Japan
Joined Apr 2010
8 9g servos + arms = 96g
motor+ESC+8040 = 60g 3s lipo=? frame=? 5mm depron control surfaces+skirt=? gyros=? I have 2 GY48Vs coming, they are 20g a piece. Here is the motor: http://www.hobbyking.com/hobbyking/s...idproduct=8618 I'll have to calculate the thrust and see if it can lift the ball! I'm trying to keep the weight down! ---------- EDIT: As a side, HK has these new cheapy ($10) MEMS gyros, GA-250, that are very small and light. Look a bit difficult, but would be great for this project. I'm still wondering about gyro placement. 4 gyros, 2 for the four elevon surfaces, and 1 for the rudder and 1 for the elevator? Following this model, I'll need to get 4 servo Y-cables? |
Japan
Joined Apr 2010
I have enough 3mm fiberglass rods to make a small 120cm circumference ball, or split some 5mm rods to make a larger 220cm ball. Smaller will be lighter, and with gyros harder to control doesn't matter? Does it matter with a VTOL like this as its not really using surfaces for lift?
I have been marooned on this thread! Noooo...!
Japan
Joined Apr 2010
Bit more info here:
http://www.wonderhowto.com/news/wond...7-mph-0128795/ Mainly good video of surface movement, and it has 3 gyros, 16 "spoilers". |
| Thread Tools | |
| Mini-HowTo RC Controlled AR.Drone w/o WiFi! | nosaari | Multirotor Talk | 113 | May 13, 2011 02:26 PM |
| Discussion New AR Drone (i-drone) light mod | bungle68 | Multirotor Talk | 3 | Apr 13, 2011 05:30 PM |
| Discussion AR Parrot Drone For Sale | webdr | Atlanta Area RC | 4 | Mar 16, 2011 07:41 AM |
| Found Parrot AR. DRONE | iceman77 | Aircraft - Electric - Helis (FS/W) | 3 | Mar 15, 2011 01:51 PM |
| Discussion Piloting Drone From iDevice BUT takeoff/landing from a computer | chope1 | Multirotor Talk | 0 | Mar 07, 2011 10:12 AM |
