 2004
Posted for fellow modeler due to me not knowing how to post pic in PM section.
BVM F-16 drop tank.
Will be one piece.
Steve
Old Nov 17, 2012, 12:24 AM
turbonut's Avatar
upland CA
Joined Dec 2004
Have fun in SF
Old Nov 17, 2012, 07:32 AM
C-5 Flight Engineer
PANTHERFLYR's Avatar
Joined May 2005
Thanks Steve! Nick
PANTHERFLYR is offline Find More Posts by PANTHERFLYR
Old Nov 17, 2012, 08:08 AM
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Great stuff there Steve! Looks like your ready to make a final push towards making the molds.
Keep at er
vettster is offline Find More Posts by vettster
Old Nov 20, 2012, 07:22 PM
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Steve,
If you haven't seen it yet, the long awaited F104 book from Danny Coremans has finally been released. Just got my copy and its great (so are the others in the 'uncovering' series).
http://ultra.glo.be/daco/
You may find it helpful as you detail your model.
Sean
strictlyscale is offline Find More Posts by strictlyscale
Old Nov 21, 2012, 09:21 PM
Joined Apr 2004
Just got back from little family vacation. FYI, San Francisco has it's own exchange rate for the American dollar. WOW, expensive.
SS
I love good books on a subject........But
Thanks for the link,. I am going to make it "impressive scale" with the dominant scale details.
I am lucky to have the Chino Air museum around 30 min from me. They have a pretty nice 104 there. The rest of the details will be functioning air brakes, functioning tail feathers, and LE AND TE flaps. And scale urethane resin hubs.
Easy to say, but let;s see.
Steve
Old Nov 22, 2012, 09:09 PM
Joined Apr 2004
A few more alum panels on the top of fuse. The outline of most of the gun door. Gun door will be an alum panel. Need to make gun fairing also.
Slow going, but going.
Happy Thanksgiving to all.
Steve
Old Nov 22, 2012, 10:41 PM
turbonut's Avatar
upland CA
Joined Dec 2004
Nice Steve..the intake really makes it look good
Old Nov 23, 2012, 12:49 PM
Joined Apr 2004
Need some vents. I have a Yellow F-16 hanging. So, I waxed/PVA'd the vents and applied bondo to the vents on the fuse. This will give me a cheap mold to make my 104 vents for the bottom at the rear of the nose gear doors. The tape is to help lift the bondo.
Let's see what happens.
You can see the benefits in this process.
I was going to mold the gun port also, but it's way to short. Although, I can elongate it. Or make one out of clay. ??
Steve
Old Nov 23, 2012, 04:29 PM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
great idea. simpler and easier than making your own from scratch.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 24, 2012, 12:29 AM
Joined Apr 2004
So this is what I did with the vents. Cut them apart to look the like the rear fuse vents. The vents have a very thin mylar sheet over them to create the panel section.
I may remove it and use alum tape due to the mylar being a bit thicker than I want.
For some reason I thought putting black marker on the vents would help make them easier to see. Just makes the vents look crappy even though the urethane casting is perfect.
Can't use the big vents anywhere on this model.
Steve
Old Nov 28, 2012, 10:26 AM
Joined Apr 2004
A bit more work. A few hours invested.
Switched the mylar vent cover to alum because mylar was too thick
On my lathe, I turned an alder wood (small grain) dowel into the shape of the gun fairing and cut it in half (have extra in case). Hand shaped to look right. Could have used a material plastic to avoid having to seal it for a good finish. Oh well, it's what I had.
Was going to pull a quick bondo mold off my BVM F-16's gun, but it was too small.
I may make a mold of my gun and use a urethane resin casting of it or a glass version. Depends on how much fuse cutting is needed at the forward recessed section of the gun.
Once the fuse mold is made, I can always lay up the gun section for other models also. The benefits of molds.
Steve
Wanted LTB F-16 1/8 to 1/5 scale fenderbean Aircraft - Fuel - Jets (FS/W) 2 Mar 21, 2011 03:29 PM
Sold Slighly Used Jetlegend 1/7.5 Scale F-4 Landing Gear $350 Shipped FlyBoyTha1 Aircraft - Fuel - Jets (FS/W) 0 Mar 10, 2011 11:17 AM
Sold PRICE SLASHED - PZL 104 Wilga 35 1:5 Semi-Scale Kit - No longer available in the USA Hoverup Aircraft - Fuel - Airplanes (FS/W) 0 May 06, 2010 11:53 PM
F-104 Starfighter Project 1/16th scale lphan Pusher Prop Jet Models 308 Jul 31, 2006 08:34 PM
For Sale F-104 cockpit 1:12 scale by italeri like2fly! Aircraft - Electric - Jets (FS/W) 0 Jul 29, 2006 05:23 PM
