Old Jul 28, 2011, 08:03 AM
Tifani is offline
Find More Posts by Tifani
United States, IL, Park Ridge
Joined Apr 2010
Originally Posted by Gary Mortimer View Post
Hi !
What about 2 servos 90 deg. heli swash plate mix,
with simply swash plate it can move as many vanes you can fit with only two servos.
Also little mod. heli swash plate can be use.
Only my 2 cents
Tom
Tifani is offline Find More Posts by Tifani
Old Jul 29, 2011, 10:51 AM
Brandano is online now
Find More Posts by Brandano
and if you use 3 servos with the right helicopter mix you can use the same vanes to control yaw as well, but you must set up the swash plate to slide too
Brandano is online now Find More Posts by Brandano
Old Jul 31, 2011, 01:08 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I am a bit late to the thread but what the heck. This is the rough model.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 31, 2011, 05:33 PM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
Looks good, I'm waiting to see everyone elses first attempts before modifying mine again.
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Jul 31, 2011, 05:54 PM
Joined Nov 2007
Aside from the horizontal rings, it is finished. I am not building it though. Maybe in a month or two, but not any time soon. It has eight rings. My ball has a 14" diameter and will accomodate a prop up to about 10". You simply remove what you need to remove from the center column. The center rings are 6mm. Everything else is 3mm.
Old Jul 31, 2011, 06:37 PM
Joined Nov 2007
The official version is complete. I just have to put it together to make sure everything fits. Would anyone be interested?
Old Jul 31, 2011, 06:55 PM
Joined Nov 2007
Done... Would I recommend this for the average builder... No!
Old Jul 31, 2011, 07:24 PM
Tifani is offline
Joined Apr 2010
Hi !
I do not see any problem to build the ball.
But control mechanics and software - maybe ordinary gyros only ?
Tom
Old Jul 31, 2011, 08:02 PM
Joined Nov 2007
My ball will need one 24"x36" sheet and one 12"x36" sheet. It is a lot to cut out by hand.
I do not see the controls be difficult at all. You will not even need a gyro. The battery needs to be located as far down as possible. The battery would act as a natural stabilizer.
My design has a cage to the bottom. Meanwhile, the rest of the electronics could be mounted between the battery and the motor. The servos should be mounted right under the motor mount.
Old Jul 31, 2011, 08:34 PM
swami is offline
Find More Posts by swami
swami's Avatar
Ursel, Belgium, Europe
Joined Jul 2001
How would the battery act as a natural stabilizer?
Dirk.
swami is offline Find More Posts by swami
Old Jul 31, 2011, 08:38 PM
Joined Nov 2007
Weight. Think of a balloon.
Old Aug 01, 2011, 01:13 AM
Gaftopher
Joined Feb 2007
The battery on the Japanese one seems to be on the CG and that allows it to roll nicely when on the ground!
Old Aug 01, 2011, 01:22 AM
Joined Nov 2007
They have a relatively unlimited budget. They can afford to put three gyros, plus a back up gyro for each gyro.
Old Aug 01, 2011, 03:24 AM
swami is offline
swami's Avatar
Joined Jul 2001
That doesn't work: no matter the orientation, a balloon lifts upwards while the drone lifts in the direction of the vertical axis.
This has been discussed over and over again.
Dirk.
Old Aug 01, 2011, 06:58 AM
Joined Nov 2007
I think you are still missing my ENTIRE point. When I referred to the balloon, the discussion was not abou orientation of lift. The lift was balance. It does not matter how strong the wind or lift is, the heaviest part (the elongated end or the filler part) will always try to sink in relation to the rest of the balloon.
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
Discussion New AR Drone (i-drone) light mod bungle68 Multirotor Talk 3 Apr 13, 2011 05:30 PM
Discussion AR Parrot Drone For Sale Matt Gunn Atlanta Area RC 4 Mar 16, 2011 07:41 AM
Found Parrot AR. DRONE iceman77 Aircraft - Electric - Helis (FS/W) 3 Mar 15, 2011 01:51 PM
Discussion Piloting Drone From iDevice BUT takeoff/landing from a computer chope1 Multirotor Talk 0 Mar 07, 2011 10:12 AM
