Old Aug 26, 2003, 05:25 PM
Wolfman is offline
Find More Posts by Wolfman
Boondocks, East Coast, USA
Joined Jun 2003
Wattmeter Source or Load?
When using my wattmeter to get mah indication from charging do I hook up the battery to Source or Load?
I think the charger gets hooked to the Load side and Battery to Source side but need to be sure.
When hooked up right I charge the battery through the wattmeter right? and the mah shown on lower right of display is the mah in the battery?
If you know the answer and could very clearly explain what gets hooked to what and exactly the procedure you would be doing me a big favor.
I am using my wattmeter and loving it but would like to use it to full advantage and need this last clarification to be all set.
Many thanks,
Charyl
Wolfman is offline Find More Posts by Wolfman
Old Aug 26, 2003, 05:59 PM
jcyr1 is offline
Find More Posts by jcyr1
United States, AZ, Surprise
Joined Jul 2002
Wolfman,
jcyr1 is offline Find More Posts by jcyr1
Old Aug 26, 2003, 06:02 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
to monitor a battery during charge, the charger is the souce, the battery the load.
dave morris is offline Find More Posts by dave morris
jcyr1 is offline
Joined Jul 2002
Wolfman,
When using the "Wattmeter" the source is always where the supply voltage is coming "from". the "LOAD " is where it is going to. Hope this helps.
John
Discussion Depron Source, or Better than Depron?? Butch777 Electric Plane Talk 5 Jan 24, 2007 01:44 PM
Found ISO: WattMeter (Astroflight or Watt's Up) heffe2001 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 31, 2006 06:24 AM
AeroHawk 3-in-1 board, new replacement source (or cheap used?) OmegaDot Micro Helis 6 Dec 26, 2005 11:16 AM
Need Source or Schematic for Adjustable Low-Voltage Cutoff green66 DIY Electronics 0 Nov 27, 2005 07:55 PM
Whoops! Endoplasma Source or Suggest a Replacement Motor rivanna Power Systems 6 Oct 29, 2005 09:37 PM
