Old Nov 13, 2012, 02:32 PM
SCALECRAFT is online now
Find More Posts by SCALECRAFT
Joined Apr 2004
The white coat. This will be the final color for the plug. The panel lines are very hard to see. Once the paint dries the tape is removed. Lets see how clean the lines are and how the tape releases. I have old plastic 1/64 tape on one side and paper 1/64 on the other for one of the long panel lines. !!
The lines will show up as black an rust brown once the tape is removed.
The V-stab has a ton of detail on it. I will do that later this week, I broke the rear tip of the rudder off. Poop.
Steve
SCALECRAFT is online now Find More Posts by SCALECRAFT
Old Nov 13, 2012, 04:49 PM
Joined Apr 2004
Tape removed. Clean up of lines, scribe lines if needed.
V-stab panel lines next
Very, very light wet sand.
Then alum panels.
The line at the wing fairing will be a guide for the separate piece for the fairing since I want optional wing airfoils/thickness.
The nose panel lines look off. Have redo that section. The nose will be removable so the panel line will make a nice guide to split the nose off the fuse. Should be even. Crap!
Steve
Old Nov 13, 2012, 06:21 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice I like it..now you need to put 5000 rivits on it hehehe
turbonut is online now Find More Posts by turbonut
Old Nov 13, 2012, 06:36 PM
Joined Apr 2004
Na, just a few panels.
5,000 rivets. By that time the plug will fall apart.
Steve
Old Nov 13, 2012, 10:01 PM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Nice progress. I never tire of looking at the F-104, in any size it's just too cool.
strictlyscale is offline Find More Posts by strictlyscale
Old Nov 14, 2012, 09:35 AM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Nice tutorial for finishing. Keep em coming. Thanks,Steve.
Phil
PhilLin is offline Find More Posts by PhilLin
Old Nov 14, 2012, 09:54 PM
Joined Apr 2004
A bit of alum duct tape use.
My details are subtle. I don't like large gaps for panel lines or rail road tie sized rivets. Especially after looking at the 104 in person.
One can always use washes and pens to enhance details, or light sanding to eliminate them.
The details:
Locations and sizes drawn on in pencil first, then pattern made from clear plastic(since one can see through it), then use clear plastic to make aluminum panels. Insures panels are the same on opposing side.
Screws on removable panels made with an old metal mechanical pencil tip. Rivets are made with a pounce wheel. The aluminum tape is great for subtle detail.
This is my favorite part. Plus I only have to do it once and have it for all my other 104 fuses.
Old Nov 15, 2012, 12:21 AM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice Steve..you had me motivated so I was sanding on the Mystere..even added the front canopy frame with the same tape
Old Nov 15, 2012, 09:21 AM
Joined Apr 2004
Scott
Let's be ready to fly most of our new models before the next Jolt.
Possible?
Steve
Old Nov 15, 2012, 02:49 PM
Joined Apr 2004
A quick mock up to see if things look right. Wing covered in monocote.
Also the scale/size in relation to the bike
Fuse is around 63-64" long.
There are a lot of details I can make out of alum tape on this plane. A lot!!
A little at a time, as AirSally pointed out in an earlier post
Steve
Old Nov 15, 2012, 04:11 PM
Tempest is offline
Find More Posts by Tempest
Tempest's Avatar
Gaithersburg MD, United States
Joined Nov 2000
That looks so hot Steve. The bike definitely helps give a sense of scale. It looks like a nice size! I bet you are enjoying doing the details. This is where the plug starts to come alive.
Paul
Tempest is offline Find More Posts by Tempest
Old Nov 15, 2012, 05:18 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice Steve..its really starting to look the part now
Old Nov 16, 2012, 03:13 AM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
saaaweeettt! it's coming along real nice ....im going to need one
AIR SALLY is offline Find More Posts by AIR SALLY
Old Nov 16, 2012, 02:28 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
what brand of F-16 is that, hanging up in the background? the F104 is starting to look very nice. you are doing a wonderful job with it.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 16, 2012, 06:14 PM
Castel101 is online now
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
Looks awesome!
Castel101 is online now Find More Posts by Castel101
Wanted LTB F-16 1/8 to 1/5 scale fenderbean Aircraft - Fuel - Jets (FS/W) 2 Mar 21, 2011 04:29 PM
Sold Slighly Used Jetlegend 1/7.5 Scale F-4 Landing Gear $350 Shipped FlyBoyTha1 Aircraft - Fuel - Jets (FS/W) 0 Mar 10, 2011 12:17 PM
Sold PRICE SLASHED - PZL 104 Wilga 35 1:5 Semi-Scale Kit - No longer available in the USA Hoverup Aircraft - Fuel - Airplanes (FS/W) 0 May 07, 2010 12:53 AM
F-104 Starfighter Project 1/16th scale lphan Pusher Prop Jet Models 308 Jul 31, 2006 09:34 PM
For Sale F-104 cockpit 1:12 scale by italeri like2fly! Aircraft - Electric - Jets (FS/W) 0 Jul 29, 2006 06:23 PM
