Old Jan 26, 2012, 02:18 PM
Tempest is offline
Find More Posts by Tempest
Tempest's Avatar
Gaithersburg MD, United States
Joined Nov 2000
Hot stuff Steve!
If you're starting a list of who may be interested in a kit, count me in :-)
Paul
Tempest is offline Find More Posts by Tempest
Old Jan 27, 2012, 03:26 PM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
Thanks Tempest.
Maybe
Let's see what this thing flies like. Then I may consider offering it.
It's just a hobby for us.
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Jan 27, 2012, 05:03 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Originally Posted by SCALECRAFT View Post
So I finally decided on a wing airfoil. The idea is to have a scale size wing, an airfoil that will allow for good speed and be forgiving at landing. And not look like a trainer wing, but more a F-104 wing. The ruler shows around 13.5"
Bearing in mind that it has a large wing tank at the end of it.
The foam wing will not have the LE flap just the TE flap.
If this wing proves to do a good job, it will be wing I make hollow composite wing with. The LE flap will be on the composite wing.
Excuse the mess. It's how i work.
Steve
The photo shows how PAvonds did his wings. Very similar to yours. The wing has the slightest curve on the bottom and a definitive airfoil shape with the leading edges being rounded.
Great Job so far
vettster is offline Find More Posts by vettster
Old Jan 27, 2012, 07:45 PM
Joined Apr 2004
Looks pretty much like the same idea. The only difference is that these are test wings. if they work, they will become the plug for composite wings.
I also noticed on the real 104 wing, since the wing (and Vstab/rudder) is so thin, the hinge is only on one side of the wing. A live hinge will be pretty scale for a composite wing on this model. That will eliminates the need for hinges.
Are the wing tanks attached to the tip rib flush, or do they slide over the wing a bit, like a "pocket"??. I think that's what I saw on Striclyscales PA 104.
On composite wing tanks, I want make it so i can replace them easily. Making them 3 piece so when I ding those I can just replace the tip, mid section, or tail section. Plus the LE flap servo will be in the wing tank on the composite wing. Need access.
Unless that gets too heavy.
Steve
Old Jan 27, 2012, 08:44 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
The Tip Tanks slide over the wing. There held on with two small hex screws. Others have mentioned that they should have alignment pins installed because finding the screw holes can be troublesome.
Old Jan 27, 2012, 10:23 PM
Joined Apr 2004
Got it.
Steve
Old Feb 05, 2012, 11:44 AM
Joined Apr 2004
I have a bit of a set back. Although most would not be able to tell once the wing fairing is added, it still bugged me. It's a plug after all.
The intake has a taper as it heads towards the TE of the wing. Mine is somewhat constant. Note the pic of the Chino Museums F-104, taper and fairing.
Here is the start of the correction. Not as bad as I thought.
Steve
Old Feb 05, 2012, 01:38 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
I think thats goning to work!..looks good from here...
turbonut is online now Find More Posts by turbonut
Old Feb 05, 2012, 02:36 PM
Joined Apr 2004
Scott, you need to see it in person.
Steve
Old Feb 12, 2012, 05:35 PM
Joined Apr 2004
Hi All
By mistake I posted the latest pics on the other form I am not keeping current on this sublject.
So heres what did.
My wing tanks were taking damage. So, I fixed it and decided to mold now.
Basic molding style.
MDF shelf cut to sink plug into 1/2 way, bondo in gaps, keyways installed, tinted epoxy resin surface coat thickened with cabosil.
Next. Few layers of glass, pop off MDF and mold other side.
All waxed and pva'ed of course
Steve
Old Feb 12, 2012, 08:20 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
quite a coincidence... I just did the exact same thing tonight..lol I have two Tip tanks already, but I needed two wing tanks aswell. Ill be fabing a Nuclear bomb later.
Here's what Im replicating..http://www.aircraftresourcecenter.co...chulze/00.shtm
Trev
Old Feb 12, 2012, 11:14 PM
Joined Apr 2004
Good view for reference. For the P Avons one, right??
Steve
Old Feb 13, 2012, 12:44 PM
Joined Apr 2004
It's a bit cold here today, 63. For epoxy that's cold. Hence the little heater and lid off one of the arfs I have to make a temporary hot box.
A pic of the glass layers on the surface coat.
Basically, 5 layers of 4oz "e" plain weave, I think volan coated.
We normally don't use this top quality glass for reinforcement (only for parts) for the mold but, but it was all I had laying around here.
The reason for using 5 layers of this glass, is due to the shape of the mold itself.
It provides a tremendous amount of support geometrically. I guess that would be the way to say it.
Normally, on our large fuse or wing molds, we cap them off with a 20oz final layer. I have a large roll of bias configured 20oz glass. Gotta use it somewhere.
Steve
Old Feb 13, 2012, 12:50 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Cool! Work is done after this week so on to the arado
Old Feb 13, 2012, 04:13 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Steve
Yes Sir
Wanted LTB F-16 1/8 to 1/5 scale fenderbean Aircraft - Fuel - Jets (FS/W) 2 Mar 21, 2011 03:29 PM
Sold Slighly Used Jetlegend 1/7.5 Scale F-4 Landing Gear $350 Shipped FlyBoyTha1 Aircraft - Fuel - Jets (FS/W) 0 Mar 10, 2011 11:17 AM
Sold PRICE SLASHED - PZL 104 Wilga 35 1:5 Semi-Scale Kit - No longer available in the USA Hoverup Aircraft - Fuel - Airplanes (FS/W) 0 May 06, 2010 11:53 PM
F-104 Starfighter Project 1/16th scale lphan Pusher Prop Jet Models 308 Jul 31, 2006 08:34 PM
For Sale F-104 cockpit 1:12 scale by italeri like2fly! Aircraft - Electric - Jets (FS/W) 0 Jul 29, 2006 05:23 PM
